Treeko Treeko is offline
Car: BMW E82 135i N54
Default Log review N54 Map2 - 03-08-2019, 12:17 PM
Hello there, this is my first log on my new setup:
*****ted OEM *********
Wagner Evo3 FMIC
NGK 5992 Spark Plugs (0,6mm/0,023inch)
Upgraded Charge Pipe
Upgraded PCV Valve
Upgraded Oil Thermostat
K&N Air Filter
102 Octane
This is the only log i got because it was wet and the weather was **** but I hope someone can tell me if everything looks good or not and give me some advices. Thank u alot!
Default 03-08-2019, 02:55 PM
Wagner Evo3 FMIC
Upgraded PCV Valve
K&N Air Filter
102 Octane
You’ll want to update to the latest firmware
Are you using a BEF?
Based on this, boost looks okay, timing a few dips, nothing alarming.
Trims / AFR could use some work, the BEF should help.
Enable 6cyl timing as well, or at least check u have the right value selected
Default 03-09-2019, 12:23 AM
Hello Dave, thanks for your quick answer! It will take me some time until the BEF but i'll come back with some new logs
Default 03-09-2019, 09:36 AM
Sounds good.
Default 03-17-2019, 01:15 AM
Hello Dave,
here are some new logs after the MHD BEF
Default 03-17-2019, 07:43 AM
Hello Dave,
Overall these look pretty clean
Boost looks good, timing doesn’t look bad either
Your LPFP looks tired- in the 50s uptop- id upgrade. Trims taper a bit as well up top.
How’s the car feel?
Default 03-17-2019, 07:59 AM
To be honest it feels pretty powerful. Car feels good but i have a small issue. When i drive upwards with constant pedal postition it sounds like the rpm it going up and down all the time - but the rpm is constant. It just sounds restless. Spark plugs are new. Everything else works fine.
Default 03-17-2019, 08:02 AM
Oh yeah i forgot: Injectors are new too (around 2k miles)
