(#1626)
Default 04-12-2019, 06:56 AM
Originally Posted by Antec800
One question DO we enable this? bit3 - Raise "boost over stock" cap from 10psi to 20psi.
Usually for people running larger turbos. Not needed for stock turbos.
sc67065's Avatar
sc67065 sc67065 is offline
Car: n55
Default 04-12-2019, 05:01 PM
Is the carb legal jb4 able to be updated to new firmware?
Default 04-12-2019, 06:19 PM
No firmware updates are blocked out on the CARB models.
sc67065's Avatar
Car: n55
Default 04-12-2019, 08:03 PM
Which version is on the carb model and where can I find the all the map settings for carb jb4?
jbourne jbourne is offline
Car: F30 320i B48
Default 04-13-2019, 06:15 PM
Is there gonna be firmware 11 final / release /stable build? I want to update the firmware from v9..
Antec800 Antec800 is offline
Car: 340ix
Default 04-13-2019, 08:53 PM
V11 t4 is stable
BMW After BMW
Car: BMW M240i
Default 04-14-2019, 06:51 AM
Terry posted recently he was working on new f/w for b58. We just need to be patient.
Romanychev Romanychev is offline
Car: BMW 320 lci B48
Default 04-14-2019, 12:59 PM
Hello.
B48 (330).
What to set the value auto shift boost reduction to reduce overboost?
Log (280+, second run).
Car: 340ix
Default 04-16-2019, 03:51 PM
I’m running v11 t9 hex firmware on the jb4 with my bef flash. I want to keep the afr and boost gauge working can I use map 1?
Default 04-16-2019, 04:23 PM
Yes
Default 04-16-2019, 04:24 PM
Originally Posted by Romanychev
Hello.
B48 (330).
You're not over boosting on the shift here? The shift reduction is used when you have the EWG connector, and then a default value of 60, reduces WGDC during shifts, to prevent over boosting in the next gear.
Default 04-16-2019, 05:16 PM
EWG installed. Default value 0, set 60?
Default 04-18-2019, 12:01 PM
You can change it to 60, yes. It's not a setting that is generally relevant unless you're running a really aggressive boost profile and are over boosting post shift. Are you? If you are not then don't worry about it. If you are then post a log of that and I can help you refine the setting.
blue blue is offline
Rr
Car: 320i
Default 04-22-2019, 06:46 PM
Hi,terry.Is BMW_B48_B58_12_V3 firmware stable?Can I upgrade from BMW_B48_B58_OBDII_11_TEST4? Can the new firmware turn off dashboard scanning animation?
Default 04-23-2019, 07:20 AM
Use boost 20-22 psi.
update 12 version, tests.
Adaptations?
The car is inadequate.
B48
Version 12.
The first log is 6 map, target is null.
The second log - 3 map, 100% pedal - kick and sharp brake (after which I let go of the pedal).
Update: map1 - error (check engine), attachment.
tutuco's Avatar
tutuco tutuco is offline
Car: Audi A3
Default 04-23-2019, 09:25 AM
Hi all,
I'm highly considering to buy a new M140 2018.
With the car FBO and the JB4. How should I expect to have in whp?
Can someone share dino results?
Regards,
Tulio
Default 04-23-2019, 11:35 AM
Should be around 400whp on pump gas.
dRDiesel's Avatar
dRDiesel dRDiesel is offline
Car: BMW
Default 04-23-2019, 11:47 AM
Originally Posted by tutuco
Hi all,
Regards,
Tulio
I did 410whp/426 ft-lb STD with JB4 map 5, intake, and 5" catted down-pipe with 3 gallons of E85 mixed with 91 octane fuel.
tutuco's Avatar
Car: Audi A3
Default 04-23-2019, 01:22 PM
Thanks Terry! One more question. Can JB4 handle any bigger turbo in B58's?
tutuco's Avatar
Car: Audi A3
Default 04-23-2019, 01:23 PM
Thanks bro!
Default 04-23-2019, 02:07 PM
Yes of course, we can control whatever turbo you want to install.
e90roxs e90roxs is offline
Car: f30 b58
Default 05-01-2019, 02:35 PM
I have been using jb4 for over a year and today I'm getting these error codes. I did a search on the error codes and some of these are jb4 related. Please let me know what I can do to fix this issue.
121002 MAP sensor, short to ground
120408 Reduced power mode
12BD52 Lambda probe before catalytic converter, line error: interuption pump current line
118401 Mixture Control AFR too lean
My car has ******* **, Agency Power intake, exhuast system and jb4.
JBoe JBoe is offline
Car: M240i
Default 05-07-2019, 09:58 PM
If I activate WMI on all maps, will it use the additive set point or function as simple on/off according to window/rpm and boost activation set points? I'm considering using map 5 with WMI, but I'm not sure if additive amount is active in such an application. Please let me know... Thanks.
BMW After BMW
Car: BMW M240i
Default 05-08-2019, 07:31 AM
I have run Map 5 with WMI by setting Trigger mode to 1 and it felt pretty good. I think meth additive is only active on map 7, and Map 5 is a fixed +6 additive? The additional meth fueling helps that map though if your octane sucks.
Someone from BMS can confirm for sure but it does work.
Why are you considering switching to 5? You had such great results on 7...
Car: M240i
Default 05-08-2019, 01:59 PM
It's getting to 100+ again and DME starts wabbling. I never tried just Map 5 and WMI. When I did it the other day, the car was much better and consistent. I'm anxiously waiting for final BEF+JB4 maps to be worked out. I'll go that way as soon as they are. This is just an interim fix. Lol.
