Team Tonka Team Tonka is offline
Car: G70
Default Newbie - some questions in regards to tuning... - 05-01-2019, 10:30 AM
Hoping some of the below could be answered, I'm coming off of a 2012 WRX which I had tuned (programed OEM ECU) at a performance shop. I had an aftermarket ******** and intercooler installed, that's about it.
For the 3.3T AWD my tuning options likely will be 91oct. or 93oct. fuel (both with up to 10% ethanol).
So, I'm wondering what folks recommend for a tune and what other mods (intake, spark plugs, exhaust, etc.) are truly needed to benefit from the staged tunes for the fuel I can run? How easy is it to switch from one tune to the next? For example if I don't have to add other mods to benefit from a 1-3 stage tune that would probably be ideal. Maybe when warranty runs out I'd do more mods, but simple for now would be good.
This is a daily driver car for me, round trip no more than 50 miles. This car won't see too many long trips, but reliability is of course important, and the ability and ease of removing in case of warranty issues appeals to me.
Input/suggestions greatly appreciated!
Default 05-02-2019, 09:42 AM
JB4 would be best.
Car: G70
Default 05-13-2019, 11:31 AM
I picked up a JB4. I would only likely ever use Map 0 (stock), 1, or 2. Knowing I'll likely never see over 100MPH very often, it sounds like stock plugs and gapping will work for Map 1? Will they not work for Map 2 at all, or would stock plugs need to be gapped to 0.024" to allow for Map 2 to work?
From what I gather, no need to add other mods (exhaust, intake, BOV, etc.) for Map 1 or 2 to work up to its potential?
Also, once installed what parameters do I need to verify are set correctly (and how do I know what those correct parameters are)?
Default 05-13-2019, 12:17 PM
Some users don't need to adjust the gap, others do. You can leave it on map 1 and enjoy the power gains. No need to set anything up, it's all ready to go once installed.
You can get a log for us to evaluate though.
Car: G70
Default 05-15-2019, 09:12 AM
Where would I find the directions/how-to-video on how to get a log for you to evaluate?
NLJ NLJ is offline
Car: G70
Default 05-15-2019, 09:51 AM
On USB connection or mobile app?
If via a laptop, under Logging, click Start and then Stop when you are done. Then Export as a CSV file and save it.
Default 05-15-2019, 11:40 AM
Connect via bluetooth or data cable to the JB4.
Once connected, click start logging.
Do a log from 2krpm till redline in 3rd gear with pedal at 100% for consistent data.
Once finished, if you're using the bluetooth device it will automatically save.
If you're using the data cable via laptop, you'll need to save at CSV file.
