Go Back   N54Tech.com - International Turbo Racing Discussion > Non-Engine Related > General Tech Support, Tuning Advice, Logs, and Help Me Posts
Reload this Page Trims & both bank AFRs oscillating +car jerking while highway cruising w/steady pedal
seroga1986's Avatar
seroga1986 seroga1986 is offline
Default Trims & both bank AFRs oscillating +car jerking while highway cruising w/steady pedal - 05-23-2016, 05:38 PM
Just like the title says. Trims and AFRs oscillate while highway driving with a steady pedal. Only happens once in a while as you can see in the logs. Have not changed any settings for a long time. Just started happening recently. Logs posted. Any help appreciated.
2008 135i Sport 6at
JB4 G5 ISO, MHD E85 KR, Fuel-it S1, E55 Mix, Alpina Trans Flash, afe Scoops, My own custom 2.5" inlets, ER CP, Synapse BOV, 3.5 Tmap, 7.5" Phoenix FMIC, NGK 5992, 3" BMS downtubes, N55 Mids, Berk Race, BMS OCC, 48 plate oil cooler, 36 plate trans fluid cooler, PSS, R888, Hoosier DRs.
11.92@123.6 (JB4 ISO, DCI, IC, **, DR, on e45 & 17psi)(2013)
444whp/481wtq @19psi and e60 (2013)
2013 X3 xDrive28i M-package
JB4, K&N drop-in, ER downtube, Map 2 @ 22psi on 93
chatz86's Avatar
chatz86 chatz86 is offline
Car: 08 E92 335i N54
Default 05-23-2016, 08:00 PM
Curious to see what advice you receive. I still have this issue intermittently.
2008 e92 335i M-Sport|JB4 G5|MHD BMS BEF|BMS DCI|VRSF **|Alpina 7603537|BMS OCC|RB PCV|Stage 2 LPFP|Fuel It! ES-1 fuel lines with Ethanol Sensor and JB4 analyser|MMP Silicone Inlets|4 Bar TMAP|VRSF 7" FMIC
Default 05-23-2016, 08:55 PM
It's from having the wastegate so closed during cruise. Lower DWP (menu10 in dash) as needed.
seroga1986's Avatar
Default 05-29-2016, 11:56 PM
Terry i have tried DWP at 0, 10, 20 and so on. Problem is still there. Cleaned MAP sensor. Checked all connections for boost leaks. Weird because car sounds very different now at 80 DWP than it used to. Maybe boost solenoid going bad? Anyway to tell from that log? I had the solenoid resistors on the jb4 board replaced by you last year. But last year i lost boost completely when the resistor failed. This time the car builds boost but just sounds very different and not smooth at all.
2008 135i Sport 6at
K.Jameel K.Jameel is offline
Car: BMW E92 N54
Default 05-30-2016, 03:51 AM
Same issue in the below thread
http://www.n54tech.com/forums/showth...252#post473252
BMW 335i '08 E92 N54, JB4 G5 IOS, BMS DCI, VRSF ***, BMS-Tial BOV Kit with Chargepipe, VRSF FMIC, BMS Meth Kit, JB4 MHD BEF, BMS PCV valve, BMS OCC. TCU Alpina_B3 Flash, .
seroga1986's Avatar
Default 06-04-2016, 10:11 PM
Still have not resolved this issue. Lowering DWP does not help. Map0 or in any map problem is still there. Tried several different flashes - nothing. Here is another log from today. Any help is appreciated.
2008 135i Sport 6at
chatz86's Avatar
Default 06-05-2016, 02:42 AM
I found lowering menu 10 appeared to help but mine still does it too
seroga1986's Avatar
Default 06-05-2016, 07:52 AM
No menu 10 does not help. Disconnecting jb4 doesnt help too. Some sensor is on its way out.
2008 135i Sport 6at
chatz86's Avatar
Default 06-05-2016, 02:23 PM
Let me know if you figure out which one it is
Car: BMW E92 N54
Default 06-07-2016, 10:07 AM
I read in other forum that solution founded out, was a full DME firmware update,
Modules updated were ECU, TCU & CAS.
Hope that help but i did not do it sofar. If you did the update please keep me informed.
Thanks.
Default 06-07-2016, 06:05 PM
Could also be a faulty TMAP sensor, ground issue, etc.
cebrailbakan's Avatar
Car: BMW E90 335XI
Default 06-07-2016, 06:54 PM
Set menu 11= 3.5k please. Then let us know if it is still there
Do more with less !
seroga1986's Avatar
Default 06-08-2016, 07:00 AM
Yes i have tried playing with menu 10, 11, and 12. It does not help. I have put the stock tmap in with no change. Its so annoying.
2008 135i Sport 6at
Car: BMW E92 N54
Default 06-08-2016, 05:06 PM
Thanks.
I put the stock tmap no change
I have tried 11=3.5k and 0.5k also no change.
Now i'm thinking it could be from the pedal, tomorrow i will try clever move to use the cruise control other step i will remove the JB4 and flash back to stock.
What make me crazy that WOT and idle it's fine, when press the pedal with no gear engaged the rpm swinging and hard to keep it steady and sound of banging only @rpm 1600-1800 were the oscillating occur.
seroga1986's Avatar
Default 06-08-2016, 07:33 PM
Cruise control on or off the problem is still there. So that rules out the pedal itself?
Also i dont know if this is normal but i have the same thing where lets say i keep pedal at 10% idling in P and the RPMs fluctuate 1500-1800 or so.
2008 135i Sport 6at
mattf80 mattf80 is offline
Car: 08 335i 2/6
Default 06-09-2016, 10:34 PM
exact same issue here with no solution. I've been emailing Terry back and forth for weeks now with no solution. It just started out of nowhere and no setting fixes it. I've checked extensively for vacuum leaks and couldn't find one. Swapped throttle bodies with a friend no change. Messed with all menus. Cleaned and swapped vanos solenoids, tmap, tried stock charge pipe still no change.
seroga1986's Avatar
Default 06-10-2016, 05:45 AM
I have also done all of those things minus throttle body and CP. If you find a solution please please let me know. Thanks.
2008 135i Sport 6at
Car: BMW E92 N54
Default 06-14-2016, 06:08 AM
Ok now hesitation and oscillation had increased, i made small test i kept my foot on pedal so i can have a steady RPM but i can't between 1400 - 1700 i decided to take the vacuum line off from the part connected to the HPFP and the hesitation and oscillation is there with noticeable smoke (clouds) i think due to bad turbo. but could they cause such symptoms. i have "2C7B Lambda probe behind catalytic converter 2, signal" code but only every while.
does anyone else have same smoke. logs attached to see how bad the RPM fluctuating.
MSick174 MSick174 is offline
Car: 2009 BMW 135i 6AT
Default 06-14-2016, 08:54 PM
I had a thread here before a month complaining about the same drivabilty issue. It happened suddenly. Terry suggested to try change menu 12 to lower value based on my duty bias. It solved the problem momenterly.
But it's happening again. No matter what I do and which map it will drive the same. I tried map 0 and cruise control. The same problem presist.
I hate driving the car these days because of this issue. I hope the root cause will be found soon.
BTW I have 3.5bar TMAP.
Default 06-14-2016, 09:00 PM
This looks like the classic menu10 set too high for the driving style case. What happens with DWP=0? Do the same log like that. And based on that I have a few ideas on things we can try with the firmware.
Car: 08 335i 2/6
Default 06-14-2016, 10:57 PM
Terry whatever change you made in 32_5 seems to have helped tremendously the issue is still there but much less noticeable and only at a narrower pedal position it seems. Very hard to replicate now.
seroga1986's Avatar
Default 06-15-2016, 02:57 AM
For me, 32_5 didnt change anything. Maybe even made it worse.
2008 135i Sport 6at
seroga1986's Avatar
Default 06-15-2016, 02:58 AM
I also cannot keep a steady RPM between 1400-1700.
2008 135i Sport 6at
Default 06-15-2016, 04:29 AM
Same here. It will be fluctuating between this rpm range.
Car: BMW E92 N54
Default 06-15-2016, 05:20 AM
The menus 10, 11 & 12 already have been sets to default values 3000, 1000 & 2800. additionally one of the log was with the vacuum line off is that do the same as DWP=0. well, i will do so and log again.
Thanks Terry.
