Cubanoo's Avatar
Cubanoo Cubanoo is offline
Car: Bmw m2 f87
Default 08-06-2016, 03:56 PM
HPFP is about maxed.
If you decide you want to upgrade the LPFP and run PIO, let us know and we'll hook you up. We have a couple of our new PI systems running on M2's but nothing on the X yet to my knowledge. Same motor but obviously a different platform.
What system I can use in my m2?
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 08-07-2016, 07:02 PM
you can get the fuel-it stage 2 lpfp for the F series n55 & the F series n55 port injection kit.
Mods: Stock for now
Default 08-08-2016, 06:47 AM
This is correct. You can install our F-series Stage 2 LPFP upgrade and we have a new port injection kit that we developed for the S55 that is also compatible with the N54 and N55. There are a couple M2's running it as well, including this one...
LycanX4M40i LycanX4M40i is offline
Registered Users
Car: 14' F25 X3 xDrive28 M-Sport AlpineWhite DHP
Default 08-12-2016, 02:21 PM
Attachment 52514
Nice!!
**Updated first post*** with Map4 logs from 3 different days on these hot humid summer days For anyone curious to see stock logs on a X4 M40i
Cheers
Cubanoo's Avatar
Car: Bmw m2 f87
Default 08-17-2016, 08:46 AM
Attachment 52514
In your web side is the f series n55 pi or s55 the pi I need?
Default 08-17-2016, 11:01 AM
You are an F-series, but send us an email at info@fuel-it.com
We have a couple M2's running our port injection kit but they run the newer one (s55) so I want to make sure you get the correct kit for your car.
Registered Users
Default 08-21-2016, 12:21 AM
bump anyone with M2 post stock and map1 and map2 logs to compare
Registered Users
Default 08-21-2016, 05:02 PM
Some intensive WOT logs with e30 blend
map1, map2 and map7
These logs wouldnt upload due to size (guess doesnt like long logs)
- http://www.***********/u/fsociety/e27...10-14-15-18-23
- http://www.***********/u/fsociety/e27...10-12-15-19-23
- http://www.***********/u/fsociety/e27...-6-10-12-23-18
Adding ewg-add on connector tomorrow and will be upping to e40
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default 08-21-2016, 05:26 PM
WHOA!! Hold your horses. If the HPFP is maxed, adding more ethanol is going to cause it to crash. Until you add the better LPFP or PIO, I would not add more ethanol. In fact, I would dial it back.
Mike Levy
2017 X3 xDrive35i
2018 Equinox LT 2.0T
Lowon's Avatar
Car: Bmw M2
Default 08-21-2016, 08:37 PM
Some intensive WOT logs with e27 blend
map1, map2 and map7
Logs on Map 1 & 2 look good.
map 7 is really borderline risky because it looks like the HPFP is maxed out,
in some parts of the power band the HPFP is getting really really low, at times as low as 10 which really means imminent misfires and the HPFP is maxed. Like mike said I really dont think you should up the ethanol content because your HPFP cannot handle it, you should think about getting supplemental fuelling like PI or TBI, and maybe meth. otherwise you'll need to go to a less agressive map.
Mods: Stock for now
Registered Users
Default 08-22-2016, 05:31 AM
LMAO trust me its fine, Steve was just suggesting not to max it out.
My 435 ewg friend runs E36 all day long (5.4 gal e85 + 10.4 93) =D and i havent even hit e35 in this round, i was on e30
Thank you I looked at all my logs, Map7 did hit once 10 for split second, 11 and 12. But it still stood above 13+ across the board. It may or not be maxing out but due to not having EWG-add on right now could also be?
also remember car only has bms intake + jb4 obd2 w/ FF wires
Waiting to see what Terry and other guys say too.
Once you get your M2 should be interesting to see its potential as well.
Remember we're running higher boost than standard N55 so things can be a little different.
Def not getting PI or TBI not in my agenda going to use what my stock fuel system can do. I was thinking about Stg2 fuel pump but no point since its only the Low Fuel pressure upgrade is availalbe and the High is the weaker point.
Element's Avatar
Element Element is offline
Car: BMW 135i N54
Default 08-22-2016, 06:16 AM
Increasing boost or rather holding higher boost towards redline (which is what the EWG patch is essentially for) and simultaneously upping your ethanol concentration when you're on the borderline will likely see your fueling crash (judging by your current logs), however you are of course free to test this for yourself
As for running higher boost than the standard N55, you may be doing so when stock, but your upper limit on both boost and fueling is the same as any other recent F-series N55 motor.
2016 F22 M240i | 8ZF
Anthony235's Avatar
Anthony235 Anthony235 is offline
Car: m235i
Default 08-22-2016, 08:34 AM
I have to disagree from personally logging a m2 over the last few days. If the X4 really does have the same setup as the m2 then he has more headroom when it comes to fuel than a normal f-series N55 (like my m235i).
I'm not sure what the difference is between the m2 and 235 in regards to fuel, but there has to be a difference. My buddies m2 hits way more boost than I do and over a bigger rpm range. He was seeing 17psi to redline on map 1 with 99oct. His trims and FPH were much better than mine.
Basically his map 1 is like my map7, but he holds more boost to redline than I do. Perhaps because the turbos are different...?
I will say we were running slighly differerent fuel mixtures though. He was 91oct with VP racing booster to 99oct.
I was e25 mixed with 99oct (with booster). So I should have less headroom than him.
Having said that though, and from my what I saw in his logs, the m2 is doing something different in regards to fuel management. RealOEM says the FPH and FPL pumps are the same. Also same fuel rail and injectors. So I think it might be different DME settings. I can't imagine BMW would up the power and boost on the m2 without doing something with the fuel to keep it in OEM safety margins. Maybe it's just the factory timing is handled differently...?
Lowon's Avatar
Car: Bmw M2
Default 08-22-2016, 09:28 AM
Also if you exceed 21 psi don't you have to change map sensors to a 3.5 bar? I'm not sure if the m2 and x4m40i have different sensor set ups or not.
Mods: Stock for now
Element's Avatar
Car: BMW 135i N54
Default 08-22-2016, 10:06 AM
Haven't said that though, and from my what I saw in his logs, the m2 is doing something different in regards to fuel management. RealOEM says the FPH and FPL pumps are the same. Also same fuel rail and injectors. So I think it might be different DME settings. I can't imagine BMW would up the power and boost on the m2 without doing something with the fuel to keep it in OEM safety margins. Maybe it's just the factory timing is handled differently...?
Fair enough. I've yet to see anything solid log wise from an M2 that I can use as a basis of comparison, but as you mentioned the pumps on the low and high side are identical (as is the turbo by anyone's account so far) so any differences would have to be down to what the DME has been programmed to do. At the very least the target timing advance seems to be different compared to non-M N55's.
The logs above however leave me unconvinced. That said, I'm not saying that he shouldn't try push the boundaries, but if it were me I'd install the EWG connector first to see what the additional boost brings before revisiting the ethanol concentration (or visa versa).
Anthony235's Avatar
Car: m235i
Default 08-22-2016, 10:20 AM
Agreed.
I need my buddy to send me a copy of his logs so I can get them up on my monitor. I think it's the timing targets.
Also if I recall correctly his AFR target at redline was richer than most N55s I've seen.
I will also say that even though he was running more boost then me (especially at redline) that he was not faster than me during our multiple pulls (40-130mph). We were literally perfectly even.
m2:
BMS intake
Turbo back exhaust (no *****)
JB4
m235i
BMS intake
no *****
JB4
IC
Registered Users
Default 08-22-2016, 10:27 AM
Judging my current logs? Only Map7 I did see 10-12 for less thank split second, still nothing as bad as hitting 10-11 for long period of time. If I may have missed it please point it out since just trying to understand and appreciate your time for looking.
I agree there may be a upper limit, but seeing from my posted Dyno w/o EWG-add on and no *** there power gain is more than standard N55. For ex, Dahler European Company has a tune for X3/X4 35i at 360-380HP & 480-550 Nm torque increase Max. For X4 M40i its 400-420HP & 570-590 Nm torque and according to them the M40i is still being in development with more room for torque.
Exactly, thank you
My Boost Safety is currently at 20 and it seems map1 or 2 hits 20.5 pretty often, I just increased Boost Safety to 21 in some other logs lets see. Some people are on 23 with standard N55 go figure.
Anthony235's Avatar
Car: m235i
Default 08-22-2016, 10:35 AM
I just don't think your turbo has much more to give over map1 from what I've seen.
You might be able to get more boost out of it, but there is no ROI in doing so. On the m2 we tried map2 which had more boost, but it didn't seem to benefit from it.
Registered Users
Default 08-22-2016, 10:50 AM
Yep I agree thats what I'm thinking so, I have some Dyno's on the first page btw which shows exactly what you're saying in some way.
On my dyno's and roll-races I noticed Map2 adds some more torque def but WHP its about the same in my current setup (stock everything).
Should be getting EWG this week before I touch *** or backend flash
Registered Users
Default 08-31-2016, 06:36 PM
Added EWG add-on on friday , I had about 12 gal of 93 added 4.5 gal of e85 on top before driving 50 miles to the drag-strip. and tested Map5 for 50 miles (drive) then at the drag-strip, ran map2 mostly after and then hit 1 or 2 runs with map7.
Today did 2 driving map4 logs, wouldnt upload due to size restriction so added them to ***********
http://***********/u/fsociety/map4-ew...-9-10-11-14-19
http://***********/u/fsociety/map4-ew...hg=2-4-10-15-1
Something interested I've noticed now after adding EWG-add on im noticing im able to log map4 doing more boost than my first few map4 logs w/o EWG control.
Hopefully with all these logs at dyno and drag we can understand this beast more.
Default 08-31-2016, 08:04 PM
I don't see why it would be over target on map4 with the EWG connector installed. I'd just remove the EWG connector, doesn't look like its doing much for your situation, anyway.
Registered Users
Default 09-05-2016, 04:41 PM
Very weird
Some more recent Map5 logs , FF learning down
Default 09-06-2016, 10:28 AM
Already responded to emails...
Registered Users
Default 09-09-2016, 08:55 PM
Yep car is fine its an Overboost in the higher rpms from factory unfortunately only a backend is going to fix this and the JB4 throttle closures.
