04-22-2015, 10:54 AM
Curious to know what his setup is in map 6 and what kind of boost limiting in the lower gears would be used for the track?
04-22-2015, 10:56 AM
Boost limiting can be changed in dash now which makes it easy to setup at the track. I would guess 8.0 in 1st and 4.0 in 2nd would be good for his setup. We will find out this weekend at Shift Sector I guess.
On our PURE Turbo M3 I run 8.0 in 1st, 7.0 in 2nd, and 4.0 in 3rd. But I'm also targeting around 30psi vs. Ando's 25psi.
BMS Customer Service
Car: bmw 335i
04-22-2015, 11:53 AM
Currently my 1st gear is at 7psi and 2nd gear is at 4psi
04-22-2015, 01:20 PM
Originally Posted by iuhutch
Sweet numbers, very impressive for a mostly stock car. Any concerns with these turbos on the higher output maps?
What is the stock boost level set at?
04-22-2015, 01:56 PM
Logs are in the first post.
N54TECH FTMFW
Car: E92 335i
04-22-2015, 02:28 PM
Congrats! looks like you were able to reach 25psi on the custom map6 !
Are you going to get *********?
If you do please re-dyno, 550whp or bust!
04-22-2015, 02:41 PM
No competition race use only *** for this S55. It's going to be operated on public roads. I'm not sure they do much on "race car" S55s anyway. Mainly just sound.
Car: bmw 335i
04-22-2015, 04:35 PM
For now I want to break hearts with my JB4 only S55 M4
Car: F80
04-23-2015, 09:45 AM
This is very impressive!
My setup will be the same as Ando's car. Going to keep stock ***
04-23-2015, 09:52 AM
For the map 6 were you using the default boost settings across the rpm band?
If not is there a screen shot that can be loaded up of map 6 settings?
04-23-2015, 09:58 AM
You can see the map 6 target in the log. But, tuning is a details business. Some customers are not able to even run map 7 on E30. In this case we happened to get away with a bit more. Unless you know how to read logs and adjust the tuning stick to the suggested map 2, for now.
Car: 2007 335i coupe
04-23-2015, 11:37 AM
What needs to be done to run more e85 mix? Is that limited due to hardware or software?
Car: 2015 ///M3
04-23-2015, 12:42 PM
So for the stock runs, those were with E30 running Map 0? Does that mean there is some benefit running a mix over 10% on a stock vehicle?
04-23-2015, 03:31 PM
Yes E30 on map 0. Didn't seem to add any power over normal 91 octane numbers. But a little E85 stock can't hurt. Maybe an extra 10-15%.
04-23-2015, 05:38 PM
This is really great Terry!! 520whp on a JB4 and E85 is insane!! So for now the highest pump gas only numbers are at about 480whp? If they can creep up to 500whp on 91oct with bolt ons I think the M4 will have to be my next one..
Car: M235i 6spd
04-27-2015, 05:58 AM
Very cool!
15 M4 / 14 M235i-Sold / 09 E92 M3-Sold / 07 E92 335i-Sold
Car: 2015 M4
04-29-2015, 10:44 AM
How is this car producing so much more power and torque than Mike's stock dyno? He reported on a previous thread 391hp and 381ft/lbs stock. This car is showing MUCH higher base numbers. Almost the same numbers as Mike's stage 1.
Car: 2015 M235i
04-29-2015, 08:06 PM
Does this M4 have the fuel mass connector installed? Is it needed for E30?
04-29-2015, 08:11 PM
Yes it's required for any E85 use.
04-29-2015, 08:12 PM
All dynos read differently. The "stock" dyno is also on E30 which helps a bit. I actually made 430whp stock IIRC on 93 octane.
Car: 2015 M235i
04-29-2015, 08:54 PM
So with our gas here having 25% E mixed already (note that octane remais 95 (US RATING), would I need it and a custom map would be required? That's the big question.
04-29-2015, 09:42 PM
I don't know. Log it and we can evaluate fuel trims.
Car: e92 335i
04-30-2015, 04:23 PM
how many miles do you have ? great numbers when did you actually start tuning your car how many miles? i wanna have a clean break in period and tune thats why i ask. thanks
Car: bmw 335i
05-01-2015, 10:24 AM
After the first service. Which is at 1200 miles I think.
Need4Speed
Car: 2010 E90 335i M-sport
05-01-2015, 10:31 AM
Ando is your car fixed for NFZ?
