prelude2perfect's Avatar
Car: '07 335i
Default Manual 3.08 to Auto 3.46 differential swap - 08-03-2015, 09:53 AM
Did some searching and couldn't find a solid answer. I want to change my final drive from 3.08 to 3.46. I assume swapping the entire differential is the way to do this. What all is needed to swap? I have 03/07 build date manual transmission btw.
Also, can I only find one from a 335i or are there other models that will work like a 328i?
Best 1/4 ET: 11.4
Best 1.4 Trap: 127.7
Car: '07 335i
Default 08-03-2015, 11:06 PM
Really, nobody? Thought this was an easy answer
Best 1/4 ET: 11.4
GR1P's Avatar
GR1P GR1P is offline
Default 08-03-2015, 11:41 PM
All you need is a diff with the 3.46 gears.
2013 135is 6mt - FBO - Pure stg2 - 90/10 meth - Fuel-It stg2
Default 08-03-2015, 11:42 PM
I've read about it but never cared since our cars are auto's. IIRC, Terry looked in to doing just the opposite...not sure that he ever did though.
E90Convert E90Convert is offline
Car: 08 E90 335i
Default 08-04-2015, 05:46 AM
Find a junk yard automatic 335i and pull the rear end. Should be the same axle
E90 335i 6-Speed Manual
JB4 ISO G5 - BMS Pump flash - VRSF Inlets - VRSF FMIC - VRSF CP - HKS BOV - VRSF DP's - Dinan oil cooler - BMS OCC - H&R sways - Goodridge Stainless lines - ATE slotted rotors - Hawk HPS/R Pads - Apex Arc-8 17x9
Car: '07 335i
Default 08-04-2015, 05:58 AM
Only 335i's work or are there other E90's that work?
Best 1/4 ET: 11.4
Levan-i's Avatar
Levan-i Levan-i is offline
Car: 2007 BMW 335i E92
Default 08-04-2015, 06:08 AM
im not sure about different engines,
but i left 3.46 diff in my car after swaping to manual
do you have any specific question?
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 08-04-2015, 07:48 AM
I swapped the 3.46 into my 6MT. It is fine, just make sure you get a "large pumpkin" 3.46, as all 6MT use the large pumpkin.
Also, you will want to change the values for the "Gear Ratio Calculation" table in the DME. This table will be published to the public XDF's soon. I have the correct values now. With the stock values, it would report your gear incorrectly...which did not play nice w/ my upcoming load by gear
Levan-i's Avatar
Default 08-04-2015, 08:08 AM
WOW!!!! it sounds so interesting!!!!!
maybe finaly i find reason of my pt-can errors
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
Car: '07 335i
Default 08-04-2015, 09:54 AM
Thank you very much jyamona, that's the info I needed to know. I didn't know it had to remain a large pumpkin for the swap to work.
Best 1/4 ET: 11.4
Car: '07 335i
Default 08-04-2015, 10:09 AM
Anyone know what the E60 535i's 6mt come with?
Best 1/4 ET: 11.4
ucsbwsr's Avatar
ucsbwsr ucsbwsr is offline
Car: 535xi Wagon
Default 12-19-2015, 10:20 AM
I have been researching for my 6AT-6MT swap and dug this thread up while looking into the FD Ratios. Here is info from a 2008 E60 brochure which will answer your question.
For the record the E60 M5 is 3.62 because it doesn't have any cohones.
Personally I have the 3.46 in my xi wagon, which is fine but have been spending some time behind my buddies single turbo E90 with 3.08 and am a huge fan. It gets me thinking what the 2.93 would be like on a heavily modified N54, I have not heard of anyone running this.
Evan
N54 Powered M5 Wagon:
idratherbesurfing's Avatar
idratherbesurfing idratherbesurfing is offline
Car: 06 STI
Default 12-19-2015, 10:26 AM
What is the benifit of doing this? Mfactory is doing mine in a few days. I can change it before its too late if this is a good idea..
ucsbwsr's Avatar
Car: 535xi Wagon
Default 12-19-2015, 11:47 AM
Final Drive will change the ratio of engine input to wheel output. For example if you were running a taller 3.08 and went up to a shorter 3.46 your engine will be at higher rpms in the same gear.
This is my understanding... Shorter gearing can make seem faster as the engine has an easier time getting the power to the rear wheels, therefore appearing to be more powerful but it doesn't necessarily translate to the car actually being faster as a shorter gearing can make the tires break traction earlier than they otherwise would and shorter gearing will also mean you have to upshift sooner.
Just think about launching your car in 1st gear vs 2nd gear, 1st is shorter than 2nd, same concept applies to the Final Drive ratio in the Diff except it applies to all the gears you will shift through. Also, a taller FD ratio will allow the car to cruise on the highway at lower rpms and have a higher top speed.
You should consider the balance of engine power and type of power (hp vs tq) with your transmission gearing, and the cars intended use. If these are completely out of wack the car would drive in an unfavorable way. For example an E60 M5 (high hp, low tq) with a 2.93 would have a hard time getting off the time and a tuned N54 (gobs of tq) with a 3.64 would light the tires up all over the place. Assuming you are within in normal range it comes down to intended use and personal preference.
Evan
Car: 06 STI
Default 12-20-2015, 12:29 PM
Evan
wow ok well put...i will keep my diff 3.08 the same until i see furthers experiences with this!
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 12-20-2015, 04:26 PM
Throwing my opinion in here as well. Definitely stick with the 3.08. I have a 3.46 with a MFactory LSD in my car right now and will be switching to a 3.08 with MFactory LSD. Cruising at 80mph keeps me around 3200 rpm (pretty annoying for longer trips). Also at over 600whp the shorter gearing just causes A LOT more spinning even with good tires.
Levan-i's Avatar
Default 12-20-2015, 06:12 PM
^^ this
also had 3.46 LSD, MT, ST,
was definitely planning to change to 3.08
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
omarmarji's Avatar
Car: n54 335
Default 12-21-2015, 12:14 PM
Turbo engines love load so i would stick with the 3.08
751WHP 688WTQ
JP Works Kit Record
SOLD: E90 335i 751whp 688WTQ
johmei's Avatar
johmei johmei is offline
Default 02-04-2016, 04:01 AM
Depends what you are using the car for. I track (road course) and the 3.46 fits me better. I have more torque to the wheels faster with this setup and easier to modulate boost buildup out of corners with higher engine speed. Sure there will be some more shifting but that is part of racing.
Straight line racing will not benefit from the switch for sure. Get longer and maybe fewer gears in a AT for that stuff.
johmei's Avatar
Default 02-04-2016, 04:02 AM
What are the correct values after the swap? Might have missed you posting them..
nitemare's Avatar
nitemare nitemare is offline
Car: 2010 535i 2002 530i
Default 02-07-2016, 05:22 AM
Evan
Since you have an E60/E61 platform like I do and researched this do you know if an early build 335i large diff would bolt up to my 535i? I see the output flange size is the same ( I have a large diff) but curious about the driveshaft input. I'm thinking they would work if the large diff/pumpkins are the same overall dimensions.
I mainly want to do this for several reasons:
1. Going from 3.46 to 3.08 for more load and less shifting for 1/4 mile
2. Large bolted diff so no machining ring gear required
3. LSD life
MFactory MFactory is offline
Car: BMW E92 M3
Default 02-07-2016, 10:56 AM
535i AT is the small bolted diff.
RadarContact's Avatar
Car: 2010 E60/535i AT FBO+WMI
Default 05-23-2017, 03:24 PM
I know this thread is a little old, but not too bad...so I'm bringing it back to life, hopefully!
Bought a 3.46 AUTO diff from an '05 530i to swap INTO my Son's '05 530i MANUAL car (2.93 gears). The car has the M54 231HP motor w/6-sped manual tranny. I think the 3.46 will make that car really fun to drive!
This is the diff. Is this a large pumpkin? Will this fit/work without mods??
(I have more pics if needed)
Please, any help is greatly appreciated. We wanted to do this on this upcoming Saturday (May 27th 2017).
Thank you!
2010 535i M-Sport w/Sport AT/6-spd xHP Stage3, Alpine White w/Natural Leather, type-135 wheels w/spacers & Coilovers --- JB4 G5 ISO Trebila (Map-6/BEF) Custom Tune, Custom Meth Setup (link) , VRSF 3" free-flow D/Ps, MMPe DCIs, Wagner 1060 Stepped FMIC, VRSF Chargepipe/Tial BOV, BMS Oil Cooler Valve
defineste90 defineste90 is offline
Default 05-25-2017, 06:09 AM
yes its all the same diff i had VAC build my LSD with 3.46 gears for my manual car no issues bolts right in its just a different ring gear
Default 05-25-2017, 06:21 AM
Has anyone swapped the DCT or 335d gearing into a 6MT rear end? Wonder what that would be like with slightly longer gearing compared to the 3.08
N54 | Build Thread
