LycanX4M40i LycanX4M40i is offline
Registered Users
Car: 14' F25 X3 xDrive28 M-Sport AlpineWhite DHP
Default X4 M40i - JB4 Testing - Logs + Dyno - 06-27-2016, 08:14 PM
Started this thread to share with everyone Dynos/Logs/ results of a Stock X4 M40i (Similar M2 engine) and after JB4 Testings Stages (BoostSafety 18, 20), 93 pump, E30 blend and before/after EWG wires.
I've been sharing some logs for the past month or 2, drag strip and dyno with Terry.. But thought I share publicly now..
Car: 16' X4 M40i
Mod: JB4 OBD2 Map1 (no EWG wires)
New Log with BoostSafety at 20
First log I let it auto shift, second log I manually shifted at 6k rpm
I'll post more stuff later going to start posting more for feedback..
Weather today was 80F
8/10 = Map4 log on 93
Couldn't upload 8/9 and 8/11 logs due to a size restrictions so uploaded it here..
http://www.***********/u/fsociety/aug...hg=2-4-6-10-12
http://www.***********/u/fsociety/aug...=1-2-4-6-10-12
Registered Users
Default Dyno - Logs - 06-27-2016, 08:29 PM
3 here are Map1 and Map4
Map2 logs here are too big so had to upload it on dropbox
https://www.dropbox.com/s/5rq3fx3ksp...no%29.csv?dl=0
https://www.dropbox.com/s/iaz3d0y3vk...20%29.csv?dl=0
JB4 was switched to map0 before the dyno then map3 to lower the avg_ign then it was switched to map2
BoostSafety was set to 18 ; will go back to Dyno with BoostSafety at 20
Default 06-28-2016, 02:04 PM
I see you are triggering a false alarm map4 fail-over, so raise that safety setting to say 20psi as a first move.
Registered Users
Default 06-28-2016, 02:50 PM
Yep that was when the settings were at 18 and I questioned via email on raising it to 20
You're referring to the 5-21 logs correct?
Will re-dyno soon...
Registered Users
Default 06-28-2016, 08:29 PM
Drag-Strip Logs from June 1st w/ BoostSafety at 20
Registered Users
Default 07-05-2016, 09:15 PM
E30 blend logs today
90F weather
Map2
Map1
Map4
Pulls
Cubanoo's Avatar
Cubanoo Cubanoo is offline
Car: Bmw m2 f87
Default 07-06-2016, 12:17 PM
In the m2 I have to move the safety boost to 20 psi?
Registered Users
Default 07-31-2016, 12:02 AM
Dyno Day Logs & Dyno Graph
92-94F temp 30% humidity, weather sucks but if numbers look ok in this weather should be much better in cooler weather.
4.7 gal of e85 + 14 gal of 93 = e30 blend
JB4 OBD2 version Flex Fuel Wires no ewg wires
5th gear runs then 4th gear runs
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 07-31-2016, 12:16 AM
Nice!
Yo I've spoken to Vinny before about buying an Ej257 built long block way back when I was new to subies, but found a really great shop in my neighborhood.
Mods: Stock for now
Default 07-31-2016, 06:23 PM
Looks to me like map 7 is a little sku'd due to an inconsistent pull. Look at the RPM fluctuation when you should have been making peak power.
Registered Users
Default 08-01-2016, 02:08 PM
Yes I don't know what went wrong either, maybe car was slipping on Dyno ?
Default 08-01-2016, 05:57 PM
Certainly possible. DCT?
Registered Users
Default 08-02-2016, 07:32 AM
I wish DCT, has 8 speed AT
Map7 pull was on 5th gear , later runs were on 4th gear don't know why Dyno operator did it in 4th gear.
Default 08-02-2016, 08:29 AM
It was probably a slip on the dyno then. If so, easy enough to correct.
Registered Users
Default 08-02-2016, 08:42 AM
Maybe also because I don't have EWG wires ?
Probably a custom map6 will dyno and run better w/ backend flash
Default 08-02-2016, 10:51 AM
I don't think so, that'll limit boost...not traction.
Why aren't you running EWG wires?
Registered Users
Default 08-02-2016, 02:13 PM
EWG wires coming soon, wanted to get an idea of what I could do before.
Planning to do backend flash + ewg wires in the upcoming weeks after I hit drag-strip.
Going to hit drag-strip tomorrow, but crappy one on wednesday only allows 3 runs per car. So will prob do map7 first run, map2 2nd run and map1 last run.
And log of course
Default 08-02-2016, 05:55 PM
Registered Users
Default 08-03-2016, 11:16 AM
Any tips on FOL ? Leave it at 60 or increase to 70 ?
I saw in my e30 map4 my FP_H was at 11, meaning if it hits 10 no good right?
Default 08-04-2016, 11:04 AM
FOL won't help your HPFP, only your trims. Correct, once you see it dipping in to the 10's you're likely to get misfires.
Registered Users
Default 08-04-2016, 01:07 PM
Stage2 Fuel-Pump wont be any benefit for me since the weak point is HPFP correct ?
I ran twice last night (too crowded) had prob about e20 blend 1/4 tank, first run map2 about 1hr 1/2 or 2 hr later second run in map7 (manually shifting). Both time still only managed 13.1@104 but i run 13.1@103 on 93.
I'm sure the 70-75F with the insane humidity was the factor, gotta get these ewg wires in asap.
Logs attached
rwalker rwalker is offline
Default 08-05-2016, 10:54 AM
Once you're at the limit of the HPFP, you have 2 choices:
1. lower boost a bit and enjoy the car as is, you're done
2. get supplemental fueling (TBI or PI) and keep cranking up the octane and boost
TBI and PI require a bigger LPFP.
rwalker@rwalker.com (I really dislike private messaging)
Default 08-05-2016, 11:45 AM
HPFP is about maxed.
If you decide you want to upgrade the LPFP and run PIO, let us know and we'll hook you up. We have a couple of our new PI systems running on M2's but nothing on the X yet to my knowledge. Same motor but obviously a different platform.
Anthony235's Avatar
Anthony235 Anthony235 is offline
Car: m235i
Default 08-05-2016, 02:56 PM
3. Run less ethanol. Which will probably mean less boost depending on your current boost targets. See #1 lol
Registered Users
Default 08-05-2016, 04:22 PM
When you say HPFP is about maxed ?
I looked at all my logs and my FP_H is always above 11 on WOT even on map2/map7
