BIMMIN BIMMIN is offline
Car: 2009 335i AT
Default E92 n54 smokes when coming to a stop(but very weird) - 05-12-2019, 10:59 AM
It smoke only when not in sport mode. It's a automatic.
Rb external pcv, bms high side catch can as well.
Head was rebuilt 3k miles ago, 3k on oem style turbos.
Why would it only smoke outside of sport mode??
No smoke at wot, or cruising or when leaving from a stop. Only as the car comes to a stop and drops down to idle.
erichale's Avatar
erichale erichale is offline
Car: 335i coupe
Default 05-12-2019, 12:25 PM
Check for clogged turbo drain lines. Oil pooled in lines could be forced back into hot turbo upon deceleration.
07 335i AT/CUSTOM 6870 GEN2 ST/VAC ENGINE AND STAGE 3 HEAD/FABFACTORY INTAKE W/PI/1000HP AD FMIC/EOS BILLET FUEL SETUP/BL COILS/DUAL OIL COOLERS/RB EXTERNAL PCV/PD TRANY W COOLER/M3 FRONT N REAR SUSPENSION W/ROUGE BEARINGS/HOTCHKIS ADJUSTABLE END LINKS/ADUSTABLE REAR TOE ARMS AND CAMBER LINKS/EIBACH SWAYBARS/BC RACING BR COILOVERS AND CAMBER PLATES/AKG REAR SUBFRAME, DIFF, REAR SHOCK BUSHINGS/POWER FLEX BUSHINGS/WAVETRAC REAR DIFF WITH DEFIV BRACE AND VAC COVER/4IN EXHAUST
Car: 2009 335i AT
Default 05-12-2019, 01:15 PM
Thank you, I'll try that. But why does it not smoke in sport mode? I mean I can still smell the oil in exhaust but no visible smoke in sport mode
erichale's Avatar
Car: 335i coupe
Default 05-12-2019, 01:47 PM
I have no idea about sport mode. I just know i had the same problem and it was because of clogged drain lines.
Bushido1991 Bushido1991 is offline
Car: BMW 135I 2009
Default 05-12-2019, 07:49 PM
Something similar happened to me, changed turbos and my problem was still present, I changed the valve cover and it continued to smoke, and as a last hope I removed the head of the engine I gave it a brush, I changed the exhaust and valves and I no longer smoke ,
vanosman vanosman is offline
Car: E93/F10
Default 05-12-2019, 08:30 PM
my 951 had leak on seal of brake bias valve, dripped onto cup turbo, smell in vent, at breaking zones. Jk RECALLS because drip onto exhaust fires. I filmed some 07 Jeeps burn down while driving my TJ on 33s
Car: 2009 335i AT
Default 05-13-2019, 03:41 AM
Man I hope it is not anything to do with the head.. that would be depressing to take all that apart
