(#2676)
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 10-05-2015, 08:57 PM
Originally Posted by x99percent
Yes, this is on Android. No other apps (except games that only run in landscape) will rotate, but the JB4 app doesn't respect the system's rotation setting and will still rotate.
I'm investigating it.
Originally Posted by rob_h10
Can you retrofit my older connectkit to the current V3?
Losing the data and usb cables next to the JB4 would be great! And I'd be willing to pay a nominal fee...
There is no retrofit option as the kits are very different. You could just sell yours on the marketplace and buy one.
(#2677)
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 10-06-2015, 01:33 AM
Is the max cool setting somewhere in the app?
(#2678)
Race8877's Avatar
Race8877 Race8877 is offline
Car: BMW 135I
Default 10-06-2015, 07:16 AM
I just installed my REV3 .So niceeee.Man good job.
(#2679)
AV1977 AV1977 is offline
Car: M4
Default 10-06-2015, 04:29 PM
Just installed JB4 and Connect Kit today. I love it so far. I can't figure out how to change settings like Active Sound, etc. The "BC" button on the turn signal no longer responds. What is the appropriate process?
(#2680)
Car: 2008 135i
Default 10-08-2015, 11:19 AM
No, just set it with your steering wheel controls.
Glad you like it!
Good to hear you like the kit. I'd make a post in the support section as far as Active Sound and the BC button not working. I don't think it's related to my kit. Someone else had a weird issue and they ended up having the wrong JB4 firmware uploaded.
I'll be posting my iOS beta tonight so if you're one of my beta testers, please contact me and let me know how it works out for you.
Updates for iOS include the following:
Hopefully the final fix for the occasional compressed log bug.
Selected logs now stay highlighted after review.
More color options for RPM Glow.
GPS Speed now saves the max value. To view the max value, simply double tap your GPS Speed gauge. Double tap again to view the live value and clear the last saved max speed.
Various other improvements/bug fixes.
Trying to get an Android beta up later as well if time permits. I'll have more details later.
(#2681)
cmg5461 cmg5461 is offline
Car: 2008 E90 335xi 6MT
Default 10-08-2015, 11:40 AM
Can I be added to your android beta list?
E90 335xi 6MT - Deep Green
(#2682)
rleroy4298 rleroy4298 is offline
Default 10-08-2015, 12:21 PM
Another issue I notice with the iOS version that I'd like see fixed, involves issues syncing the app setting "PID Gain" with the steering wheel/interface setting, "Base Duty Cycle" (Speedo 12)...if I change this value in the app, its not reflected in the steering wheel controls/interface...same goes for making the change with the steering wheel controls or interface.
(#2683)
rob_h10's Avatar
rob_h10 rob_h10 is offline
Car: F30 335i
Default 10-08-2015, 12:50 PM
Device: Nexus 5
OS: Android 5.1.1
Engine type: N55 F series
App build: A059
Problem:
Currently running N55_OBDII_PWG_2 firmware and have intermittent errors using the BC button. These occurences has never happened prior to installing the OBDII firmware which I did just last weekend.
When opening and closing the exhaust valve via canflap the blinkers do not flash. Also, I can't access the dash menu system.
Recently, with the app not running, CEL warning was triggered, error: 180001 ********* dp detected.
F30 335i, JB4, dec4tted, BMS intake, CG Precision Exhaust
(#2684)
The Leopard's Avatar
The Leopard The Leopard is offline
Car: E92
Default 10-08-2015, 06:53 PM
Just a small finding. Now with the remapped ST maps (the meanings for each JB map number are different), when running map 4 (23psi) when you end a WPOT log it gives the error "JB4 switched to map 4". When in reality is was already on map 4 (Map 1 is now the failsafe map). I think you just need to look at the ST toggle and revise the warning logic appropriately.
Good stuff, still loving this app.
TS N54
(#2685)
dotCEO's Avatar
dotCEO dotCEO is offline
Car: 08' BMW 135iM
Default 10-08-2015, 09:58 PM
Should set up a github for the OSX JB4 app, so those like myself who can, can contribute in the project.
7DCT 2013 LeMans Blue BMW ///335is (Pending Inspection)
6AT | 135i ///M Sport - CRASHED (TOTALLED)
(#2686)
Default 10-09-2015, 04:38 AM
Don't forget about android!
(#2687)
dotCEO's Avatar
Car: 08' BMW 135iM
Default 10-09-2015, 04:39 AM
That too
(#2688)
335iFFM 335iFFM is offline
Default 10-09-2015, 05:36 AM
Hey Dmac
I've been trying to contact you via Mail since month but it doesn't seem to work. I always get an error code back.
How can I subscribe to the waiting list for the V3 for an F80?
335i N55 DCT
(#2689)
Race8877's Avatar
Car: BMW 135I
Default 10-09-2015, 07:09 AM
Question: Why can't I logged with my tablet Android 4.4 with Bluetooth, and
with my I-phone is not a problem.With the tablet I get all the time No Bluetooth device found.I have REV3 installed.
(#2690)
str8shot str8shot is offline
Car: N54 135i
Default 10-09-2015, 07:38 AM
I'll jump on the beta bandwagon as well...
2008 Montego Blue 135i Coupe // Sport Package // JB4 G5 Iso in passive mode with custom e30 MHD tune // Bluetooth e85 content analyzer with JB4 integration // Walboro 255 inline pump // BMS downp|pes // VRSF 7" FMIC // ER charge pipe // Turbosmart BOV // Injen intake // M-Factory SMFW // F10 550i clutch // Vorshlag camber plates // Hotchkis FSB // Turner adjustable drop links // AST 5100 coilovers // Hawk HPS pads // Ti backing plates // Stoptech stainless lines // Turner 15mm front spacers
(#2691)
Car: 2008 135i
Default 10-09-2015, 07:01 PM
Yes, PM me your email address.
Not really sure what is going on with that. I'll investigate it.
Device: Nexus 5
OS: Android 5.1.1
App build: A059
Problem:
Not an app/connect kit related issue, please post this in the support section for the correct support.
Thanks for the report. I'll get this in the upcoming iOS/Android updates.
My code will not be open source. I spent A LOT of time reverse-engineering the original JB4 app to make mine work. It wasn't until I already had a functional logging interface that Terry sent me the actual JB4 Interface source.
This is however going to be my primary focus so expect more active updates on the JB4 related apps over the coming weeks/months though.
Originally Posted by 335iFFM
Hey Dmac
Just PM, me. I'm going to be checking my PMs tonight anyways.
Sounds like your Android tablet has some weird issue. Are you sure that device supports Bluetooth Low Energy?
Anyone that wants beta access, PM me your device type (iOS or Android) and the email address you use for that store.
(#2692)
Car: 2008 135i
Default 10-10-2015, 12:19 AM
If you want to try the Android beta, which should be live in a few hours, follow this link.
Beta Opt-In Link
(#2693)
Car: 2008 135i
Default 10-11-2015, 01:11 PM
I will stop accepting pre-orders at some point this week. After all pre-orders are taken care of, I should start having a continuous supply of Connect Kit in stock.
(#2694)
mike_nazz mike_nazz is offline
Default 10-11-2015, 01:55 PM
nice work!
Is their going to be a 0 100 timer?
(#2695)
jackyl22 jackyl22 is offline
Car: 2015 M3
Default 10-11-2015, 04:14 PM
Has anyone had issues connecting to the JB4 by USB? I have a Macbook Air and when I connect the usb and open app it says " Not Found".
(#2696)
dotCEO's Avatar
Car: 08' BMW 135iM
Default 10-11-2015, 05:15 PM
(#2697)
Bullitt1841's Avatar
Default 10-11-2015, 05:19 PM
From page 1 of this thread:
*How To Connect:
iOS - Requires my JB4 Connect Kit.
Android - Can connect with an OTG cable or my JB4 Connect Kit. Note that not all Android devices are either OTG compatible or Bluetooth Low Energy compatible. It is up to you, the user, to find out if your device supports either OTG or Bluetooth Low Energy. Android users using my JB4 Connect Kit must realize that the Android Bluetooth Low Energy implementation is still not up to par with iOS's. Due to this, Android users may need to restart their device to be able to connect to my kit. This is not a problem with my kit, but rather an issue with Android's Bluetooth 4.0 implementation. Hopefully they will pay more attention to Bluetooth 4.0 in the near future.
(#2698)
Car: 2015 M3
Default 10-11-2015, 06:21 PM
I'm inquiring about OS X on MacBook not IOS for iPhone.
(#2699)
Pennzoil Pennzoil is offline
Car: BMW M4 RHD
Default 10-11-2015, 06:23 PM
Will this apps compatible for S63tu engine later ?
(#2700)
Car: 2008 135i
Default 10-11-2015, 06:33 PM
Originally Posted by mike_nazz
nice work!
Not quite yet.
Did you select the proper serial port from the settings page?
It's compatible now, just select N54 for your engine type.
Closed Thread
