Olimpiakos
Car: 335i e90
Dragstrip tonight had some issues -
06-24-2015, 07:33 PM
So I was fully prepped to beat my best time of 11.23 @ 126.8 tonight at the dragstrip. Ms109 in the tank, couple days to adapt, running map 7.
I get up to the track and first run I was only trapping at 118 mph.
So, I hooked up the laptop made sure I was on map 7, sure enough I was.
I tried logging a run but the guys working the line wouldnt let me run with the usb cable outside of the engine bay running into my door. Kinda pissed I couldnt log anything.
So I kept running and the best did was 11.7's @ 118 mph. The car felt as if it had no tune. I switched to map 0 and did a run to verify and ran the same 11.7 @118 mph.
No cels, no reduced power just running like stock when the laptop said map 7.
I even disconnected the battery for a bit to see if that might reset anything but nothing changed.
I noticed last week after some serious rain that the housing on the jb4 was wet. (Didnt get around to installing the waterproof cover) The plug for the usb cable actually looked like it had some rust on it.
My question is, if the board got wet and shorted out, would it throw a cel or just run like stock?
TIA
YMB F80 M3- Jb4
F85 X5M-Jb4
06-24-2015, 07:55 PM
Without a log who knows. Log it when you can. If the board was shorted you'd get all sorts of faults and zero boost. What I do when things like this crop up is make some "mini pulls" in the back of the track parking lot. To see what is wrong. It's probably something simple like you set the boost safety too low, etc.
Olimpiakos
Car: 335i e90
06-25-2015, 05:31 AM
So I did some logs this morning. Noticed that no matter what map I started in, it would default to map 4 as soon as I press on the gas pedal more than half way.
Codes were 138A04, 138102, 138A02
Attached log below. Not sure if this should be moved to the support section or not. Sorry T. Ive been out of the logging/forum game for a bit. lol
YMB F80 M3- Jb4
F85 X5M-Jb4
Olimpiakos
Car: 335i e90
06-25-2015, 05:34 AM
YMB F80 M3- Jb4
F85 X5M-Jb4
06-25-2015, 06:03 AM
Saw your runs last night I was in the passenger seat of the white 1er that pulled in around your area. After seeing your first pass I wasn't sure if it was you because I was expecting a 120+ pass LOL.
Car looks amazing. Hope you get it figured out. Good luck.
2011 135i - N55 - JB4 ISO - FBO + Meth + Corn
VTT JB Stage 2 with VTT Forge DV and VTT N55 Waste Gate Upgrade
Pump Gas
60' ... 1.850
1/8 MPH ... 98.06
1/4 ... 11.735
Trap ... 122.71
Olimpiakos
Car: 335i e90
06-25-2015, 06:18 AM
Thanks. I saw you guys pull in. Car looks sick man. I knew after my first run something was up. Especially compared to how it was running a few weeks ago up there.
YMB F80 M3- Jb4
F85 X5M-Jb4
06-25-2015, 06:30 AM
Thanks dude...it's my buddy's car (BostonBeemah) it's a VM top mount car.
I remember seeing your video from a few weeks agocar moves man. You what's crazy even with the way it was running last night, it takes off so hard its nuts.
Pump Gas
60' ... 1.850
1/8 MPH ... 98.06
1/4 ... 11.735
Trap ... 122.71
Car: 12' 135i
06-25-2015, 07:13 AM
what he run?
18’ Glacier white RS3
#PURETURBOS
#FUELIT
06-25-2015, 12:51 PM
Originally Posted by Ggreek5
You are locked in map 4, because all your settings including your boost safety, are set to 0.
Olimpiakos
Car: 335i e90
06-25-2015, 03:55 PM
But I never touched or changed anything. If I start on map 2, 1, 7 it all changes to 4. How could the user settings have changed? And how should everything be set?
YMB F80 M3- Jb4
F85 X5M-Jb4
Olimpiakos
Car: 335i e90
06-25-2015, 03:56 PM
YMB F80 M3- Jb4
F85 X5M-Jb4
06-25-2015, 04:59 PM
Not sure why you did more logs, without fixing the problem? I'm not sure how you changed them all to 0. Maybe a laptop issue. But here are what they should be:
Olimpiakos
Car: 335i e90
06-25-2015, 07:19 PM
Thanks Terry.
YMB F80 M3- Jb4
F85 X5M-Jb4
06-26-2015, 06:06 AM
Originally Posted by Newguy123
what he run?
BostonBeemah didn't run his car yet. He's still breaking in a twin disc and also dialing the car in. We just got the kit installed a few weeks ago.
Pump Gas
60' ... 1.850
1/8 MPH ... 98.06
1/4 ... 11.735
Trap ... 122.71
ElevenPointFive
Car: 2009 135i
07-21-2015, 08:43 AM
Interestingly enough, I too discovered I had this problem today. For some reason all of my default settings were set to 0. Only reason I noticed it was I was feeling like I was severely down on power. I hooked up my android and sure enough, default settings were borked. I mannually reset them all to the required settings and presto, car was flying again.
Question is, how could they be resetting?
2007 Porsche 997 Turbo - 6MT - Midnight Blue
Cobb Stage 1
2008 E90 335xi - AT - TSM
MHD Stage 2+ ~ BMS Intake ~ AMS FMIC ~ CPE
07-21-2015, 10:01 AM
Could be a bug with the android interface.
BMS Customer Service
Car: bmw 335i
07-21-2015, 10:09 AM
This has happened to me before.
All my settings were set to zero after connecting with Android JB4 app.
ElevenPointFive
Car: 2009 135i
07-21-2015, 11:08 AM
I think you could be correct. I am going to try and replicate the issue to see if there is in fact a bug wiping out all the settings.
Cobb Stage 1
07-21-2015, 05:24 PM
OK if you can find out how to do it let Donnie know so we can get it fixed!
Car: 435i
07-22-2015, 01:02 PM
Happens on iOS platform as well. It appeared to correlate with plugging and unplugging the bluetooth dongle. I leave it plugged in now...no issues.
Car: White E90 335i
07-22-2015, 04:32 PM
118mph and 126mph is excellent for just a JB4 mod! or is there more to the story?
SOLD Tesla Model S - white/blk, piano, air suspension, 21"
SOLD E93 - RB's - PTF - 4242lbs +242rwhp/+234rwtq tuning never ending tuning.
'15 Tesla P85D Insane Mode
07-22-2015, 04:51 PM
I believe the new M3's trap 119 and 120 stock, with the quickest ET stock at 11.6. Beasts! OP picked up 6 or 7 mph from the tune if I'm not completely off the mark.
EDIT: Just found the video of a stock F80 M3 at the track, 11.6 @ 119.
https://youtu.be/VUTqbhh2DCc
2009 335i XDrive (wife's)
Sold - '11 335is - N54 - DCT
Sold - '07 335i - 11.8 @ 120
Sold - '08 128i (wife's)
