BimmerFan BimmerFan is offline
Car: 2014 335i M-Sport
Default Health Check Please. Logs Attached. - 04-11-2016, 06:55 PM
My car feels underpowered. I am not a guru but it seems the boost is low considering I am running map7 on E30. Car is full bolt on with 47k miles on the clock '14 f30 N55 with EWG. Spark plugs are under 10k miles.
F32Boost F32Boost is offline
Car: 2016 435i coupe
Default 04-11-2016, 07:13 PM
Boost seems real low
Ambient outside temps must be really cool 50-60 degrees
Default 04-11-2016, 08:22 PM
This is data is likely useless now. I just realized I was using the old interface and firmware. I just upgrade everything including the latest firmware. Are the default settings on the interface attached still good to run new logs? This is my current setting on the interface now. Thanks.
Weehe Weehe is offline
Default 04-11-2016, 09:31 PM
Raise boost safet to 21psi, auto reduction to 60, FF to 80, PID to 25, Wastgate position to 60. This is assuming you clipped the diod to be ISO.
Default 04-12-2016, 08:59 AM
Disregard this post...sorry.
He's F-series and EWG, there is no diode to cut and his settings are different.
You need to change your DWP to 60. Are you running the OBDII cable? Do you have the EWG wires connected?
In the first logs all your user adjustment settings were zero'd out.
Default 04-12-2016, 09:16 AM
I noticed that user adjustment settings were zero'd out too but I thought it's because I upgraded the interface and firmware. I am conected to ODBII and not Posi-tapped. The EWG harness is also connected. So just change DWP to 60 and that's it? Thanks.
Default 04-12-2016, 09:24 AM
Yes, that's it for now and take a log.
Default 04-12-2016, 09:28 AM
Thanks Steve. I will take another log tonight and post.
2018 C63s AMG
JB4 E30, Pedal Tuner
Default 04-12-2016, 11:24 AM
Outside temps were actualy in the mid 70s. I have an ATM FMIC installed. That may have helped to keep temps down.
2018 C63s AMG
Default 04-12-2016, 09:16 PM
Went for a drive tonight and took some logs. All I can say is HOLY CRAP! My car felt like another car. I had no idea what I have been missing! I have attached some logs to make sure all is well. I am starting to wonder why I ordered a Pure Stage 2 turbo. This car is pretty freaking quick now. I need to schedule a Dyno session. Thanks all.
2018 C63s AMG
Default 04-13-2016, 03:13 PM
Car felt wierd this morning so I checked the user settings again and FF/ Wastegate Adaption changed from 60 to 86 on its own. Is this normal?
2018 C63s AMG
Default 04-13-2016, 04:46 PM
Yes it's normal.
The last couple logs looked pretty good. You could use a bit more octane if you have access to it. given you have TBI on the shelf I'm guessing you do.
Raise your FOL to 80.
Default 04-13-2016, 05:57 PM
Steve, why are his trims maxxed out ? 49 ?
Is it because of octane. ?
Or his FOL being at 60 ?
Bimmer, try adding 3 gallons E85 on map 5 .
Just realozed your on map 7 ???
What fuel you using ???
chatz86's Avatar
chatz86 chatz86 is offline
Car: 08 E92 335i N54
Default 04-13-2016, 06:08 PM
Im wondering the same thing. Nothing to worry about steve?
2008 e92 335i M-Sport|JB4 G5|MHD BMS BEF|BMS DCI|VRSF DP|Alpina 7603537|BMS OCC|RB PCV|Stage 2 LPFP|Fuel It! ES-1 fuel lines with Ethanol Sensor and JB4 analyser|MMP Silicone Inlets|4 Bar TMAP|VRSF 7" FMIC
Duncan Duncan is offline
Car: Hopefully a 335i
Default Issues - 04-14-2016, 06:24 AM
Hey guys. I'm slightly new to the modification side to the N54... Anyway. I have newest firmware JB4 G5 ISO, basically full bolt on including a walbro 255 pump, and RB turbos 2008 335xi and a Bms backend flash (which I was told is flashed to be pump gas only). I've had the car maybe 6 months and 6-7k miles. Lately, I have been getting kicked into map 4 consistently when I give it good gas. And I even have gotten the 30fe code from the car a few times. My fuel trims are maxed out and I'm not even hitting that much boost. The safety code is consistently Lean AFR. Because I am on only pump 93... I'm wondering what to do with this issue. My friends who are involved in the modding side say my pumps look like they are healthy... They told me this old backend flash is the issue, so I am getting ready to MHD backend soon. Any other advice on how to fix this so I don't have to drive like a grandma? Thanks for any help. I would attach a log but I'm not sure how to get it from jb4 connect onto my phone as a document to attach here.
Element's Avatar
Element Element is offline
Car: BMW 135i N54
Default 04-14-2016, 07:34 AM
Start by creating your own support thread instead of hijacking someone else's. Attach the .csv log files using the Manage Attachment button.
Default 04-14-2016, 09:12 AM
E30 - 3.5gals of E85
2018 C63s AMG
Default 04-14-2016, 09:31 AM
Yes it's normal.
Will do. I turned it up to E36 (Added 4 gal of E85 + 93 octane gas) approximately 96.6 octane. I have access to race gas, but it costs a fortune! I'll go up to E40 if my car stays happy with E36 mixture. I want to be as gradual as I can before I install my other go-fast parts .
2018 C63s AMG
Default 04-21-2016, 09:41 PM
I went up to 5 gallons of E85 and 10 gallons of 93 octane and raised FOL to 80. Please view my logs for health check. Car feels great. Thanks.
2018 C63s AMG
Element's Avatar
Car: BMW 135i N54
Default 04-22-2016, 02:25 AM
Trims are a bit better and timing has improved over your last set of logs, but you still appear to be octane limited (based on a few timing corrections mid-pull)
Default 04-22-2016, 07:50 AM
Trims are about maxed out. Otherwise it looks pretty normal.
Default 04-22-2016, 08:45 AM
Thanks. What is the significance of "trims maxed out?" Is it a good or bad thing? Sorry for my ignorance. What do I need to do to fix it besides adding more E or just go race gas(expensive!) or go back to map 2 or 5? Or just chill till I install my go-fast mods? Thanks again!
2018 C63s AMG
Default 04-22-2016, 09:14 AM
It's bad and adding more E will make it worse...don't do that.
Chill until you install your go fast mods.
Default 04-22-2016, 09:27 AM
Will do. I'll dial things back a bit. Perhaps back to E30 and map 2 or 5 for now. Thanks Steve!
2018 C63s AMG
Default 09-23-2016, 01:34 PM
Need a health check please. Mods are in sig and I am running E51 on map 7. Thanks!
2018 C63s AMG
