DaySleeper DaySleeper is offline
Car: 2001 and 2013 BMW M5
Default Full map 8 from 40-140mph - 11-04-2018, 08:22 PM
Here is a good clean ops check! How does it look?
Is there a way to know MPH? I see it listed the log but it is blank.
Why is the throttle all over the place with the traction control off?
Default 11-05-2018, 08:57 AM
When ECU psi comes and touched DME BT throttle will start to close a little to regulate boost as you can see you're just at target. Log is normal, looks pretty strong.
