bloked97one bloked97one is offline
Car: 335i n55 2011
Default 07-06-2016, 05:01 PM
Well.
All is ok.
Can you tell what's the problem.
The map 4 it's ok ? .
I must change the value
FF
Pid gain
Fuel open loop ect....
Default 07-08-2016, 07:36 AM
Looks okay to me. I'd suggest putting your user adjustments back to default and try another log.
Car: 335i n55 2011
Default 07-08-2016, 08:04 AM
Ok I test
Car: 335i n55 2011
Default 07-08-2016, 09:50 AM
these settings are good for the ISO mode ?
Car: 335i n55 2011
Default 07-09-2016, 05:56 AM
Hi Steve.
I have put the parameters in the table but when I rolls and I control after FF/ wastegate value goes to 74.
And Last safety 2.
what should I do?
Car: 335i n55 2011
Default 07-09-2016, 11:25 AM
Hi steve
Are you here
Default 07-10-2016, 08:54 PM
No log...no bueno. FF is dynamic and will adjust as needed.
Car: 335i n55 2011
Default 07-11-2016, 10:47 AM
Ok I do map 4 and 2
Car: 335i n55 2011
Default LOGS - 07-12-2016, 04:42 AM
hi .
Default 07-12-2016, 09:13 AM
Is the diode cut on your JB4?
Car: 335i n55 2011
Default 07-12-2016, 11:13 AM
Yes
Car: 335i n55 2011
Default 07-12-2016, 04:24 PM
Do you have a solution
Default 07-13-2016, 06:05 AM
In the last two logs you posted, I don't see an issue other than FF needing to learn down a little. Try setting it to 60.
Car: 335i n55 2011
Default 07-13-2016, 09:49 AM
Ok
I test
Merci
Car: 335i n55 2011
Default User ajustment - 07-14-2016, 06:54 AM
Hi
what do you think.
Default 07-14-2016, 04:10 PM
About what?
Car: 335i n55 2011
Default 07-15-2016, 05:53 AM
I have a tuner that made me a map 6 I don't have cuts in third but I have the code 36C9 that appears when I'm 155 miles in 6th.
Default 07-16-2016, 11:59 AM
Speed limiter...
Car: 335i n55 2011
Default 07-16-2016, 02:59 PM
Not since before installation I have already reached the 161 milles. And no problem
Car: 335i n55 2011
Default 07-17-2016, 11:05 AM
hi steve.
its going to be 1 year and nobody comes to help me .
tell me help me .
Car: 335i n55 2011
Default My ordering bms - 07-17-2016, 02:02 PM
No diode
Merci
Car: 335i n55 2011
Default 07-18-2016, 03:21 AM
Hi.
a What is the future use A?
Default 07-18-2016, 09:18 PM
You don't need to use future use A
Car: 335i n55 2011
Default 07-19-2016, 06:00 AM
Ok.
Car: 335i n55 2011
Default 07-19-2016, 06:02 AM
Have you found a solution to my problem ?
