(#776)
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 04-30-2014, 08:51 PM
JB4 Mobile (Android) - firmware updating demo:
New build is uploaded and should be live soon.
(#777)
j23a45m's Avatar
j23a45m j23a45m is offline
Car: 2011 E90 335i
Default 04-30-2014, 10:52 PM
got the update. my new OTG should be here in a day or two i hope. i can't wait I've been sitting like a puppy
2011 BSM 335i E90 MTECH 6MT BMS Intake Vishnu c@t less DP Cyba Scoops LUX V4 H8 6000K Headlight/Fog light Morimoto Euro headlight switch ACS roof wing 35% tint Black Grilles Misc coding JB4 Stage 2 AA charge pipe Vrsf 7" FMIC M3 cluster
(#778)
NJrep335I's Avatar
NJrep335I NJrep335I is offline
Car: BMW 335I
Default 05-01-2014, 04:28 AM
Coming along very nicely. Any time frame on the landscape view?
(#779)
BazBar's Avatar
BazBar BazBar is offline
Car: UK 140i-M Sport Auto
Default 05-01-2014, 05:15 AM
It depends on your settings. A few hours after I make the update, just open the Play Store, find the app and see what version it says you have. The update will be version A012.
Thanks, have updated and will give it a run tonight, have noticed that the Tab still says Map6 AFR & Map6 CPS, but this is not the case, it is global right ?. Will take my laptop with me this time
(#780)
paradoxical3 paradoxical3 is offline
Car: BMW x1 35i xDrive
Default 05-01-2014, 06:21 AM
This app is wonderful, now I need to get a bluetooth adapter for Android so I don't have to plug it in somehow....
(#781)
rwalker rwalker is offline
Default 05-01-2014, 08:24 AM
Need to be able to update FW from email or better yet, from Google Drive. Maybe register as a .HEX file handler in your manifest.
(#782)
SaferTransport's Avatar
SaferTransport SaferTransport is offline
Car: e92 335i Coupe
Default 05-01-2014, 09:39 AM
Why do i still not have this?!
JB+RB=
(#783)
Car: 2008 135i
Default 05-01-2014, 10:27 AM
After I finish data log graphing (which I believe is all that's left), I'll start looking at landscape.
It might say map 6 afr/cps, but it's the same thing as the JB4 User Adjustment page.
Couldn't you just navigate to whatever website you want inside the firmware update interface?
(#784)
Mortify Mortify is offline
Car: '08 BMW 135 M-Sport
Default 05-01-2014, 11:17 AM
Just bought the app and loving it. It's raining here so unfortunately I can't run logs but the real time info is great.
Eventually when I run a tablet media center in the car I will HAVE to hook this up, it will look amazing. Can Wait For Landscape mode, But No rush!
(#785)
Default 05-01-2014, 11:40 AM
Terry's always sending me non-public test firmware in email.
(#786)
Default 05-01-2014, 01:51 PM
By the way, is a scrollbar for the graph on OS X on the roadmap? I take long, large logs and viewing them in anything other than 120sec granularity is painful. I often need to zoom in on non-WOT sections for the things I'm working on...
(#787)
Bruce GT3 Bruce GT3 is offline
Car: 2013 M135i
Default 05-02-2014, 02:14 AM
Donnie,
Downloaded the iOS app this morning and all seems well.
Can you post a list of what all the abbreviations are for when selecting what parameters to set the gauges to please? Some are easy and obvious but others aren't.
Aslo can you brief me on how to set up oil temp display as one of the gauges as this is one of the other main bugbears I have with the latest BMW F2X cars - no oil temp gauge!!!
(#788)
Car: 2008 135i
Default 05-02-2014, 09:01 AM
I'll look into making a list of hex files and maybe adding the ability to open .hex files from other apps.
I'll look at making something after I finish my iOS and Android stuff. I haven't messed with the OS X app in a while.
Originally Posted by Bruce GT3
Donnie,
http://www.n54tech.com/forums/showthread.php?t=21269
Set Future Use D to 11. Save. Make one of your gauges FP_L. Done.
(#789)
Peter @ Pure's Avatar
Car: F20 M135i
Default 05-02-2014, 09:19 AM
Whats future use D to 11 do on n55 f series?
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
(#790)
Car: 2008 135i
Default 05-02-2014, 10:06 AM
I'm assuming it sets FP_L to output oiltemp instead of low pressure fuel. That's what it says on the notes document, but I'll double check with Terry since some things are different between the different JB4 variations.
Just heard back from Terry that FUD 11 isn't supported on N55 cars.
(#791)
Car: F06 N55 640i Gran Coupe
Default 05-02-2014, 05:35 PM
Hi Dmacpro, can check with you whether can your jb4 mobile apps receive wireless bluetooth connection so that I can charge the Samsung note 3 at the same time when I'm using it? The battery drain off really fast.
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS DP n FULL Custom Exhaust
Custom BC forge 18/17 set up
(#792)
markus8291 markus8291 is offline
Car: N55 335i xdrive Msport
Default 05-02-2014, 07:46 PM
Just tried downloading this on my nexus for which is running android 4.4 kit*** and it says it's not supported for my device. Any way there is a fix for that?
2011 BMW 335i xDrive M-Sport, Alpina B3 TCU flash, JB4 (ISO 5.9), FF wires, BMS Intake, BMS CP, BMS DP, VRSF 7" FMIC, KW V1's
2011 BMW 335xi : 12.567 @ 109.750 MPH
(#793)
Car: 2008 135i
Default 05-02-2014, 08:19 PM
The Android Bluetooth Low Energy API is not that stable right now. Nothing I can do about it. Sorry
Looks like the Nexus devices don't support USB Host which is required to use the app. You'll have to root your device and do some other things to get it to work. Just google around.
(#794)
Car: F20 M135i
Default 05-02-2014, 11:10 PM
Yup on n55 fp_l allready outputs oil temp. However the counter stops at 200 on the ios mobile app. If you log however you also see higher values. Could you allow fp_l to display over 199? Ideally conversion to celcius as well however i am already happy with all the stuff you did so far
peter@pureturbos.eu
pureturbos.eu
(#795)
shaunlsone shaunlsone is offline
Car: 09 e92 335i sport
Default 05-03-2014, 05:21 PM
I bought the app now waiting on the otg cable I can say it looks amazing.
will the jb4 app automatically update with the google play store?
(#796)
Default 05-03-2014, 10:51 PM
This app is so awesome for the drag strip. Thanks for developing it. No more need to buckle in a stupid laptop.
(#797)
MarinoB's Avatar
MarinoB MarinoB is offline
Car: E92 335i
Default 05-04-2014, 06:34 AM
No changing maps on OS X still?
2008 Jet Black E92 N54, JB4, FBO, Meth
2011 LeMans Blue E92 N55, JB4, ********
2014 Estroil Blue F30 N55, JB4
2018 Mineral Grey F80 M3 - JB4, *********, BMS Intake
ON DECK: 2020 X3 M Competition
(#798)
rippinrsv4's Avatar
rippinrsv4 rippinrsv4 is offline
Car: 2007 335i 6mt
Default 05-04-2014, 03:40 PM
Got this yesterday and love it.
Top mount 6466 and all the other bull****.
(#799)
Car: 2008 135i
Default 05-05-2014, 01:45 PM
I'll look into after I get done with data graphing for Android.
Depends on your settings, but it should.
Haven't touched the OS X app in a long time. I'll look into it after I finish up all the stuff for iOS and Android as those 2 are my top priorities.
Glad you all are enjoying it.
(#800)
Car: 2008 135i
Default 05-05-2014, 06:09 PM
Android data graphing is coming along. Looks like I might be able to get data graphing and landscape support out this week.
Closed Thread
