(#526)
Alanassar's Avatar
Alanassar Alanassar is offline
Car: Audi s5
Default 04-27-2019, 06:24 PM
Originally Posted by Stankia
Anyone run this on a S5 SB? The install guide pics for the OBD harness look different than on my car:
Can't find a way to run the harness to the engine bay.
Introduce a Fisher wire trough the groomet from the engine, you will see it under the dash and the attach it to the obdII cable and pull it, you donít need to remove anything
Default 04-29-2019, 07:19 AM
Originally Posted by Alanassar
Hi! Im thinking to buy the wmi for the s5/s4, does anyone has some guiadance or photos to install it? I have apr ic but I think it doesnít have the wmi nozzle
Thank you !!
You can get the nozzle adapter found here: http://www.burgertuning.com/methanol..._for_audi.html
There is some good info in terms of ground and power here: https://www.audizine.com/forum/showt...-upgrade/page9
Delphic Delphic is offline
Car: Q60 RS400
Default 05-13-2019, 11:25 AM
I have a 2018 B9 RS5, and access to E85 very readily. Which map should I use once I install this? Map6? 5 gal of E85 to the rest 93? Expected HP/TQ gains doing so?
Any tweaking needed?
Default 05-13-2019, 12:21 PM
Go to map 5 which is tried and tested and send logs through so we can see how its running. Typically you should be at the 530hp and 550ft lb mark.
Car: Q60 RS400
Default 05-13-2019, 12:24 PM
5gal of e85, or do you suggest a different mix? I assume the bcm does not work well for the RS5, or not needed, as I do not see the RS5 as an option for it.
Default 05-13-2019, 01:28 PM
It works on the RS5 although the RS5 has less of a issue hitting its boost targets without. Generally the reports from users who have added it is slightly less lag and a bit more boost in the lower gears.
5 gal mix is good.
Shorty Shorty is offline
Car: BMW M140
Default 05-13-2019, 10:31 PM
Lads with S4/S5’s. Is it worth can getting a ***** and adding the BCM module over just the JB4 only?
I have a customer who has an S4 and it looking into mods and wants to know weather it’s worth going further than just JB4 only.
Default 05-14-2019, 11:07 AM
Originally Posted by Shorty
Lads with S4/S5ís. Is it worth can getting a ***** and adding the BCM module over just the JB4 only?
I have a customer who has an S4 and it looking into mods and wants to know weather itís worth going further than just JB4 only.
If they will be using ethanol blend and racegas, I would highly recommend it IMO.
Car: BMW M140
Default 05-15-2019, 11:00 AM
Cool. Have ordered ***** and JB4 for him.
Next question, how hard is it to fit the *****?
Default 05-16-2019, 04:59 AM
Not sure what is asterisk out. Are you referring to the boost control module? If so there is a video in post 1 with install and its straight forward.
Car: BMW M140
Default 05-16-2019, 05:05 AM
No I mean changing the exhaust part that comes off the turbo
Default 05-16-2019, 11:24 AM
Very easy for the S4. One Vband and 4 bolts.
Yoshimura Yoshimura is offline
Car: Audi S5
Default 05-18-2019, 04:43 PM
I will soon install the JB4 on my stock S5 running Petro-Canada 94 and I have a few questions for you George...
- From my understanding, the fuel pressure connection is not required for 94. Is this correct? Any reason I should connect it?
- After installation, do I need to adjust some settings? How can I make sure the module have the correct default values?
- What would be the best map to use for safe and reliable operation with Petro-Canada 94? I really don't want to push things.
- Should I start with map 1 and send you a log file?
- How the car/engine should be operated during the log file capture?
By the way, many thanks for bringing JB4 to our platform George!!!!!
wires wires is offline
Car: Audi SQ5
Default 05-18-2019, 07:00 PM
I run map 3 on 91 octane with no issues (typically Co-op fuel).
Default 05-20-2019, 06:27 AM
Hi, map 2 for conservative and map 3 is what is recommended. Some cars look good in map 4 if you in a area where temps are still low.
We need foot flat logs in 3rd and 4th gear from low rpm in 3rd.
You can plug and play the unit initially with no need to connect.
Kekela98a Kekela98a is offline
Car: Audi S5 SB
Default 05-25-2019, 06:30 AM
Is it possible to safely use straight e85 and Map 4?
Default 05-25-2019, 01:42 PM
It will overwhelm the fuel system. Max we recommend is 5gal to a full tank.
nicotino15 nicotino15 is offline
Car: 2018 Audi S4
Default 05-28-2019, 03:15 PM
Hey George - now that you've had WMI out for a while and some logs, how are you feeling on that for running map 5 type numbers (or custom) in Texas summer vs running E30 and bigger FMIC?
Still debating it and I guess my biggest concern is around the WM distributing successfully to all the cylinders and providing the benefit equally.
skyseer skyseer is offline
Car: gtr
Default 05-29-2019, 10:26 AM
Hello! How are stock b9 rs4/rs5 with jb4 are running compared to fully stock 2012+ nissan gtr? Thinking about dumping gtr for an rs5 but don't want slower car.
Default 05-29-2019, 10:43 AM
Stock for stock, I'd say the GTR is faster...
Car: gtr
Default 05-30-2019, 07:24 AM
Yes, I understand that. I was asking about jb4 rs5/rs4 (stock hardware) vs stock gtr
Default 05-30-2019, 08:10 AM
RS4/5 with JB4 on 93 will run around a 11.3@119mph. I think the GTR is slightly quicker than this?
Gojira13 Gojira13 is offline
Car: S5
Default 05-30-2019, 09:44 AM
Can someone tell me what the latest firmware is for my S5? I bought and received it the JB4 on Tuesday but when I tried to switch to map 3 I got a message saying no firmware available so I downloaded and installed JB4 Audi S4 4 T4. Running map 3 on that version.
Default 05-30-2019, 09:47 AM
That is the latest version. Is all fixed now?
Car: S5
Default 05-30-2019, 09:58 AM
Yes it is.Thanks
