Nicky92's Avatar
Nicky92 Nicky92 is offline
Car: 2008 335i
Default newly installed PI map 6 and 7 logs - 07-04-2016, 06:41 PM
Finally got around to loading the file on the R4 software to my AIC.
Did a few logs tonight.
Got one where it defaulted me to map 4 with a boost over safety trigger.
2016-07-04 20_32_29.csv
was the longest one on map 6. It was 3rd gear, didn't feel as quick as it should, plus boost fell off rather quickly.
I got a map 4 one that one is
2016-07-04 20_30_25.csv
Then I switched to map 7 and did a couple more logs.
3rd to 4th log
2016-07-04 20_34_58
335- stock
Default 07-04-2016, 06:45 PM
You need to enable WG adaption as FF is set too high causing over boosting.
Are you running the _PI back end flash map? Fuel scalars look off too.
Nicky92's Avatar
Car: 2008 335i
Default 07-04-2016, 06:51 PM
Yes I am, just loaded it off the thread on this forum.
335- stock
Nicky92's Avatar
Car: 2008 335i
Default 07-05-2016, 06:15 AM
Wonder if it has anything to do with meth.
I'm most likely removing it ASAP.
335- stock
Default 07-05-2016, 05:06 PM
Meth is not recommended with PI as it can definitely complicate the tuning process. If you are running high ethanol concentrations, you don't need it.
Nicky92's Avatar
Car: 2008 335i
Default 07-11-2016, 05:02 PM
How do I turn the meth off?
Will remove the kit this weekend, but I am going to take more logs this week.
335- stock
Default 07-12-2016, 09:05 AM
Pull the fuse to the FSB
