bulletrs's Avatar
bulletrs bulletrs is offline
Car: M235i '15
Default M235i '15 N55 **,CP,MPE,JB4 - 10-30-2016, 03:38 AM
Hi Guys,
I have installed a **,CP,MPE & JB4 with FF,EWG,TMAP,MAP and i am running RON102 fuel. The car has u huge increase in performance in map2/map5 but max boost is around 14/15psi. I'm now looking into custom tuning with map6 to increase boost a little but i have trouble setting the right parameters and i do not know what boost is still safe.
Is there someone that can help me get some proper parameters for my setup so I can get a good starting point for my current configuration.
THanks!
Element's Avatar
Element Element is offline
Car: BMW 135i N54
Default 10-30-2016, 07:37 AM
Logs?
2016 F22 M240i | 8ZF
bulletrs's Avatar
Car: M235i '15
Default 10-30-2016, 11:03 AM
Attached four WOT logs, the 3rd WOT log is from 4th gear, the rest from 3th gear. I am currently on map 5 and i believe the car has breath for more performance
Default 10-30-2016, 08:01 PM
With a high I avg. boost won't increase. Timing doesn't look too bad so you could try another psi or so and see how it looks.
bulletrs's Avatar
Car: M235i '15
Default 10-30-2016, 11:17 PM
Can you explain a little bit more what you mean with "with a I avg. Boost won't increase", i know it is ignition average but i don't get this sentence.. And what i should change for "try another psi or so"? Can i still use map 5 for this or sould i run map 6 and add boost values? I'm sorry for the questions but i have trouble understanding, i have read a lot of things on the forum already so not everything is abacadabra...
2015 F22 M235i N55 EWG | M Performance | 18" VMR710 | Pure Stage 2 Turbo | Pure High Flow Inlet | XDI-35 HPFP | Fuel-It LPFP Stage 2 | Bootmod3 Cary Jordan Custom Tune | XHP Stage 1 Tune | GFB DV+ T9356 | N20 TMAP | NGK SILZKBR8D8S 0,5mm | Wagner DownP | Wagner EVO2 Performance Intercooler | VRSF Chargepipe | M Performance Exhaust | OS Giken Superlock
Default 10-31-2016, 09:35 PM
http://www.n54tech.com/forums/showthread.php?t=21269
To target custom boost targets you'll need to use map 6.
bulletrs's Avatar
Car: M235i '15
Default 11-01-2016, 07:17 AM
Attached two WOT logs with map 6 and attached picture of my settings? how does it look? Any advisable settings change?
Default 11-01-2016, 11:10 PM
Looks okay so far. I'd keep making small changes and see how the timing looks.
bulletrs's Avatar
Car: M235i '15
Default 11-02-2016, 11:35 AM
Yes I understand now, but why is the throttle so jumpy? I don't understand this.
Default 11-02-2016, 11:45 PM
Stock flash, pretty normal.
bulletrs's Avatar
Car: M235i '15
Default 11-04-2016, 12:44 PM
Anything i can do about the stock flash on f22 m235i? I have read about backend flash but this is only for n54? It would also be nice if the cold start could be disabled, what a sound 😂
bulletrs's Avatar
Car: M235i '15
Default 11-07-2016, 07:11 AM
Please have a look at attached logfile, i noticed my car underpowered sometimes at higher gear/rpm. It does not do this always but now I managed to log it. Please have a look... Only difference is that I have added the BMS intake. I am running RON102 fuel from ARAL germany this should be similar to octane 95 in the USA.
Anthony235's Avatar
Anthony235 Anthony235 is offline
Car: m235i
Default 11-07-2016, 10:15 AM
Your PWM seems really high. I have a similar boost curve for my map 6 settings and my PWM is about half yours, but I still hit my boost targets no problem.
You might have a boost leak some where. I say this because you have high PWM and are not hitting your targets.
I know the VRSF CP just came out so you must have recently installed it. I would check that for leaks first.
Default 11-07-2016, 11:42 PM
Set PID gain back to 10.
Map 6 targets look to be a bit too aggressive but it's hard to say for sure with that log.
FF need to learn up but is fairly high, so you may indeed have a boost leak
Try to get a good 3rd gear log without the RPM fluctuations.
For a flash, you can look in to the Bootmod3 option.
bulletrs's Avatar
Car: M235i '15
Default 11-08-2016, 12:38 AM
Thanks for the advise, i will try to make a better log today. It was rainy when doing the log. I'll check for boost leaks as i have not yet installed the vrsf charge pipe, it is still in the box
bulletrs's Avatar
Car: M235i '15
Default 11-08-2016, 03:29 AM
Attached three logs, first log is from 4th gear. It is currently 2 degrees celcius here in the netherlands, so getting grip is tough
I have kept PID on 12 and will set it on 10 later and make new logs if needed. PWM is indeed high, wasn't so high before (check previous logs), i did install the BMS Performance Intake after this... But maybe there is already a crack in the oem charge pipe, i don't know yet. Anyway, the oem charge pipe will probably be changed this week by the VRSF one.
bulletrs's Avatar
Car: M235i '15
Default 11-08-2016, 10:59 AM
Did some map 6 logs with pid on 10, still high pwm and avg ign is also increasing and high. I also found an error code in JB4: 102001 Air mass, plausibility -- Tuner code, ignore. I have the idea that all this is caused by installing the BMS Performance Intake, but maybe this is coincidence and my oem plastic charge pipe is leaking...
I also did two logs on map2 (with pid on 12), but boost is quite low on this map, almost as stock.
bulletrs's Avatar
Car: M235i '15
Default 11-08-2016, 12:34 PM
Did some logs on map5 and they look really good. Maybe the boost on map 6 i've set is just too high or needs some finetuning? Map 5 tops at 15+ boost which is only 2psi lower what i've set on map6...
Default 11-08-2016, 08:34 PM
That's a lot of logs...do you have one or two in particular you want us to review?
bulletrs's Avatar
Car: M235i '15
Default 11-09-2016, 01:12 AM
Haha, yes i did some Anyway, attached two logs, one of map6 which doesn't look good and one on map5 which looks good to me.
Also I have an error code in JB4 after installing BMW Performance Intake: B4: 102001 Air mass, plausibility -- Tuner code, ignore. Why is that.
I would still like to use map6, it was ok with the values i use but not anymore... any suggestions on that?
Default 11-09-2016, 08:47 PM
As the code says..."ignore"
Map 1 looks fine.
Map 5 looks okay as well, I see you are running the EWG board but are you running the EWG wires? FF is set at 150, you'll need to set that back to default.
bulletrs's Avatar
Car: M235i '15
Default 11-10-2016, 08:57 AM
Yes i'm running EWG wires, i have never set FF to 150, i checked it on my side and it is now on 63, this is strange. Anyway I have set it to default 60 again. I'll drive for a while now and see how it behaves. Tomorrow i'm going to install the vrsf charge pipe.
Anthony235's Avatar
Car: m235i
Default 11-10-2016, 09:51 AM
FF will change on it's own depending on conditions. The safe bet is to change it to default when changing to different maps. I don't, but I have a pretty good idea how my car reacts to different maps/fuels now.
bulletrs's Avatar
Car: M235i '15
Default 11-13-2016, 11:55 AM
chargeipe installed now, i haved added 15% ethanol to my ron95 fuel runnin map5 now. logs look good, avg ign of 3, pwm is low and max psi of approx 14. i have sent you a pm anthony235 hoping to share some of your map6 settings.
bulletrs's Avatar
Car: M235i '15
Default 11-20-2016, 01:09 PM
Attached two new logs on RON102 (AKI95) with 10% ethanol on custom map 6... How does it look? I think it looks good but avg ign is quite high?
