Jkeplinger89 Jkeplinger89 is offline
Car: 2015 GLI
Default Meth not working JB4/FSB - 07-24-2020, 07:36 PM
2015 GLI
Xman turbo, APR Stage 2
JB4, FSB, BMS Meth BM7
Blue Pin 16
Orange Pin 3
Green to Solenoid other Solenoid wire to ground
Yellow to Pump
When logging I see 0, nothing is leaving the tank.
When I am in map 6 and purge, the pump turns on, meth flows from the nozzle
I followed this for set up
JB4 Meth Integration Setup - N54Tech.com - International Turbo Racing Discussion
Then I tried messing with the meth trigger and safety settings noted here
N54 Settings - JB4Wiki
Still nothing.
Checked my wiring a dozzen times, still nothing.
Checked the fuse for the FSB, it was fine, replaced it anyway.
Still, nothing.
JB4 is on JB4_EA888_8_5_1.hex
George @ BMS George @ BMS is online now
Default 07-26-2020, 11:29 AM
Resolved with correct settings.
ZuMBLe ZuMBLe is offline
Car: VW Alltrack
Default 07-26-2020, 02:26 PM
If the JB4 could control boost based on meth, could it also control boost based on ethanol content signal from an external ethanol sensor? That would be really cool.
Default 07-26-2020, 09:26 PM
It could but what would you think would be a workable range without mapping it custom for the ethanol. i.e. E10 dont add and E40 add 3psi ?
Car: VW Alltrack
Default 07-27-2020, 07:28 AM
Of course being able to custom map would be ideal. But I think most people run about E20-E30.
