Nicky92's Avatar
Nicky92 Nicky92 is offline
Car: 2008 335i
Default 29E0 Fuel Mixture Control, every single day - 04-22-2016, 05:16 PM
been getting this code almost every day. It happens when I idle for more than a few mins.
I am now getting 29F1 - Fuel pressure, plausibility as well.
Fuel Mixture control code doesn't effect driving, but the 29F1 flicks on the half engine and fans at full speed.
Are we looking at injectors?
335- stock
Nicky92's Avatar
Car: 2008 335i
Default 04-22-2016, 06:17 PM
Would an idle log work?
335- stock
7smurfs's Avatar
7smurfs 7smurfs is offline
Default 05-26-2016, 10:18 PM
I had the same code everyday on cold start - it was injectors
135i N54 - BMS DCI - JB4 ISO - Meisterschaft GT exhaust - VRSF CP - Turbosmart Raceport BOV
Default 05-27-2016, 09:04 AM
You'd need to do a log when you are experiencing the issue.
Blown95ImpalaSS Blown95ImpalaSS is offline
Car: 08 135i vert
Default 11-12-2016, 01:04 PM
hey OP, ever solve this?
Default 11-12-2016, 01:10 PM
It's caused by the fuel scalar setting in the BEF not being set appropriately for the E85 mix used.
JazRedGT JazRedGT is offline
Car: 2007 335i E-92 6AT
Default 01-13-2017, 04:31 PM
How do you solve it?
2007 AW 335i E-92 6AT MMP Stage 3 @ 25psi / JB4 G5 ISO / XHP STG3 / VRSF D-Ps / MMP INLETS&OUTLETS / WEDGE MHD E50 BACKEND / CW EXHAUST / CPe CP / GReddy RS BOV / BMS METH KIT / WAGNER IC / PR STAGE3 LPFP 10.92 @ 132 1.72 60ft 6.96 @ 103 1.55 60ft
N54QC N54QC is offline
Car: 07 BMW 335i
Default 01-13-2017, 04:51 PM
Making changes to your fuel scalar or adjusting your E85/Gas mix. I have the problem when I run to much E85 for my setup
Default 01-13-2017, 04:57 PM
And that requires changes to the bin file of the backend?
Car: 07 BMW 335i
Default 01-13-2017, 09:15 PM
Yes, if you continue to run the same concentration that you are currently running, you will make adjustments to your bin in tunerpro or equivalent. I personally lowered my concentration and the car runs better. To much ethanol seemed to have an adverse effect on performance, at least on my car it did unless your running PI, then that's a different story.
Car: 08 135i vert
Default 01-13-2017, 09:47 PM
This was my issue btw. I must have futzed the mix up because I never had any more codes after that tank
