(#276)
JBoe JBoe is offline
Car: M240i
Default 07-11-2019, 05:06 PM
Originally Posted by rf30a
Thanks for the feedback Terry. What level would you say is concerning on the fuel pressure? Under 15, under 12? Just trying to get an idea to help me when I am looking at logs.
I'd like to know this as well.
BMW After BMW
Car: BMW M240i
Default 07-11-2019, 08:09 PM
There is a post somewhere that says 1 = 150 so 7 and higher is probably needed. If you go lower than 7 there may be something to worry about. HTH.
Car: M240i
Default 07-11-2019, 09:29 PM
I had seen a few posts about it, but Terry was still dialing in the ratio. Also, I don't remember seeing a post where he provided minimal levels. Hopefully, he'll respond soon to clarify.
With all that's changed on our firmware versions, it's probably time to update the "Settings" thread's first posts. That's always been our go-to resource.
BMW After BMW
Car: BMW M240i
Default 07-12-2019, 08:42 AM
The info you seek is in here.
Adding JB4 v13 firmware to the first post to collect some data.
JB4 v13 firmware:
1) Added active safety system for high fuel pressure. JB4 will revert to safety is fuel pressure drops below 7 (1000psi) during full throttle.
2) Moved safety/VALET map to map8
3) Adjusted map4 to be a performance map between map3 and map5. With the BEF map4 targets around 20psi
4) Adjusted FF learning to be slightly more aggressive.
Implication to me is 7 is your "safe" minimum. I'm pretty sure 1 = 150 in terms of scaling as was posted in a post by Terry somewhere on this thread. Unless Terry changed it very recently, I log with MHD logger and they don't scale HPFP (reported in actual PSI); I have compared to JB4 at full idle (change logging collection method in JB4 app to "raw sampling" and log for 15 seconds), and the math worked out like that.
Car: M240i
Default 07-12-2019, 06:52 PM
Thanks for the info... I'm a bit confused now. A few posts back a member was told his fuel pressure was tanking, but it never dropped below 10-11. Thus, still safe.
BMW After BMW
Car: BMW M240i
Default 07-12-2019, 06:58 PM
I read that post:
Fuel pressure is tanking a bit here despite boost being under target, I'd drop back down to map3.
I think the implication here isnít that safety was being triggered, but rather that lowering pressure over time was a sign that the map was too aggressive?
rf30a rf30a is offline
Car: F30 328ix/C300 W205
Default 07-12-2019, 07:23 PM
I am going to try some boostane with an e25 or e30 mix to see if I can keep both timing and fuel pressure happy.
But Terry mentioned that my pressure was tanking when it dropped to 11 so would be good to get a better explanation. A more aggressive map would naturally have higher fuel demands but if trims, timing and fuel pressures are reasonable then it should be okay I would think.
Obviously we are all still in somewhat uncharted territory with the BEF.
BMW After BMW
Car: BMW M240i
Default 07-12-2019, 08:10 PM
Boostane won’t help with fuel pressure since it’s not fuel. It’s an additive which will help with timing since it raises octane. Fuel and octane are not the same thing.
Default 07-13-2019, 03:58 AM
I understand but running less ethanol will help with fuel pressures.
Car: M240i
Default 07-13-2019, 08:34 AM
Yes and to counter the octane decrease you can use an additive. I do that with straight 91 by using half a can of the Boostane 116 additive. I haven't seen any fuel pressure issues, but at 110+ degrees ambient air temps, my timing is gone. Lol. Car is fast but high IATs have the DME pulling timing so it's not like it was.
I'd still like a little insight on the fuel pressure side. It's a relatively new addition to our tuning paramaters. I feel I have a solid knowledge of the others.
Default 07-13-2019, 09:50 AM
Attached are map 4 and 5 logs with 93 octane base e30 and 8oz of boostane.
BMW After BMW
Car: BMW M240i
Default 07-13-2019, 09:57 AM
Here are four things you can do to fight the IAT battle:
1) use the stock intake
2) use the AP intake (it’s pricey)
3) if you’ve bought the MHD flasher license, flash and use performance (or track) cooling mode. It makes a noticeable difference in IAT, I’ve seen 10 degrees cooler.
4) inject more water in your meth mix. really depends on the trade offs you’re willing to deal with on this last one.
CntryClub007's Avatar
CntryClub007 CntryClub007 is offline
Car: F30 340i / E70 X5-35i
Default 07-14-2019, 12:25 AM
People with b58 and xdrive have done it...
Well...I pulled a 3.39 using M2 and not really trying very hard, haha.
B58 Powered 340i Goes 11.40's on Meth @ 2,000' DA - PLUS Custom AWE Exhaust - N54Tech.com - International Turbo Racing Discussion
| 2016 BMW 340i | M-Sport |
| CG Catted + AWE | BMS Intake | FTP Turbo Inlet + CP | JB4 + MHD BEF | XHP Stage 3 | BMS Meth Kit | VP M1
Eric97h Eric97h is offline
Car: Bmw 340i
Default 07-21-2019, 01:17 PM
Might just have not updated it's zero reference yet.
Hey terry have you heard of the new cpi fuel kit I wonder how it works and what maps and stuff to use once this releases ? Will the performance gains be similar to meth injection ?
B58 Charge Pipe Injection (CPI) Kit - FUEL-IT!
wxs0621 wxs0621 is offline
Car: 2018 340i
Default 07-21-2019, 05:15 PM
Hi, first time running meth with BEF and wanted to check if things looked good. Attached is a map7 log. B58, 93 octane, 50/50 and xHP stage 3. Thanks
Car: 2017 BMW 340i Xdrive
Default 07-21-2019, 05:47 PM
Looks pretty good. You using MHD bef? What map? Race+ meth or just race map?
Car: 2018 340i
Default 07-21-2019, 06:55 PM
Yes using MHD BEF. Map 7 and race map for now. Not sure when race+meth map would be appropriate as I saw earlier posts from people running meth and still sticking with just race map.
Default 07-21-2019, 08:07 PM
I was running mhd race + meth and running into fueling issues. Will try your set up. Thanks
JorgeIII JorgeIII is offline
Car: BMW F30 LCI 320i 2017
Default 07-24-2019, 10:28 AM
Are B58 BEF maps compatible with the 4 stroke B48? If no, any news on a map for this engine?
Default 07-24-2019, 10:57 AM
MHD doesn't support B48 yet but they are working on it I hear.
Antec800 Antec800 is offline
Car: 340ix
Default 07-27-2019, 12:23 AM
Any updates on updated bef tunes
jdbaldoc jdbaldoc is offline
Car: 2016 BMW 340ix
Default Question about graph showing 461.83 Max hp - 07-29-2019, 10:43 AM
In the graph on this page you show a graph with only using:
JB4_B58_MHD_E40_MAP3. You show a Max hp of 461.83 and Max TQ of 473.75.
Is this with the MHD flash and using a mixture of fuel to achieve E40?
Were these hp figures RWHP or at the crank?
Another question: I assume that because you are using MAP3 that this was accomplished without a WMI kit?
Thanks,
ravits ravits is offline
Car: X3M40i
Default 07-31-2019, 05:56 AM
Hi Terry,
Am driving x3m40i
Installed jb4 with Bluetooth kit
checking on the latest firmware which should I go for.
Car: M240i
Default 07-31-2019, 03:47 PM
First I'm seeing the V14? I do see it available in the main Firmware thread. No idea what changes were made. Terry will respond soon, for now V13_1 should be fine. That's what I'm on currently.
Default 07-31-2019, 05:53 PM
On v14 just some minor changes to the gauges bouncing in newer models.
