(#101)
Default 04-12-2019, 11:35 AM
That would be it. If it sprays when doing a test purge then generally is OK.
You could set meth trigger = 1 so meth flows on all maps, and then log map1 with meth trigger = 1 and without, to see if fuel trims change.
Car: q50
Default 04-12-2019, 12:12 PM
That's the external trigger enabled? I'll give that a try. I'm also using about 30-35% meth, but would still expect to see a change in fuel trims.
Default 04-12-2019, 01:13 PM
1 enables WMI on all maps, 0 the default enable WMI only on map8.
Car: q50
Default 04-12-2019, 02:11 PM
Got it. Will give it a shot.
Default 04-12-2019, 06:24 PM
Also I would not suggest using less than a 50/50 mix.
Car: q50
Default 04-13-2019, 05:20 AM
2 map 1 pulls back to back 1 with external trigger on and 1 with it off.....not sure I see much difference but maybe you can tell?
Car: Infiniti Q50 RS400
Default 04-13-2019, 09:36 AM
Terry mind checking my log. If it looks okay, might be ready to try e30 next week.
Car: q50
Default 04-13-2019, 01:58 PM
I just checked in Excel and even with external trigger to 1 it showed meth flow as 0.....
Default 04-13-2019, 07:09 PM
Looks good to me. We raced our Q50 w/ E30 and WMI at the half mile event all day, maybe 10 pulls. Ran great!
Car: q50
Default 04-14-2019, 12:42 PM
Any explanation on this? Has the external trigger and meth flow been confirmed on v7 firmware to work with all the other maps?
Default 04-14-2019, 03:06 PM
Meth trigger mode is still 0 in these logs not 1.
Make sure to click save after inputting the value.
Car: q50
Default 04-14-2019, 03:40 PM
I'm obviously missing something...is it the "external trigger enable" from the WMI menu or somewhere else?
Car: q50
Default 04-14-2019, 05:32 PM
Or should it be meth trigger mode from the user adjust menu?
Default 04-15-2019, 06:55 AM
Looks like you have to enable on both. Just tested this morning. Meth feels much smoother on my map6
Car: q50
Default 04-15-2019, 07:01 AM
I swear its like pulling teeth to get detailed info on what to change where in the JB4 app. There are so many settings in there, many of which do not apply to our platform. It would be nice if there was more detailed responses or pictures on what to change where. I had to Google the BMW platform to see what the meth safety settings were.....
Default 04-15-2019, 07:10 AM
Totally agree with you. From the install to jb4 app settings. I do understand BMS not releasing too much info on the settings. You can easily damage your engine if done incorrectly. Us adventurous guys will have to learn it the hard way until they release a detailed guide for our platform.
Car: q50
Default 04-15-2019, 07:39 AM
The opposite is true, I could have put it on map 7 expecting meth flow and not had any meth because the vendor wasn't clear about what setting to turn on. This could have resulted in damage. There's only a handful of us early adopters and we're providing info to others on this site and 2 others which will lead to others following....it would be nice if we could get detailed support.
Default 04-15-2019, 08:30 AM
Thatís why they recommend to stick with map8, 50/50 meth etc for now. Iím good with their settings but ready to move on and comfortable enough to start customizing.
Car: q50
Default 04-15-2019, 08:46 AM
In my case, we're not seeing a drop in fuel trims with the meth on so we were trying to troubleshoot.
Car: q50
Default 04-17-2019, 06:49 PM
New logs with -20F WFF and HEET, should be ~50/50 meth. Track outing was a new best, worse 60ft but took 2 tenths off my 0 to 60 and dropped et to 12.4 at 114mph. Logs attached.
Default 04-17-2019, 07:05 PM
Looks decent to me!
Car: q50
Default 04-18-2019, 04:27 AM
Looks decent to me!
Thanks, I'm guessing it was peppier due to the higher meth content....though I still didn't see the drop in trims like others, but the boost was higher so they could offset. High gear I could see the trims drop, and if I switch to my map 6 the trims are lower so it's got to be doing something.
Default 04-19-2019, 06:07 PM
Learned something today. Purge only works on map8 seems like. Tried Purge in map6 with External Trigger 1 doesnít work.
Car: q50
Default 04-19-2019, 06:12 PM
Yup I found that out too.
Default 04-19-2019, 06:22 PM
Scared me a bit since I just retubed some lines then the pump wouldnít activate lol.
Also, maybe itís just the warm weather the other day, noticed the car tranny jerked a few times under 30mph when shifting with External Trigger 1 enabled. I will keep a keen eye on it.
