BostonShant's Avatar
BostonShant BostonShant is offline
Default N55 owners who want open OBD flashing get in here!! - 07-29-2015, 10:35 AM
With all of the awesome progress lately on the N54 tuning/flashing side of things I have gotten extremely jealous . As most of us know the cobb flashing capabilities are in the stone age in comparison to even the cobb support for N54 (no vanos tables defined even, etc etc). Not to mention how handicapped we are compared to the new stuff that is being added to the N54 xdf's. Cobb has pretty clearly abandoned the BMW flashing game and are just riding on their good reputation now. @jyamona suggested putting a list together of people interested in furthering the N55 tuning so someone like @martial@mhd might be interested in adding N55 support to the MHD app (or anyone else with the necessary know how and skills). I would certainly ditch my Cobb and pay for an app or whatever if I could edit and define my own tables and flash the DME over OBD and not be stuck with what cobb decided was "good enough".
Chime in here if you are in the same boat and are interested in seeing this progress. Obviously the E9x N55's will be easiest (as cobb already proved they are flashable) but there are certainly a lot more F3x N55 cars out there so the ability to flash those cars at all would increase demand significantly.
Thanks guys!
Check out the original post here.
http://www.bimmerboost.com/showthrea...l=1#post656197
2011 135i - N55 - JB4 ISO - FBO + Meth + Corn
VTT JB Stage 2 with VTT Forge DV and VTT N55 Waste Gate Upgrade
Pump Gas
60' ... 1.850
1/8 MPH ... 98.06
1/4 ... 11.735
Trap ... 122.71
fryj00's Avatar
fryj00 fryj00 is offline
Car: 2011 e92 n55 xDrive 6MT
Default 07-29-2015, 10:42 AM
Count me in. I'm available as a tester if needed...provided the solution looks solid.
2011 E92 N55 xDrive 6MT
CantCatchMe CantCatchMe is offline
Car: '12 335i xDrive E92
Default 07-29-2015, 11:55 AM
I'm in if we can remove the speed delimiter damnit!
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2021 M550i xDrive
Default 07-29-2015, 12:52 PM
I already tried multiple companies to get the F3x supported. Consensus is that without the keys from BMW, they won't be able to be done without opening up the DMEs and manually "unlocking" them.
Mike Levy
2022 Black Sapphire X3 M40i - At the dealer, awaiting pick up
Peter @ Pure's Avatar
Car: F20 M135i
Default 07-29-2015, 01:00 PM
Well I am in. I already have some base stuff done on mine. However the removal and opening / reinstall is always a pain. But once it's opened for the first time, they can read your key from your dme.
So now that i know my key it would be nice to self flash my car. But without a device it's not possible.
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
fryj00's Avatar
Default 07-29-2015, 03:10 PM
I've been doing a lot of reading on this subject and if I find a workable solution may purchase the necessary equipment/software to do multiples. We'll see...no promises.
Darkiedm4, do you have any idea what tool was used to open your DME?
Car: F20 M135i
Default 07-29-2015, 03:16 PM
They just pry it open with a knife/screwdriver. Only thing you have to pay attention to is that on some DME's in the middle the capacitors are glued to the top of the DME enclosure as well. So if you brute force it after opening the seal/glue between the top and bottom part you may damage the DME board/capacitors.
peter@pureturbos.eu
pureturbos.eu
GR1P's Avatar
GR1P GR1P is offline
Default 07-29-2015, 04:28 PM
I'm definitely in on this one too, but I'm only looking for a way to "unlock" my DME so I can so I can add my own BEF.
All the tuners here in SoCal only offer custom mapping that doesn't work with anything but pump gas.
2013 135is 6mt - FBO - Pure stg2 - 90/10 meth - Fuel-It stg2
loesch's Avatar
loesch loesch is offline
Car: 2011 BMW 135i M Sport
Default 07-29-2015, 04:39 PM
This has been a wish of mine for quite some time now. I have a Cobbable N55 but the Cobb is extremely limited on what it can alter. They say it can't be done, so someone do it and prove everyone wrong! How is the method used to implant the PPK different from this? Apparently that's pretty easy.
loesch's Avatar
Default 07-29-2015, 04:47 PM
This is why we need this...http://www.n54tech.com/forums/showthread.php?t=31534
The misfire gremlin.
Mike_L's Avatar
Anti-Social
Default 07-29-2015, 05:59 PM
PPK is flashed on by a dealer or the Port. Its a BMW product, so they have the encryption info and keys so they can do it. It goes on just like any other DME update except they have to unlock it after writing.
Mike Levy
Default 07-29-2015, 06:09 PM
Don't think you can fix N55 high boost misfires with flash tuning. The flash maps misfire as much or more than the OEM flash maps.
On the F series flash tuning, thread is a waste of time. The tuners already know if they can release a workable solution they will reap huge profits. It's just a matter of one of them figuring it out and then monetizing it in a way that prevents others from copying them.
deemarr 335i deemarr 335i is offline
Car: 2011 E90 335i
Default 07-29-2015, 06:10 PM
Definitely in....2011 e90
F30George's Avatar
F30George F30George is offline
Car: f30 335
Default 07-29-2015, 06:28 PM
Def in!
F30 335i Jb4 ISO/ Pure stage2wIntlet/ DV+/ER Cp,Dp,FMIC /meth/MPE/BMS Intake/3.5barTmap/Spec stage3+/Pss10
Mike_L's Avatar
Anti-Social
Default 07-29-2015, 06:55 PM
From what I'm hearing, the late E-series are the same as the early F-series. Its the Bosch MEVD series DMEs. Just can't get into them.
Mike Levy
diesel3443's Avatar
diesel3443 diesel3443 is offline
Default 07-29-2015, 07:03 PM
In definitely in as well!!!
2018 Alfa Romeo Giulia Quadrifoglio
Venoml2k Venoml2k is offline
Car: 135i 2012
Default 07-29-2015, 09:52 PM
Just got mine a month ago, and I would love to be able to change parameters. Intake and jb4 were the first mods.
obriennathaniel's Avatar
obriennathaniel obriennathaniel is offline
Car: F30 335i
Default 07-29-2015, 10:12 PM
in!
CG Precision VS-1 Exhaust\DR-1 | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | JB4/ACF Performance w/BM3 | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge|
jake1220's Avatar
jake1220 jake1220 is offline
Car: 2012 135i DCT
Default 07-30-2015, 04:55 AM
Definitely interested in this
2012 135i DCT, FBO, Pure S1, E40, JB4 ISO
330whp/400ft lbs & 12.6 @109 (Stock Turbo)
400whp/460ft lbs & 12.2 @117 (Pure Stage 1)
fryj00's Avatar
Default 07-30-2015, 07:34 AM
darkiedm4, I meant which software tool...CMDFlash, Kess, KTag, etc (if you know).
Also, from what I have seen, the Bosch MEVD17.2 is the Cobbable one. Any MEVD17.2.x seem to be the tricky ones. Though, I know even these can be programmed...but at great expense and effort. I'm doing the homework now to try and figure this out but it's not simple by any means.
The other issue is that a lot cars with these DME's are still under warranty...but they won't be after you split it open.
Does anyone know if there has been any work to develop an xdf for Tuner Pro for the N55? I would love to have a non-Cobbized look at my ROM.
NorCalN55 NorCalN55 is offline
Car: '11 335xi M Sport
Default 07-30-2015, 07:52 AM
Where do I sign?
hp jnkey's Avatar
hp jnkey hp jnkey is offline
Car: 2008 535i
Default 07-30-2015, 09:12 PM
Me too, my poor F10 needs a new life.
chrisgarcia8000 chrisgarcia8000 is offline
Car: 335
Default 07-31-2015, 09:21 AM
I have a damos file for the mevd 17.2 f30 ecru but it only works on win ols and it needs to be translated to English. and tansfered into tuner pro but if we could get tuner pro working like they have for the n54 that would be nice.
fryj00's Avatar
Default 07-31-2015, 04:31 PM
Well if you have the tables and their settings defined in WinOLS, we could re-create that in Tuner Pro. It's a lot of work but someone has to start. Do you mind sending me your bin so that I can look at the tables?
Newguy123's Avatar
Car: 12' 135i
Default 07-31-2015, 07:18 PM
Scribin'
18’ Glacier white RS3
#PURETURBOS
#FUELIT
