ehoons ehoons is offline
Car: E60 535xi
Default Boost dropped from 17psi to 15psi - 03-13-2019, 12:01 PM
Can someone take a look at this log?
I have been targeting around 17 psi all week, all of a sudden I can't make over 15 psi. No change in fuel or tune, no check engine lights, and it pulls smooth, just builds boost slower than usual.
Mods:
JB4/MHD BEF
Charge Pipe W/ Modded DVs
DCIs
OCC
5 gallons of e85, the rest 91 octane
Running On Map 5
In the past I've replaced all my vacuum lines except for the ones from the boost solenoid to the waste gate. That is where I am going to start. I just want to confirm there is nothing else obviously wrong. Any input is appreciated.
Default 03-13-2019, 01:20 PM
Mods:
JB4/MHD BEF
DCIs
OCC
Running On Map 5
I donít see anything glaring in the log. Tbh map 5 can be a bit finecky at times, your at or around 16.x psi for some of the pull, so I donít think you have a hardware issue.
If your so inclined- you can run map 7, see if you have the octane for it, or if you want 17 psi, map 6 is always an option too that we can help dial in.
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
