Vroom's Avatar
Vroom Vroom is offline
Car: 335i 318ti
Default 08-15-2015, 01:50 PM
Congrats T!
Just got my M4 this week. JB4 in short order.
DLSJ5 DLSJ5 is offline
Car: E92 M3
Default 08-17-2015, 03:53 PM
I'll have to do some VBOX 1/4 mile runs next just to get a feeling for what sort of traps we're looking at with the car. Gut feeling is around 132mph in 60s weather but I might be a bit optimistic.
I think that's doable Terry, can you do a standing burnout with the F8X M3/M4 or does the DCT disengage?
16 F82 M4 ZCP - DCT - JB4 - Meth - 1/2 Mile 161MPH
08 E92 M3 - DCT - Built Motor - ESS VT3-750 SC
710 WHP/495 WTQ STD CF @ 14.4psi
6.1s 60-130MPH (Drag Strip)
174.12 MPH Shift-S3ctor Standing 1/2 Mile - E9X WR
Default 08-17-2015, 04:00 PM
Never tried but I doubt it. Best we can probably do is a rolling burnout.
LostMarine's Avatar
LostMarine LostMarine is offline
Car: E92 DCT ///M
Default 08-18-2015, 12:44 AM
Probably worth a line lock kit. Took about 2 hours to install from start to finish. Awesome burnouts/traction with heated up tires
Default 08-20-2015, 10:02 PM
Same tuning & settings on more of a slope. 6.35s.
dani335i dani335i is offline
Default 09-04-2015, 02:14 AM
Hi therry, can you Show me a log in Datazap with your upgrade Turbos ? i will see the ignition after the shift. A lot of 335i DCT user had Problems with the ignition after the gear shift.
I will buy a M3 F80 with DCT next year and have no interest of this Problem with the break after the gear shift...
Default 09-06-2015, 02:58 PM
Log is in the first post.
335iFFM 335iFFM is offline
Default OEM 100-200km/h times - 10-08-2015, 05:55 PM
Hey guys.
Which times did you guys achieve 100-200km/h with a stock car? I've just measured mine and corrected the runs to 0% slope. I've also tested different shifting strategies. Seems like we should shift @ redline which is cool.
8.5s was the time with a slope of -1% and uncorrected. Best corrected time (0% slope) was 8.7s. Seems quite fast to me for a 100% stock car but data back up the last run I did with the PBox a few weeks ago.
Best
335i N55 DCT
Default 10-08-2015, 06:21 PM
Use the vboxtools.com website to analyze the VBOX files.
Default 10-09-2015, 12:47 AM
Attached for the same run.
What a crazy run :D Congratulations Terry
Default 10-09-2015, 05:29 AM
Here we go:
335i N55 DCT
Default 10-09-2015, 08:36 AM
Not bad! What mods? As you can see in the log on mine I start in 3rd gear which has been working pretty well. Helps with traction.
iuhutch's Avatar
iuhutch iuhutch is offline
Car: 2011 e92 335xi
Default 10-09-2015, 09:17 AM
Dayyyum! Impressive as always
If TPG can break into the 10s, well then....I know you can T!
A418t81's Avatar
A418t81 A418t81 is offline
One tire fire
Car: E92 335, 6MT
Default 10-10-2015, 03:24 PM
<-- Quite literally I am sure, lol.
'18 Magnetic Gray Raptor
'19 GT3 RS Weissach
'09 997.1 6MT: FBO, 65mm VTGs. 730 whp
'18 Nardo Gray RS3 APR stage 2, 10.72 @ 130
Default 10-10-2015, 06:18 PM
Car is 100% stock except a heat resistant golden foil around the Intercooler + around the OEM Chargepipes which shouldn't do much.
Really interested to see how the car runs with a JB. It's already in place since two month or so but just not connected .
Will do a dyno first on Map0, then Map4 + Log, then 1 + 2 + 7. Car runs only 102 Octane ARAL Ultimate since day 1.
Edit: I've also started in 3rd gear. The rear always breaks loose if I start in 3rd or below
335i N55 DCT
Default 10-10-2015, 09:05 PM
Sounds good. Be sure to do a few runs on each map for adaption!
