ucsbwsr's Avatar
ucsbwsr ucsbwsr is offline
Car: 535xi Wagon
Default 03-02-2019, 04:01 PM
Siblings
Family Photo
Before & After on the Valves
Flushed front and rear diff fluid, I hate the smell of gear oil.
Decided to give the XHP X-Delete a shot. It allows you switch between AWD and RWD, the flash takes about 90 seconds.
Removed F Driveshaft to ensure no parasitic loss
M5 door handle/trim and individual for the front door cards which are on their way
M5 rear sway bar, M5 brakes, and RWD rear hubs
Stock Vs M5
Got an alignment done
Replaced electronic gear selector with the late model SAT unit
After
Coded the vehicle order to reflect the upgrade gear selector ($205 -> $2TB). GKE215 wasn't showing up in WinKFP so I couldn't update the ZUSB with the faster SAT trans software but will do later.
A couple glamour pics, can't wait to build the front door panels
Dinan muffler was way too quiet IMO, it sounded like stock. Sold it and did a muffler delete with a Vibrant tip. More sound, more character, less weight, and left over money to pay for more upgrades
Replaced broken cargo floor handle
Replaced missing outlet plugs
Headlight gasket were UV damaged
New OEM gaskets
Replaced old OEM bulbs with Osran CBIs
Replaced broken headlight housing cap
With some fuel mixture codes popping up and one time specifying Bank 1 I decided to replaced the Bank 1 pre-*** O2 sensor. What a pain. Had to remove liners, drop subframe, remove engine mount and engine mounting arm to finally get a wrench on that mofo.
[IMG]https://lh3.googleusercontent.com/yoXc_EHeGSmxGqfDte7xg-ecn0bbFvAadfolJIDz213ql5V***Pem59HxHbBw6UUpq0es2S-oyJ29xwwmGOW-jshs9lzGNJ3FIxi9ofzEDu1gix2IFb3vuFEGhuqf7O_PNJlL7q et053lPhe5Qa_0ZTICWpiKhkHvYJBYLtzLx6eMVeCJuTs8-_g8og6byPuLuhsFBkO-8k4JC5iMBHGW4Kr49Jdk7XwwlWXdGCZFaxs0bqJseunltrhhLc EwjVrUK3fvsSTPUVCUJwPUr83t8fpUNa4-3KbwAMbOVcuBjqz86m6d8ekZGKgwIZTX5g_ckLoIDHnW3z4cEz qTRsO89xYgHikoasBR8MppOfRqVu3pyUT9X-9V1cTdT3NXdtPMrqdZs-Ch_y4puU7KBybug5cXf5msdOkHdfgzvCyRl9qj8UR6XDALNWgh q4UkGQ_uW2HJnlH8qNsaqSJ78ALmaaAbEkjvufId-b4_ndmKRI8AMnAC5j-8lXibvZ_r0cK6eW9KZXlPpuwyMOE5s7aXU9Qo1A-dMzF3ZNwXh_uydMUz0eRBNAU80bCipppmej10kHUCW3Duuy0OZ H1jjwhE7KIVrTno65jxXRljlli5X46_4Xjuu0Rr0VxIrnIu6do YdAN5d5shWKCLWRlzwT3jED-kub_fdJ64Dq4CKQ7jdbC67nr-QRjhxfNkZBWoQJ1GkPjSHPPwfhUhZSV6bheEIPolw=w1303-h977-no[/IMG]
For good measure I replaced all charge-tract related vac lines. This is also not particularly enjoyable especially with banana hands like mine, the heat shielding on the engine bay closely resembles cheese graters.
N54 Powered M5 Wagon:
ucsbwsr's Avatar
Car: 535xi Wagon
Default 03-06-2019, 09:57 AM
With the front subframe lowered to access the o2 sensor in the ********* I noticed the engine mounts are a bit tired. I replaced the passenger side mount. When my white E61 gets it's fresh new RWD subframe (waiting for KWs to arrive from Germany) I will swap the complete subframe over to this grey wagon. The subframe from the white wagon is in much better condition with low mileage mounts, control arms, etc.
Snagged 2 sets of E60 M5 calipers and a set of M Parallels (for my E39 Touring)
M5 brake conversion kit for a 535xi: rotors, calipers, and rear hubs
Rotors and pads came off the same very low mileage car and the calipers were cleaned and inspected, everything looks good.
Size comparison of the rear rotors
Stock fronts
As a Southern California car with brake cooling ducts and large rotors these brake shields make zero sense so they (and all other shields) were removed.
You will need M5 specific rotor bolts for the fronts. I can confirm with years of use that M5 rotors will work on non-M front hubs but the M5 hubs to have 2 threaded eyelets for screws and also a studs to help keep the rotors centered, FYI.
Stock Left M5 Right
Fronts mounted
[IMG]https://lh3.googleusercontent.com/w7HMSLN_fc662623wUHdlFMx3PJIPehUbsvRO3nX6s_0kxsX0I xktUIPwbAzImcpzcr-cQsIe0HXT8***fwAFSBIFK-_gxaDL_1oz1Wc0rfdekoEgb1UVW3oU-r38Xwwb_23LZxKotuix595IfSsBpdWfQFjCRBDW83EKH323JlR HrYgsPqqw6L085rOf6vHSwXTFZPVEeKOfuGp0pIAk7PTlZI7nW 8xzx22xpeqEDlYp01gixMgXwG82L9P1yjXstGbXcIGW4ZQUQjW Br_5TwB3uwgMApV92DE249cUqsy-ofkmNt7aj-neC_gVvARs_NkqLVG-isQK8HmY1JhT-YgD-kGXHMK5nHy98p0uRsgmmTVtlkn0mJ_ZusA4qnWHW9A0wyh4kW9 grt8Ux9jLXI45wqDl3L3EKqJ-Cyy2N2CyffJRTh96ofHimdBovYKAUA0bc_N7iZAvPUuXSq6BKt NnILpBbx2tRwAeOQNl6ykQ67wahkalgPuDzptBM6-WnAjH81Cx3Zw68Me1SgPm0CA3LINYIeQNHa25QiFIjmQKG-nmt7V-1BNDX1zjJ-dtp900eA-M393TSUrMJfD-PBt7i0kcHLz3EMGigefNgeCZ0P-t4nHE2RtqUsvR-B8kBoKUvcJOgJ5HfRDo7Z595moqeZy4FnFYWKuzQEGtNXTnv3k 2Ugvcag9vsqvykJmtN7VWoGUwE1YWkxYxzeU_BZvFCw=w1303-h977-no[/IMG]
Annie nervous knowing how stubborn these rear axles/hubs can be.
Penetrating oil, 12 ton hydraulic puller, and a sledge to tap the hub. It's the recipe that worked for me when doing the rears on my white E61 and this got the right rear to release.
The left rear was much more stubborn. I used a torch to heat the hub up to about 400F to no avail. At this point my tools are a bit maxed out and the axles threads are damaged from the puller so I will remove the knuckle and have a local shop finish the deed.
I took a brake from the .....brakes.. LOL!!! and finished the front door panels.
Here are the donor panels I snagged off eBay.
Pretty good condition overall with some typical wear on the driver door handle
On my grey inserts you can see the top of the leather has been released like it came unglued.
Under further inspection it looks like this was a factory slip-up with not enough lather for the panel. The grey leather is about 10mm too short in contrast to the brown which full wraps around.
Driver door complete. Individual "Dirac" speaker grill showing off the upgraded DSP woofer and M5 door handle with padded leather is a nice touch to compliment the Nappa leather M sport steering wheel, and SAT gear selector. Nice surfaces to touch!
With the exception of black seat backs the custom OEM+ interior is complete. Very happy with how it came out.
Car: 2003 Forester
Default 03-07-2019, 12:03 PM
Any chance you have a video of how this sounds? I've been thinking about it since I bought the car 4 years ago but never took the leap as it's my daily.
ucsbwsr's Avatar
Car: 535xi Wagon
Default 03-08-2019, 08:47 AM
Wagon is on jack stands at the moment getting M5 brakes and other goodies, will try to get a sound clip later but in the meantime I am sure you can find a slew of E60 muffler delete videos on YouTube.
Car: 2003 Forester
Default 03-08-2019, 11:02 AM
Oh duh. Thanks!
ucsbwsr's Avatar
Car: 535xi Wagon
Default 03-19-2019, 07:58 AM
Time to upgrade the brakes
M5 brakes + RWD hubs assemblies
Rotor comparison (rears)
Dust shields get the boot to aid cooling
You will need an M5 specific rotor bolt. 535xi left, M5 right
You can sneeze and the fronts will install themselves, I wish I could say the same for the rears....
Annie knows...
For whatever reason these axles are a real paint to remove. On my white wagon both rears required penetrating oil, a 12 ton hydraulic puller, and some "love taps" with a 10 lb sledge hammer. I got the right rear to release with this method and when I say release I mean an ultra violent *BANG*. The left rear was not as cooperative.
I played around with some heat, got it up to about 300F (which I know isn't that hot) and then decided to let the professional handle it.
I removed the spindle and took it to a local BMW indy, unfortunately they didn't find any success with their 20 ton press and lots of oil. Took it to another custom fabricator who was able to get a saw between the bearing and spindle to cut the axle tip in 1/2. Fine by me since all I cared about was the spindle.
[IMG]https://lh3.googleusercontent.com/Z6VDWauQGKweBJOK2d6nrfTLXy2SwPX1AgIflyGNJrY0J0k3XR A-0ZlwGgCl5_lejRlYHjjwtMne_gAJpyRp965W7pg0GLrsRIg*** tlTdIGpiNby_TKljPCitgfllQ7XizPXzMzRLZQNIkZMs9_IWRK 92ft5-4td7HxWbeFnlGfcYHOU2QcWaavcDZLvqgmF7hEHJLc5kVzuUQR fgLolpCGRvCppuTOM7FaRKDwFBcNt0z0hl_2wFdhLiLzm2gQtD g5qEPLHedTSDgEGJ3PMGnr1a83e48PZ17JAd5B82q51akionw_ sVsnQaxEjnd1ut9rstJ4UoAp7bBCyDMG2Ms-_SiNfcVH82eSVuXa5HL3WL3x9hYxzFzopLF9qscMZFKT3lCTXa ltMHPkzq0XdPTLCurvwvy_W-iwxxInUS8KlJ-juzAmSvJtnYSTR7hBdwaKZ3HYL10GscGFtwcfnfTTyxLWgFWhL _oCmvDl7CY_ZUbHZJOB9YetOyFJDgREr0QnKVojLVzltMBHX7k jv_qIScmtK9AmWUOaiUTZsAGZBDvF4_WItkPNhbxS5GrJuoxhZ VLtd_7ai-Me7zsqg3Lbcv1OJ9TN3-uuUPsj5qDQEK-wdbbkCzTEZJUFQG6-X9HQFAIi6wkhB2-33CmIsxuY_UP2rdxzVDiVIiI5p5mv_d1pjhXSpF1lDc90JwQjA 2bU-SxcCg8UDV59hNb8A7okNQ=w1304-h978-no[/IMG]
While the axle was making it's rounds at the shops I took the opportunity to execute some other upgrades and maintenance.
Replaced passenger engine mount
Flushed TC fluid
Replaced TC mount
New CSB
[IMG]https://lh3.googleusercontent.com/C63kJGgHyiynaB0c-g9uTZXvmaQIqIXGenXzB05CvALrQALnse5Fn8nx8rBRbOU3ZQa WTWyXhKQSci71Y2SPaZjKCH9ckCka19SB-tnn7PNEJpKxh5QsOI_t7IaBdqWlqVhqqvtVwJ6xeukoGKK6ObJ LsRHZ5p5oZX78v-46XNssTOy-ZI0-tGFSgFyOpm8hqDgpa6AdU4iZ_2_druLFjMqhSj8LJcGs0bN8nc cXNlifpiCK2MG83jAj5VTRMZWH6EfNcZnFGKgQUdKH0RNouaND 9KisEMZXTHxNEgsdVHuks6W1rAJU860gfIkS1NLsp2dh6EGBwA DrnLnQgDfGoyV_GKEEdracunRM0oExn94zNKAqGz2_3iAvJjt7 Re6rQvQMuENXnjRNBAVnxRZlULrbzLP71zVYY737CSMI1VQejD g0S4adBlWP1p7VEb4pUwwKypH36cWmLzk_XTkKLIt9qKgPmkWb AyqbSFZcYNQDJP82rwNphCeC6paCYYZqN241Aa_SB36SbbBvYO PHNZ6avfzo4TH6k0bD8V0Zfq5_UOgXE1Q2odGq9wAupbJRfRZ1 MS_DymLQbRCT94T1jwlL1GHSg5--68JDHMlkqiGjc1M6***bohuKmttkHyLz-kFKINC98on-0R2uFoSlwwhSxkdpGHxObpWeIhw2Jik5m5XFsT7TLCGlR5cGdr pv-n-3gVgh4JUdiLKb9KaDeUKnoA=w1304-h978-no[/IMG]
In the spirit of a clean OEM+ build the Vossens will be retired for some style 167 (M6) wheels which are coming off my E39, E39 has a set of M Parallels which are being refinished.
Personally I think these wheels look great on the E6X chassis, heck I think they look great on pretty much everything
As a bonus we will be saving about 10lbs each corner or unsprung and rotational mass!
For fun I threw the Vossens on the E39, excuse how horrendously filthy it is.
HHHNNNNNNNNGGGGGGGHHHHHH!!! Looks perfect but would rub like crazy
New control arms, upper guide arms, and (not pictured) ball joints
M5 integral links
Used my laser level to help with the control arm positioning.
Here is the difference between AWD and RWD hubs
[IMG]https://lh3.googleusercontent.com/3TuVfiPZM1cHBuryLDDi75An1FVR_vCfbttrpTl5udAK72XNCt hSMUxIIikHYGvoMey6BsXvCD5pcg70XyzabvNin0hFoD65uS2q lLjTPUB2U5ost12rh_SE45K5RzVKT3cJDxzVYLmZ5kLsTG4tVp Quv6m0h7r62G7FF91vXWkqHM_p_GlAKYQL9cOCZxcSZHLJmzan AitMR7-Ohcd6OQ7PBeDeeqmuFkvyS43IfTA8kixhWAiUPfpsYHWESXqrZ i18VKYgGPuIOmeHaBp-tENhMqwK1JnEgdpJqXt1tyWRmuVi4lkdwsqQiblyQDIkjOqHzj eL***3dJRfrMfugepZgKmFwNg_LrSUV1Rp4CX8uiXhwzN_qfF-g8rULHZ4PII5cwPOwGTLLjeD6-s9h2zmO0fxZX7GcoPbYZpNYs1MTkHHovAY0cWVupslilcBVwQN 3apEd-t9-Cy7tNyeuPTJuVrgkseurPsNlCoct2-5tFY7QTQl97E6kg6nZdPvpr_oa5oyA2Q9NFGTBJSmY9_ANyHME lKA8tDXc-i6lrlkUfm89CMagwA-0UyH_TuUj7D4B86Qv5OiFs_Eie7oSfblyYX_tzVpNI7qLAUhUx 7dBNRRYXHwE2Y03BdfGzF6elQvP3K5qbQSE4RtmBmfawm5sraw 2lGSZF8PDVvm9-8zfyPlwKrZmFrDdYNKVAlwqRq94oFa3-YpwGIIh0nzOO9HZQ=w1304-h978-no[/IMG]
Cleaned up the spindles a bit
Cleaned all threads and mounting surfaces before assembly, fresh locktite
Original ball joints coming out
Surface prepped prior to install
New ball joints and M5 links installed
One axle died in the m5 brake upgrade and the other had ~130k on it. Luckily I had an extra set of axles with about 70k on them.
Bleeding brakes
I need to adjust the parking brake and rebleed the brakes but here is how she currently sits
ucsbwsr's Avatar
Car: 535xi Wagon
Default 04-01-2019, 08:53 AM
Garage Dog ready for some wrenching and sniffing
Cleaned and installed black seat backs, this completes the custom 2 tone interior!
Looking sharp!
On my white E61 I needed a RWD specific driver side engine mount so I transferred this mount over to the grey wagon, it only has a few hundred miles on it so it now both engine mounts are essentially new, the old ones were past their prime.
For the life of me I couldn't find one of the parking brake springs when reassembling everything after the M5 brake upgrade (the long one on left) so I was forded to buy the repair kit.
With the spring installed and parking brakes adjusted (stupid process, can't believe it isn't easier) it was time to re-bleed the brakes. BMW Dot 4 fluid, Motiv bleeder, the juggernaut Schumacher battery charger, and INPA software which bleeds the DSC pump as well.
Buttoned up, engine bay is very stock but very clean
The Grigio Telesto hides dirt incredibly well, better than any color I have seen, with all the wrenching on the wagons a wash was long over due, this was the 2nd time I have washed it in my ownership. lol
Got all the wagons together for a quick family photo
ucsbwsr's Avatar
Car: 535xi Wagon
Default 05-21-2019, 07:16 AM
An overdue update but a lot of progress has been made. Really happy with how it's coming together.
Here are a couple pics showing the interior.
Inspecting the rear glass release button which doesn't actuate, hopefully it's only the button and not the wiring harness, no other tailgate related issues.
1 dog 3 wagons
The E39 got it's Style 37s which means the Style 167s are ready to go on Das Grau
Style 167 + E60 M5 brakes = WIN
Straightened the window trim which was bent by a careless body shop during disassembly, not perfect but much better.
Personalized plates arrived.
Rear bump stops needed replacing
[IMG]https://lh3.googleusercontent.com/Pado2d5cUQ_d2H5XfTUG7J0HZVi937Fiah__0cT1suSt-hfL_jZlyq4hfxpATXBZz_iF4CLtz8K0ktTX7n0uJ9K3LbdzaXE WhBmcTw32az0AQBRNhxGX6mbLV3DFt1FVxMpXplHLP5JMySaqn 4OZ8bqgugVu1epWUtVRzRU9pcUVeHi-toKCcdeISl_utPKlFrhTCMbzwwUZVHKFFrWANhTosnUEeLKTcr VyG7BDU2yB1sx9gUUHsuxKN8Am0id7o9qFd39H92s0xnEPKAyZ OSu6YCxD338DwvvF3KC0lNnbyy8Kqky6KVuvL6vemZMTrKuRll d00fevFFVl2G4tTDJMctx1Vovk1xE5GQgYVo-1t6A3R8LC_kBuUfhWRuGmvSSNU43-y9qJX0ST04A3DtV69Xs_XGYQXRqhr18CYkmRKIClcYkZsFoGS3 VQd3dOh4gBNpTnRBqF0Wn_bXfT6ouQ85u9FMTyeyjQjl0u84XL lPYrjAWNTOwAVmZ0G_I8O53495eP3pGvxfp1ESBmaZlQUn_V2r GtOjFk0hrC3VmYRkgjUKUYskDc_phqIOnX7A5NGq2OsGg0tvxU YZVoqgBVmOjqupN9A68zXHjorIfiPsrYITjEM35UGOx3LTyJ0b dXTZBIJykkbfpoUoJLIv7_ku0caJOijLhSPdGHiSnabpl-_99RN1_ZX6VwvHx2c***XDtwDoz5LW-tpOPNlrOWqA=w1300-h976-no[/IMG]
Cleaned up the rear struts too
Windshield cowl was in rough shape so I installed the lightly used cowl from my white E61 (the white one got a new cowl
Pano roof had some issues, there was water ingress that warped one of the partitions and damaged the track, there were also some parts missing so instead of going down the deep rabbit hole of repairing the unit I simply replaced it. Thankfully I was able to find a local dismantler who had the cassette with the grey interior panels I needed.
Headliner and cassette removed.
New OEM weather stripping
Big difference
With the old stripping removed there was a nice amount of residual foam and adhesive to remove. Preferred technique: heat gun and a strong thumb.
All clean, you can see the OEM paint
Installing the new strippig was easy since the cassette was out but very tedious since if it wasn't installed just right you would be able to see the OEM paint at the seam which is a no-no, this made the install pretty challenging but the results are great.
Amateur hack: You can use the electric seats to hold and move the pano roof (headliner also) into position during install. This made the install reasonably easy considering I was doing it solo.
1.
2.
3.
San Diego coming through with some timely rain for testing purposes! This thing operates as it should, no longer rattles from broken/missing pieces, and has hardly any wind noise!
Looking good
codesx codesx is offline
Default 05-21-2019, 09:57 AM
Over The Top.
What movie or collector are you building these for? lol
TMAP: 3.5 barr
xHP Stage 3 (v2.0)
VRSF CP | HKS BOV
RB PCV Valve
NGK 5992 Plugs @ .020
Maintenance:
ucsbwsr's Avatar
Car: 535xi Wagon
Default 05-21-2019, 10:03 AM
Originally Posted by codesx
Over The Top.
This one is going on Bring a Trailer.
ucsbwsr's Avatar
Car: 535xi Wagon
Default 06-17-2019, 08:13 AM
We have entered the final stages of the build and with most of the mechanical maintenance and upgrades done it is time to tidy up some loose ends, to me this means fixing some of the visual eye sores which are out of place on the wagon. Previous owner had kids and dog and used the wagon as a daily driver (rightfully so!) but this meant there was extra wear on the rear seat and cargo area.
I went back to the dismantler who was parting out the E61 I got the panoramic roof cassette from and picked up a few more interior parts.
Original rear seat cushion
Replacement cushion
Much better.
Replaced some broken cargo floor hinges
[IMG]https://lh3.googleusercontent.com/lv5YTmiQpSdQJtXVu1QW8c4_YCD2j91IPLL8k_CA2017iLTZ7m 5HR-BHaRtORulPHaDz2v3FaZwW83GOVmiM3i3X9cwLcdc-lvSwsaOCOVToBH4MR9BcvTodFmI3LOlqbSTIExxnU3m6Gh4NWa 3d3EWO_-XIlE_b0yLhT0SOdcwDD2GLPVFVnlIpV5JDFit3yLiXp_XhbHce Rbf4l82C9fX6b5MlmU-caWuf2CtE4eKVav16C3Dqt1m_QF7gFDWugM9Rsl37YuZHZLhxm ywxSeKEvuf2eH***1jltWVHTDwUVHjN-PMveDSSqXH73RxfXhDv2CI64gUlMy3qQco7UZatYDh-IALHWRymDHUrvdm86CmiT-9Nmw4MC2AVgOtNs-lHjVOaF8mUnW69tmAbWpsnnAP01UHfVK3vPcZfFSuQrBfRpmqP r2qa5XbxIaK8OsEiBI6ZHZLy6KolEttdMbB0di75K7vuQGjb5j 2ojbM2EBBAxVDeE4frtj3vjZJ4yoCcb3Wi1Dw3FEaDqI1hPuEg vFoFFouWn7nrFWyUb4nsTW9P94CJTLRG_KaEEMNA-HRB6LpP4SpEp_S7aXhU1dmOagTqKVXgIEqxliaxqa_gqRO4zNr 4sGaB3uMhwgt51bBduPq5ws_AQQ9JXJ1I8uW21HNe6jupAsEQL 9jZ7_GDXxhrf0D4uVq-Ps6XqyHjtWd44LylV7Vv2MlZyOqY9Um_Xw=s975-no[/IMG]
Replaced child seat anchor covers
Replaced cargo hook covers
Saggy elastic strap replaced
Both thigh supports on the front seats were inoperable. The motors were working but the cushion was not responding to electronic adjustment. Turned out both plastic gears were shattered. Thankfully repair process was cheap and easy, $10 and 15 minutes per seat.
Needed to find a solution to get the gears ofer the metal lip at the end of the worm gear
My solution was to Dremel down the metal enough for the plastic to slide over and into position. I ended up taking off more material than shown in this photo but it worked like a charm.
10mm socket makes for a nice press base
Plenty of grease in the assembly to reuse and relube the gear
Yellowing plastic from UV is never cool so I applied some Plasti Dip to visually refresh and protect the plastic
[IMG]https://lh3.googleusercontent.com/JUQueU9h-n63X97mPPf***VGNiCBX5HVB0YdLZQ7VJqtNYwDWxaICtyw-KeWDSWZFNP0qnNk8K2PE46AXyY3qO9vKh_ORTvXbYfunra4w3d bm4IsnRmrFYX5rA0iCZNgCsTvXBnPcl1-FP3wpWaay2KYUBQ_09PLYoIs7ryPABGnGufMYq0ppBVUD4VZFP K7U0fUjUKc6DlHmfGojGxxVQo925Cidx0Ib1xFrSSFRePBMVTI kxxBmVePKUIsQxHRbCq-VvtL3UJVjqx23Z_t9djIWI_d9r4-lywSwRVKFzrNeubEcvIctZQw6FxEOJ1_8ZgFn_AMl-ZPlGXCstbTO6azLbzrgC5DVD2_MDgnp6Nc9e86nLehEK1R8Z8P wLQ1Q_kOkNoG3KLG4SAckb5Ue51rUPticMTTIwQYk-Pp81J7ZUHPagVMA743CK_uJMyA1zro1Jv-HGbI4TVxG7TPBbh_hvgW46u7e7yhKBdDiNF1w_XN7mDF7Wx3Jb oIFgPBonkbMHnM6lYRnPcsAWsc_jmdnWrHbCGUZrNXO2G2mPO3 jM9htOg3pNkpTX3yxtUiqhMoQdGJee5RoS2CLBjVhXI-6aF00AnVjpKdfxP_DGkTwsavihueXXHurhzLWXOaCyLqCXpnLf 9SjZAGjMpDLBcpmNWJHdX2rFMx9Kb_Z-Vwwj8tig_lQ5JO2JX6fXqTtlQT7yD_JzHdhQ_rREo1VLwE1A=w 1300-h976-no[/IMG]
The Style 167s had some very minor curb rash repaired. For the record these wheels fit in the back on an E70 X5 perfectly!
Refreshed wheels with full polish on the faces.
Up next is cleaning the undercarriage, then onto mild paint correction and interior/exterior detailing.
ucsbwsr's Avatar
Car: 535xi Wagon
Default 07-01-2019, 10:15 AM
Made it to the BMW CCA Clean car show in San Diego. Great event where you get to drive right onto the grass a Spanish Landing Park right on the edge of the harbor, couldn't ask for a better location. The wagon was well received and grabbed it's fair share of attention.
Will be going again next year but will be bringing board shorts so I can take a dip in the harbor between eating some grilled brats, chatting with people, and enjoying other's builds.
These are also the first pics showing the style 167s wheels with fully polished faces, I was a little worried they might look too much like chrome but am happy with how they turned out, clean!
Quick wash and clay bar.
Love the Grigio Telesto
Wagon providing a seat + shade. Hanging with my good friend, volleyball bad-ass, and fellow BMW enthusiast - Matt Anderson.
Polished faces popping
Girlfriend made it too and we were able to sneak in the X5D.
Hard to beat this venue
ucsbwsr's Avatar
Car: 535xi Wagon
Default 09-12-2019, 02:59 PM
Serviced the transmission:
- New pan/filter
- New mechatronics sealing sleeves
- Fluid flush
- Painfully slow fluid filling procedure using an infrared thermometer
