sx33 sx33 is offline
Car: E92 335i -11
Default 08-03-2015, 04:26 AM
Sign me up!
Wish MHD would consider developing a flash for the early N55 with MEVD172.
wgknestrick wgknestrick is offline
Car: 2011: 335Xi
Default 08-03-2015, 06:40 AM
Do we even need this list? Of course we all would like another evolving option for flashing. Why wouldn't we?
BostonShant's Avatar
BostonShant BostonShant is offline
Default 08-03-2015, 06:54 AM
The reason why this list was put together is because when it initially started over at BimmerBoost Dmac asked to put together a list to see if enough people were interested.
2011 135i - N55 - JB4 ISO - FBO + Meth + Corn
VTT JB Stage 2 with VTT Forge DV and VTT N55 Waste Gate Upgrade
Pump Gas
60' ... 1.850
1/8 MPH ... 98.06
1/4 ... 11.735
Trap ... 122.71
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 08-03-2015, 08:17 AM
Originally Posted by chrisgarcia8000
I have a damos file for the mevd 17.2 f30 ecru but it only works on win ols and it needs to be translated to English. and tansfered into tuner pro but if we could get tuner pro working like they have for the n54 that would be nice.
Can you send this to me? I'll see what I can do.
Enjoying the new tables discovered and the XDF progress made? if you'd like. Every bit is appreciated!
Default 08-03-2015, 08:19 AM
Sorry jyamona I don't know why I got you confused with Dmac.
Thanks for responding.
Pump Gas
60' ... 1.850
1/8 MPH ... 98.06
1/4 ... 11.735
Trap ... 122.71
diesel3443's Avatar
diesel3443 diesel3443 is offline
Default 08-17-2015, 09:14 PM
Bump, there has got to be more of us!
2018 Alfa Romeo Giulia Quadrifoglio
Newguy123's Avatar
Car: 12' 135i
Default 08-17-2015, 09:49 PM
Im in if we can exceed 21-22psi boost cap
18 Glacier white RS3
#PURETURBOS
#FUELIT
M-terkait's Avatar
M-Terkait
Car: F30 335i
Default 08-18-2015, 03:54 AM
ops i thought i already said am Innnn
N55 - Doc race 6266.
Default 08-18-2015, 07:22 AM
LOL I know the ball dropped on this but someone was supposed to do something about it. Let me look back and see who it was.
Pump Gas
60' ... 1.850
1/8 MPH ... 98.06
1/4 ... 11.735
Trap ... 122.71
fryj00's Avatar
fryj00 fryj00 is offline
Car: 2011 e92 n55 xDrive 6MT
Default 08-19-2015, 07:07 AM
Remapping MAP voltage would be at the top of my list as well. Want to run the N20 sensor with Cobb tune.
The guy above who said he had a WinOLS damos file won't respond. I asked for it here and in PM.
2011 E92 N55 xDrive 6MT
harkes harkes is offline
Registered Users
Car: M135i
Default 08-20-2015, 11:12 PM
I had my ECU unlocked by ESS Tuning so I should be able to flash mine too if there was only a tool to do it.
JETmn JETmn is offline
Car: 2011 335xi
Default 08-27-2015, 01:40 PM
I am in. I have quite a bit of previous tuning knowledge from the Mitsu crowd.
Default 08-27-2015, 01:44 PM
Still trying to see what's going on with this. We were asked to start a thread over on bimmerboost to see who would be interested, so we did...the ball kinda dropped there.
Pump Gas
60' ... 1.850
1/8 MPH ... 98.06
1/4 ... 11.735
Trap ... 122.71
Peter @ Pure's Avatar
Car: F20 M135i
Default 08-27-2015, 02:00 PM
I had some more flashing done on my car through obd today. The tuner showed me in winols all the things he could change.
We tried lowering ignition adv and increasing load and setting proper afr for the higher load. The ign adv seems to be working but the afr changes are not. We set afr to richest 11.9 at 7k rpm and leaner in lower rpm but in jb4 logs we always see afr dropping to low 11's and even high 10's. And then we get missfires.
So i kinda give up for now flash tuning my car. It seems not all tables are known yet and the dme runs values of some other part in dme that must trigger these rich afrs.
Maybe in the future. Time will tell. But stock flash and jb4 runs pretty nice together.
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Car: 2011 335xi
Default 08-28-2015, 05:37 AM
Darkied, have you tried the PPK flash to see if it is any better than stock?
Registered Users
Car: M135i
Default 08-28-2015, 04:50 PM
I did a few logs with my flash + JB4 yesterday. Quite surprised what I got. My car was not flashed on a dyno so not running 100% on the flash alone. Car was running good before the flash so I will probably go back to stock flash.
Not what I expected to see on map4!
Default 08-28-2015, 04:52 PM
Have the CSV?
Registered Users
Car: M135i
Default 08-31-2015, 04:25 AM
@Terry
I am running map1 until I can get it flashed back to stock.
Default 08-31-2015, 08:09 AM
Timing seems to be mapped too high for a flash?
Anyway since you are ISO you would need to manually dial in duty bias. It's clearly too high here at these targets. The flash target itself is a bit odd though. You have meth right? Log map 3 w/ say a 40 additive and then adjust duty bias as needed to get boot on target.
Alternatively you could flash non-ISO firmware and remove the blue boost control patch to evaluate the flash only mapping.
Registered Users
Car: M135i
Default 08-31-2015, 04:31 PM
The flash itself (not running JB4) does not work well enough. Something wrong with the wg duty cycle so the boost is oscillating. "mail order" flash so I guess that can be expected.
Ill be back to stock map asap.
Attached the flash only logged with Torque.
Default 08-31-2015, 04:37 PM
I would not rush to ditch the flash yet and instead would focus on dialing in the ISO. We just so happen to be working on that right now. You'd need to switch over to an OBDII CANbus connection to enable the newest stuff. But that is a lot of fun anyway. In dash boost gauge comes in handy when troubleshooting.
You can always ditch the flash in a week or two after you determine its not helping.
Registered Users
Car: M135i
Default 08-31-2015, 04:43 PM
Thanks for the recommendation, but I dont want to use JB4 as a band aid. I cannot live with having a limp car.
Default 09-01-2015, 06:11 PM
It's a details business. If the details are right you might be better off with the flash in place. Or might now. I'm curious myself. You'd have to master those details though.
We've redone the F series ISO firmware in an OBDII format and as part of that process redoing the base boost control which I think will make dialing in things like your Stage1 turbo a lot easier.
TDDaryl's Avatar
TDDaryl TDDaryl is offline
Car: 2008 335xi
Default 09-02-2015, 11:37 PM
OK I'm in here, where are the N55 flashes and who do I have to pay?
2012 E82 FBO JB4 (Daily)
2008 335x 6466 ST (being rebuilt and upgraded)
NJCarGuy's Avatar
NJCarGuy NJCarGuy is offline
Car: 2013 335i E93
Default 09-13-2015, 04:09 AM
Count me in! Love the ability to BEF my N54
Garage:
2020 X3M Comp - JB4
2011 X5 50i M-Sport - Dinan Stage 2
2002 M3 6-speed, Euro Cams, RE Exhaust, Intake, Dyno Tuned
2016 i8 - Installed K&N filter. Looking for mods
2015 X1 35i - FBO, Pure S1 Turbo + Meth
