3000GT MR's Avatar
3000GT MR 3000GT MR is offline
Car: 09' 335i
Default Spark plug guide - 05-04-2016, 06:33 PM
This has been a long needed update.
So after many years of owning high power N54’s I’ve had my fair share of ignition problems and have tested many parts. This thread is more to inform people what is actually out there and the options that can be had.
After all it really only boils down to 3 choices so pick one that suits your needs.
Spark plugs:
NGK 95770 (ILZKBR7B8DG) formally 5992’s
1 Step colder than stock. Recommended for any FBO +.
http://www.sparkplugs.com/product.aspx?zpid=39947
$13-14/ea
Autolite XP 5682
1.5ish colder than stock. By the information I received on them when compared to NGK. Recommended for FBO+
I ran these for a few thousand miles both with E40+meth and full E85. It performed much better than expected and better yet they are cheap. For the price they seem to be well worth it. They are dual tip dual material Iridiums and platinum. I’d expect them to last the 20-30K miles you usually get out of the 5992’s
http://www.sparkplugs.com/product.aspx?zpid=29181
$6-7/ea
NGK 93026 (DILKAR8A8)
2 steps colder than stock. 1 step colder than 5992’s. Recommended for 700hp+
These are the stock plugs in the GTR R35+.The GTR guys are running them in the 1000AWHP-sub range with E85. I have been running these for a pretty long time with full E85 and they have been great. They seem to be a little more crisp with response and slightly better starting than the other options. Last time I had them out they were still very clean telling me they aren’t to cold even for full E85.
Now with GTR plugs comes a whole other world of aftermarket parts we are deprived of. HKS has a plug, NGK has a $100+ race plug etc If anyone wants to try any of the other options, then go for it and let me know, ill update this thread.
http://www.sparkplugs.com/product.aspx?zpid=9718
$17+/ea. The price of these have really came down.
NGK 97506 (SILZKBR8D8S) S55/N63TU/N20?
2 Colder than stock.
Should be a good fit for us but currently untested. Someone try them out and let us know!
Now lets talk gapping.
I see a lot of people running into ignition issues swearing they gapped the plugs correctly. Wire and the round disks you get from AZ or advanced are all junk. I use either “feeler gauges” or a razor blade that I used a micrometer with to verify thickness. There should be a slight resistance as you insert the feeler gauge between the electrode and ground. If it goes in really easy or its tough to get in then its not gapped correctly. Take your time and do it right the first time.
Recommended gaps are
0.022”…….0-25psi (pump to E50 with meth)
0.018”…….25+psi (pump to E50 with meth)
0.018”…….20+psi (E85)
That’s been my experience with fresh coils. Others may have better or worst luck.
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust
335i 2009 e90 665RWHP VFF900 ST RIP .
pysical pysical is offline
Car: 2009 335xi
Default 05-04-2016, 06:53 PM
I would recommend going to
www.sparkplugauto.com
for the NGK 95770
http://www.sparkplugauto.com/ngk/las...park-plug.html
9.99$ ea
3000GT MR's Avatar
Car: 09' 335i
Default 05-04-2016, 07:06 PM
for the NGK 95770
9.99$ ea
Good call much better pricing.
I used the other links more for the info. I'd recommend shopping around regardless of which route you choose.
Default 05-04-2016, 07:12 PM
We've got the Bosch plugs, NGK 5992 plugs, and special socket tool always in stock ready to go.
http://www.burgertuning.com/N54_BMW_...t_adapter.html
3000GT MR's Avatar
Car: 09' 335i
Default 05-04-2016, 07:17 PM
I wish you had that socket years ago. I wont even admit what i paid for mine years ago. Your pricing is always reasonable.
Have you tried the DILKAR8A8 plugs? I wonder if it would clear up any of Payams timing/melting plugs. The dual tip is good for spark concentration too.
Default 05-04-2016, 07:19 PM
We had it years ago. I think we've sold over 5000 by now lol. It works really awesome with the magnet too. Everyone should have one.
On the plugs I have not at least not that I recall. I had a phase where I tried 4-5 different ones (NGK, Brisk, etc) and eventually decided NGK 5992 worked the best at least for my needs at the time. Now with the OEM N20 & S55 plugs out I may give those a whirl once Bosch releases the part number for non-OEM sale.
Car: 2009 335xi
Default 05-04-2016, 08:04 PM
I got a socket that works from Autozone for around 9$ if I remember right.
PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 05-04-2016, 08:22 PM
I'm running Pure stage 2 with PI E85. I run 26psi (640ish whp) and use 5992 gapped to .022. I'll try them at .018. I'm not 700+ but is it worth trying the 93026 gapped to .018?
SOLD - FBO N54, Pure Turbos stage 2, TFT inlets, JB4/MHD, EOS intake manifold w/PI, Fuel-it stage 3
Bullitt1841's Avatar
Default 05-04-2016, 09:04 PM
Only if you have experienced misfires
bradsm87 bradsm87 is offline
Car: E90 LCI 335i
Default 05-04-2016, 09:15 PM
I believe it's Bosch ZR5TPP33. Apparently the "ZMR" in the part number for the BMW OEM spark plugs is just for "M" printing on the plug and "ZR" are an identical plug.
Edit: S55 use those Bosch plugs. N20 use NGKs.
Levan-i's Avatar
Levan-i Levan-i is offline
Car: 2007 BMW 335i E92
Default 05-04-2016, 09:21 PM
thanks for info!
btw, i was always wondering why BMS doesnot sell already gapped NGKs, would make life much easier to so many folks
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
3000GT MR's Avatar
Car: 09' 335i
Default 05-05-2016, 03:58 AM
The S55 plugs don't have generic P/N's yet so its tough to say whether they are just overpriced 5992 equivalents or if they net any potential gain spec wise. They are quite expensive and for the money something like the DILKAR8A8 seems to be a better deal having dual tip iridium over what looks to be platinum on the S55
Car: E90 LCI 335i
Default 05-05-2016, 04:03 AM
I'd be interested in how NGK SILZKBR8D8S (97506) go. They're OEM on N20 and Alpina B7. I find it interesting that Alpina chose to use these different spark plugs to the Bosch ones used in all other N63N engines.
Default 05-05-2016, 08:34 AM
Originally Posted by Levan-i
thanks for info!
Just not profitable to do. Sorry.
keyap keyap is offline
Car: N55 135i
Default 05-05-2016, 08:40 AM
+1 one for the BMS tool - works great. Also, if you need to compare heat ranges the guide below may help.
Name:  Spark Plug Heat Ranges.jpg
[B]
AZN54 AZN54 is offline
Car: N54 135i
Default 05-05-2016, 08:49 AM
Thanks of the write up! I went with NGK 95770 gapped to .019 (per Wedge) about a month ago; used the same feeler gauge. I've noticed a rough idle upon start. I'm assuming its more fuel system related, but any thoughts/ideas if it could be the gap? I'm on e60, no meth, 21psi max, no misfires.
2009 135i
DOC Race 6266 Single, VS DW400 LPFP, VRSF Race FMIC, Motiv BoostBox, Tuned by Wedge
Offering Arizona Walnut Blasting Service:
http://www.n54tech.com/forums/showthread.php?t=36741
Default 05-05-2016, 12:26 PM
I know a rule of thumb on spark plugs is usually every 100hp or so over stock, it is recommended to run a colder plug, but how do some people (myself included) able to run the oem plug and mid 500s?I have tried the ngk plug, gapped at 0.022, didn't have issues, just replaced them as they had 10k on them
2007 e90 335i
Hexon turbos
Trebila Custom tuning
bigdnno98's Avatar
bigdnno98 bigdnno98 is offline
Car: e92 335i
Default 05-05-2016, 12:35 PM
I have the same question as above. What is a better plug for a 400WHP car? (+130hp over stock). The 5992 or the stock Bosch? I love NGK plugs, just wasn't sure if I was making enough HP to go 1 step colder on this motor.
2011 335is DCT, FBO
cleancutx's Avatar
cleancutx cleancutx is offline
Car: 2007 E92 335i
Send a message via AIM to cleancutx
Default 05-05-2016, 01:26 PM
The biggest change for me was the life of the plugs... The NGKs last double, if not triple, the amount of time as the oem plugs. When I used oem plugs I literally had to replacement every 10K miles as stated, so cost wise going NGKs helped.
I did notice more cold start roughness, but after I purchased a torque wrench and torqued them down to spec, all that went away.
My 2cents
Cc_
2002 VW GTI 1.8T (missed)
2008 Mazda MazdaSpeed3 2.3T (missed)
2007 BMW E92 335i 3.0TT (current)
6MT | ACT | VTT | BMS | MMP | MHD | Active Autowerke | VRSF | ETS | TiAL | 'BigTom' | Fuel-It
Mike @ Outcast Garage's Avatar
Mike @ Outcast Garage Mike @ Outcast Garage is offline
Car: 2007 E92 335i
Default 05-05-2016, 09:40 PM
Hmm.. I'll give the NGK 93026 a try. Thanks for the thread!
Default 05-06-2016, 09:35 AM
Getting close to time to replace plugs on my car and would really love an answer to this.
N54 | Build Thread
konvikt21 konvikt21 is offline
Car: 2008 335i 6mt
Default 05-06-2016, 04:48 PM
for single turbo running up to ~25psi should I go closer to the .018? Just got a new set of 5992
Doc Race Single Turbo Kit PTE5862 - e93 6MT - ADE PI - Fuel-It Stage 2 Bucketless - JB4/MHD - MFactory 3.46 LSD - MFactory SMFW - Spec Stage 3+ Clutch
omarmarji's Avatar
Car: n54 335
Default 05-21-2016, 07:23 PM
awesome thread , just ordered a set of GTR plugs...will keep you guys posted, currently running ngk 5992
751WHP 688WTQ
JP Works Kit Record
SOLD: E90 335i 751whp 688WTQ
3000GT MR's Avatar
Car: 09' 335i
Default 05-22-2016, 05:40 PM
The idea is to get away with the largest gap possible before you get blow out. If you dont mind pulling plugs and gaping them a few times to see what works best then start with 0.022" and go smaller as necessary. I also wouldnt gap individual cylinders if only a few are blowing out.
I have close to 10K on the ones that are currently installed. I was going to pull them this weekend but didnt have time.
3000GT MR's Avatar
Car: 09' 335i
First post updated to add NGK 97506
