(#101)
ucsbwsr's Avatar
ucsbwsr ucsbwsr is offline
Car: 535xi Wagon
Default 12-16-2015, 09:25 AM
Originally Posted by samstryker
Engine bay is looking clean! Do you eat off that? I saw on Instagram that you were having some problems with your drivetrain. I'll keep my fingers crossed...
*just finished eating breakfast in the engine bay*
My drivetrain problems were mainly due to my lowered ride height and CV boots tearings, then when installing some aftermarket CVs they were not seating properly (due to being low). I decided to give a AWD-RWD conversion a shot by removing the CVs, F Diff, and F Driveshaft, transfer case was left in place. I removed AWD from the vehicle Order and also unplugged the actuator for the TC.
Car was operational and traction control would work when breaking the tires loose at speed in 1st or 2nd (and let the tires spin when off) but the ultimate test was to do a traditional stationary burn out. Doing so made something go BOOM and there definitely was a mechanical failure, I am just not sure if it was the trans, TC, or E-diff. I am having a hard time connecting the dots on how the DXC would trigger such a catastrophic failure. During the burnout I wasn't slapping the rev-limiter and smoking people out, rather the rear tires were just starting to spin and revs were maybe around 4,000rpm.
I have not had time to investigate as A) I am on vacation and B) my buddies FFTEC E90 is still a garage queen while some more goodies arrive.
Evan
N54 Powered M5 Wagon:
- M5 Driveshaft, M5 LSD, M5 Axles, M5 Brakes, M5 Rear Suspension
- M5 Front End, M5 skirts, M5 Mirrors, M-Tech Rep Rear
- KW V3, RD Sport Sways, UR Strut Braces, Forgestar F14 SDC
- Manual Trans Swap, MFactory SMFW, Spec Stg 3+ Clutch, UUC SSK
- EOS Port Injection Manifold, Fuel-It: Stg 2 LPFP +Lines +Ethanol Sensor
- JB4, Hexon RR550s, Custom Inlets, AR ***, 3" Exhaust, VRSF 7" IC, ER CP, Tial BOV, RB Ext. PCV, BMS OCC
Car: 08 535i
Default 02-23-2017, 11:10 PM
Subscribed. Just picked up an 08 e60. Was looking for options. Thank you for this. Would you be interested in selling your first set up? I liked the first version with the flat filter. Also did you figure out the A/C line?
Replacing my turbos with VTT OEM replacements for now. Would love to do this when re installing.
m5james's Avatar
m5james m5james is offline
Default 08-11-2017, 10:44 PM
Bump for the question above or a complete parts list, please. I blazed through this thread while at work and looking over my shoulder but I didn't see if there was a consolidated price on the final design. Someone local is selling an MMP inlet for $18 but I don't know if it'll fit an E61 and/or if doing this homemade setup would be cheaper.
ucsbwsr's Avatar
Car: 535xi Wagon
Default 08-11-2017, 11:22 PM
This inlet system was not cheap, parts alone were nearly $400.
Fabrication was also required to get the system fully assembled.
Evan
socaln54's Avatar
socaln54 socaln54 is offline
Car: 535i
Default 02-09-2018, 07:55 PM
Reviving thread, awesome idea anyone know where he could have gotten all the pipeing and couplings?
ucsbwsr's Avatar
Car: 535xi Wagon
Default 02-12-2018, 04:24 PM
Silicone Hoses
Max Redline
HPS
Turbo Hoses
eBay
socaln54's Avatar
Car: 535i
Default 02-15-2018, 05:11 PM
what type of clamps to use on turbo? many debates between worm and t-bolt clamps
ucsbwsr's Avatar
Car: 535xi Wagon
Default 02-15-2018, 08:33 PM
I like worm drive. They are less likely to pinch and create as possible boost leak plus they take up less space and can fit into tighter areas. A quality worm drive is capable of holding a lot of boost.
socaln54's Avatar
Car: 535i
Default 02-15-2018, 09:19 PM
where did you get yours?
ucsbwsr's Avatar
Car: 535xi Wagon
Default 02-15-2018, 10:08 PM
Read the thread man!
socaln54's Avatar
Car: 535i
Default 02-15-2018, 10:44 PM
Silicone Hoses
Max Redline
HPS
Turbo Hoses
eBay
HPS is local to me, which clamps did you buy from them for the 1.75" D side? any special SAE that you went for?
ucsbwsr's Avatar
Car: 535xi Wagon
Default 02-16-2018, 09:18 AM
I don't remember what I used. There are 4 clamps which will work so pick your poison.
socaln54's Avatar
Car: 535i
Default 02-16-2018, 10:23 AM
Really appreciate all the help man great thread
datbimmer datbimmer is offline
Car: E92 335i
Default 10-21-2018, 02:39 PM
Amazing build. Where did you get the tiny beefy coolant system clamps ? Did you just use heater hose to replace the stock rubber ?
ucsbwsr's Avatar
Car: 535xi Wagon
Default 10-22-2018, 08:01 AM
Don't remember where I got the clamps, I might state that in the thread. Yes, on heater hose.
rcpro88 rcpro88 is offline
Car: 535i
Default 10-25-2018, 07:16 AM
Ever have your rear inlet pop off the turbo/come half off?
DON'T buy VRSF D.Ps or inlets! FBO, E85 Walbro 450, xHP trans flash
ucsbwsr's Avatar
Car: 535xi Wagon
Default 10-25-2018, 07:56 AM
No, the piping is aligned correctly and the snout of the 90 degree coupler is long enough it can't back off since the firewall is so close. I don't use a clamp and you shouldn't need to with proper alignment/fitment.
Car: 535i
Default 10-25-2018, 01:28 PM
I have the VRSF ones and I noticed mine popped off when I went to remove the turbos. I noticed mine are straight after that 90 degree elbow and don't seem to account for the fact the turbos are recessed to the part where the engine meets the trans. I don't think RB inlets have that problem. I googled it and found a few other people had their VRSF inlet pop off. I cleaned it and all but couldnt get the thing clamped on the turbo good enough for me, so I made a turbo flange extender to give a longer lip to clamp on to/be free from dealing with the wastegate interfering with the hose clamp screw body. Now I know the thing won't fall off, I was shocked when I saw it off the first time, its not easily visible on the 535i
y0itzflip y0itzflip is offline
Car: e60 535i
Default 01-16-2020, 10:09 AM
so since my water pump is leaking, iím starting this project. well at least the relocation of the expansion tank. went thru the thread a few times, did you use new coolant hose on the bottom as well as the top hose on the expansion tank or just the top? also were you able to align the top mount where it is bolted (near power steering res.) or was that remounted some way? thereís a lot of pics so I got lost a little. love this thread and your work on the e60 platform that always gets ignored in the whole n54 scene.
ucsbwsr's Avatar
Car: 535xi Wagon
Default 01-16-2020, 11:04 AM
Yes, I bought some extra coolant hose to connect things.
I don't really follow your questions about aligning the top mount where it is bolted?
