Default 07-14-2016, 04:22 AM
Originally Posted by Bmwfixerguy
The module you got is on its way out.. Buy a new module
There Will be tonsssss of these on eBay because they always get replaced together a a precaution and to prevent a come back
I decided to cough up 270 bucks for the module. Won't be here for another 5 days or so according to Ecstuning.com, I just hope this fixs the issue. 8psi isn't fun at all when at one time it was at 23
2007 e90 335i
Hexon turbos
Trebila Custom tuning
Default 07-25-2016, 09:22 AM
Update
New module arrived from ecs, coded and programed to car with latest ekp software from bmw, after 30miles of driving fuel pressure still at 55psi. No codes, no issues starting or idling or driving normally. For this reason I can't upgrade to any pump bigger than oem. Currently on the original bmw fuel pump and still not getting right psi
2007 e90 335i
Hexon turbos
vwetish's Avatar
vwetish vwetish is offline
Car: BMW 335I / VW 2.0T
Default 10-25-2016, 01:42 PM
Originally Posted by mojo20032004
Update
Any updates on this issue Mojo?
Default 10-25-2016, 03:44 PM
Only way to receive 60+psi at idle or during wot is to run a inline s1 pump from fuel it. Any other pumps will not produce enough psi. Without the s1 pump its at 55,with it 65
2007 e90 335i
Hexon turbos
the imitator the imitator is offline
Car: e30
Default 10-25-2016, 05:39 PM
I'll be using this for my specific needs.
034 surge tank
Default 10-25-2016, 10:23 PM
You do not need 65psi at idle, I don't know why everyone is so obsessed with that.
Running a Stage 2 pump allows the DME to retain control of the pump via PWM, consequently it may and most likely will show lower pressure at idle and cruise. Running an inline pump removes much of that control from the DME, thus the higher pressures. Higher pressures do not equal more flow, nor is more flow or pressure needed.
Our N54 has a very powerful LPFP setup...it runs at 60psi at idle and cruise with an external FPR. You can't even set the FPR higher at idle than 65-67psi as the DME will pull PWM to the pump and won't allow it.
Default 10-26-2016, 06:43 AM
Complelty understand, but the fact that the more throttle that is applied you would expect pump voltage to increase and pump more fuel and at the same time increase the psi when logging. But I personally have that issue with any setup higher than a s1. It would increase the pressure barely, 3-6psi. After everything was replaced that sounded like it was bad, your telling me during a pull in 3rd that 62-57psi through out a run with a S2 pump and 19psi on e30 was maxing out my system. Just doesn't sound right to me. Than id throw a S1 in there with a brand new lpfp assembly and run E60 at 25psi and maintain 78-66psi through out the run.clearly a S2 flows more than the s1 and oem setup should but it didn't seem like it
2007 e90 335i
Hexon turbos
vwetish's Avatar
Default 10-26-2016, 03:05 PM
Is this when running e85 mix? Because I see 65psi at idle and wot. Stock ecu. Stock lpfp. Only hpfp has been replaced.
Default 10-26-2016, 05:55 PM
No, e85 does not affect it
2007 e90 335i
Hexon turbos
joselarajan87's Avatar
joselarajan87 joselarajan87 is offline
Banned
Car: 2009 Bmw 335i
Default simple solution for you - 10-26-2016, 06:34 PM
hello i've done close to 100 installs stg 1,2,3 and been on this forum since the only thing available for the n54 was the jb+ and never seen an issue like you..
now, dont matter what fuel pump you install the ekp module(fuel pump module) is the one that controlls your lpfh & hpfp so thats still alittle issue there.. but of course upgrading to better fuel pumps will help mantain your fuel under WOT.
one thing i hate about people is:people making statements about a product that they think dont work .... bcause thats what they think its the issue but is not..
solution:
#1. ask the seller for a replacement.. maybe it can be defective.. sometimes even new products come defective .. i experience this even on oem spark plug,conectors etc coming defective....
#2 update the jb4 to the latest. double check all your setting .. make sure you have all your setting right... the correct flash/backend flash/mhd flash/cobb whatever...
#3. log your car and check all the parameters... lpfp,hpfp,trims,timing,fol,waistege position etc
once you see the log then you will see whats wrong with it
stop been a lil Bitc. and stop accusing a product you think is bad . because thats your own opinion.
mojo20032004
Default 10-26-2016, 08:11 PM
solution:
mojo20032004
Looks like you missed my other thread. Everything was done, I'm asking for assistance. Logs don't show any issues, since than I sold my S2 setup as it wasn't worth having as I couldn't use my car past 16psi. I also have done multiple installs of pump and just did my 4th turbo install on jackstands, so I know these cars pretty well now. I'm trying to get some pointers in the right direction and go from there
2007 e90 335i
Hexon turbos
Banned
Car: 2009 Bmw 335i
Default 10-26-2016, 08:44 PM
ok.good . the fuel pump is not the problem
Default 10-26-2016, 10:44 PM
Never said it was. Like I said I'm just looking for leads in hopes I get pointed to the right direction
2007 e90 335i
Hexon turbos
Jwesty18 Jwesty18 is offline
Car: E92 335i 6spd
Default 10-27-2016, 09:46 AM
I don't know if you have more posts on this but has all the wiring and grounds been checked for the EKPS and the fuel pump. Also check the terminating resistors in the PT-CAN for that system and make sure they are where they should be. Check all lines from the fuel pump to the rail, make sure you have the updated fuel pressure sensor and not the old one. Old ones are ****. No fuel seeping out of the rail or anything, check connectors for the fuel pump. Id just go over everything with a fine tooth comb.
Default 10-27-2016, 10:26 AM
I have the fuel it upgraded lines in the trunk I have to install so I'm sure that will help. As far as the lpfs. What does the upgraded one look like? I replaced it with one that looked like the unit that was on there.
2007 e90 335i
Hexon turbos
Car: E92 335i 6spd
Default 10-27-2016, 10:40 AM
It should be silver and it should all come together with a hard line and sensor together as one piece.It has a quick disconnect on one end with a fitting into the HPFP on the other. The gold ones are el junk. Ive only been able to find the updated one straight OEM from BMW. When i look on turner or even REALoem, they still show the old gold ones and they don't come together with the hardline. Im not sure what the whole deal is with these, I work at a BMW dealership and the only ones i get from parts are these updated silver ones but i still see the old gold ones everywhere online. Its weird. Ill try to take a picture of what the new one looks like on my car
Default 10-27-2016, 02:54 PM
From what I saw online that hard-line is part of the hpfp assembly,so I would have to buy a complete set in order to receive this hard-line(minus hpfp). And I think you are the 3rd person now that has mentioned this line
https://www.turnermotorsport.com/p-1...IdnBoCRybw_wcB
2007 e90 335i
Hexon turbos
dror135's Avatar
dror135 dror135 is offline
Car: m1235 2013 f20 n55
Default 01-06-2017, 03:16 AM
hi i had same problem with EKP
i order oem stock EKP
need to coding it ?
m135 2013 at-8 PWG STG2 PureTurbo **-ER CP IC NGK plugs inlet pure tmap 3.5 meth kit cm10
JB4 pump fuel stg2 fuel-it
Default 01-08-2017, 12:58 PM
Yes, I believe a brand new one has to be coded for your car. I added a 4x4" aluminum heat sink to mine and have had no issues with fueling systems since. I haven't measured temps before and after, but both EKP and heat sink feel cool to the touch. It's a plate that partially slides under the EKP. The tension from the mounting bolts holds it in place. Kinda redneck but seems to work ok. Car has Stg 2 LPFP and RB turbos.
My original idea was to get a 6x6" heat sink and cut the fins out in the center to create space for seating the EKP, but that would require tools I don't have access to.
dror135's Avatar
Default 01-08-2017, 01:57 PM
Why its heat ?
Default 01-08-2017, 02:13 PM
The EKP module generates heat and has its own built in heat sink plate. No fins though, just a thick aluminum plate. When we upgrade to pumps that draw more amps than stock, the EKP works harder and overheats. That is my guess at least and why I added a bigger heat sink to help the EKP run cooler.
dror135's Avatar
Default 01-08-2017, 02:18 PM
Can send a picture ?
DaZuc DaZuc is offline
Car: 335i xDrive
Default 03-14-2017, 09:26 AM
Please post pics and where do I purchase 4x4" heat sink from?
Did you use thermal paste between the ekp aluminum plate and your heatsink?
Default 03-14-2017, 03:17 PM
I'm also intrested in pictures. I still haven't figured out the issue
2007 e90 335i
Hexon turbos
phv628's Avatar
phv628 phv628 is offline
Car: BMW 2009 335i xdrive
Default 03-21-2017, 06:10 AM
I'm in the same boat. I was idling at 57 psi for several weeks. I decided to pull out the Fuel-IT Stage 3 pumps to change out a fuel level sensor. I uninstalled all of the wiring to check for any tears are poor connections. I reinstalled with no change in lpf at idle and during WOT, the lpf would tank down to 38 psi. The next day I pulled the Stage 3 pump for a second time and re-installed all the wiring for a second time out of frustration thinking maybe something wasn't on tight enough. Anyways this time the lpf at idle jumped to 83 psi and then settled down to 65 psi. However during WOT, although the lpf is tanking down to 38, it is still tanking to about 50 psi. I also installed a new lpf sensor recently and it didn't change a thing. I have now resorted to ordering a ekmp module to try that. My logs show that port is turning on and the trims are good so that tells me that both pumps are turning on and working. This is all very frustrating as a 5 months ago, my lpf would not drop below 70 even with boost at 30 psi.
I'm hoping that someone could chime in so that we can resolve this issue. Are the Walbro's starting to fail?
|E92 335i xDrive| |JB4+MHD BEF| |VM Single Turbo Kit + PTE 6466| |Built Auto Trans| |xHP Trans Flash| |Stage 4-Triple Walbro 450s, fpr + return| |EOS Intake with Port Injection| |AD-ENG FMIC + AD-ENG OCC| |RB PCV Kit| |PR Ignition kit| |Built N54: Darton Sleeved, Manley I-Beam Rods+ARP Rod Bolts, JE 9.5:1 Pistons, JE Wrist Pins, VAC coated main & rod bearings + ARP Head Studs| |Keyed crankshaft snout, crank hub, timing & oil pump sprockets + VTT crank-bolt capture| |ADV Oxygen Sensors|
