Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default Fuel Pump warning in iDrive, 2AAE code - 10-13-2015, 10:38 AM
Hello All,
My BMW has been pissing me off so I have been driving my Lightning around. Anyway since winter is coming and it's my only AWD car I am determined to mess with it again.
I installed the Stage 2 Fuel-It Walbro 450 about 6-8 months ago and have been enjoying it with no problems up until about 2 months ago. I was in SLC visiting a friend and the "Fuel Pump Warning" popped up on the iDrive that tells you continued driving is possible but to take your car to the dealership. I emailed Steve at Fuel-It and he told me that this is normal on some cars.
The car drives fine but recently the warning has gotten worse and I seem to have developed a 2AAE code. I did some research on it and a lot of people having this code said to replace the LPFP sensor on the HPFP. I bought an OEM BMW one and replaced it and it changed nothing.
I am getting ready to send the entire bucket back to Steve but wanted to pick your brains before doing so. I sold my Android phone and bought and iPhone so for the time being I have no way to log the LPFP, but the car drives great. Steve told me this can happen when there is too much ethanol used but have not filled up with anything other than 91 octane.
What else can I check? I don't think it's normal because I drove around for month's with no issues.
09 335 - 6266
07 335i - 6870, E85 - SOLD
Gizm0 Gizm0 is offline
Car: 08 335i
Default 10-13-2015, 10:49 AM
2AAF code is very common and should be disregarded. I had it on my car when i was bone stock, it never caused any issues.
Milan's Avatar
Car: 08 335xi
Default 10-13-2015, 10:57 AM
2AAE, not F
09 335 - 6266
Default 10-13-2015, 11:11 AM
I don't suspect it's an issue with the pump, but as I said you're welcome to send it it to be tested.
Steve
Milan's Avatar
Car: 08 335xi
Default 10-13-2015, 11:55 AM
Anyone else have ideas?
09 335 - 6266
Bme30's Avatar
Bme30 Bme30 is offline
Car: 07 335i 6 speed
Default 10-14-2015, 08:25 AM
Originally Posted by Milan
Hello All,
I just started getting these codes as well. I have monitored my pressures and everything is ok. The car drives great too, just this 2AAE code keeps coming up and then goes off and comes back! I have been running the stage 3 bucket for a few months and this issue started a few days ago.
Default 10-14-2015, 09:42 AM
I'd just turn the fault off in the flash file is low pressure is OK. Some cars do flash a warning for odd things like pump current, low pressure vs target, etc.
Milan's Avatar
Car: 08 335xi
Default 10-14-2015, 09:46 AM
Guys I found a thread on the other forum where someone started getting this problem when driving at high altitudes. Since this happened for me when I was in Utah I think it's the same issue.
I will try his fix (reset) adaptations tonight and report back. I overnighted a samsung tabler to myself so we will see..
09 335 - 6266
Milan's Avatar
Car: 08 335xi
Default 10-15-2015, 03:15 PM
Reset the lambda, fuel, and octane in MHD but no dice. Car runs great though...gonna have to get a log.
09 335 - 6266
NorCalN55 NorCalN55 is offline
Car: '11 335xi M Sport
Default 10-15-2015, 07:34 PM
While I have a N55, I too get the same fuel pump warning on idrive and I run a stage 2 lpfp from Fuel-it. It's pretty anyoing but logs check out and the hpfp is happy.
Milan's Avatar
Car: 08 335xi
Default 10-15-2015, 08:28 PM
Do you get the orange car on lift symbol when you turn off the vehicle?
09 335 - 6266
Default 10-15-2015, 10:13 PM
8.5 / 10 times.
Milan's Avatar
Car: 08 335xi
Default 10-17-2015, 02:36 PM
8.5 / 10 times.
Same here....I'm determined to figure this out lol
I seem to be the only person with an n54 and this problem but it seems like idrive is less common in people modding n54
09 335 - 6266
Sikh335xi's Avatar
Sikh335xi Sikh335xi is offline
Car: 08' E90 335xi
Default 10-26-2015, 01:58 PM
Terry may be onto something with Pump Current throwing that code, I recently had my pump power and ground wires melt together inside of the tank. Too much current will cause heat, then all of a sudden I started getting that code and the Idrive message.
I've had that pump in there for damn near 50k miles and one day it died while driving, no low fuel pressure, found the wires melted together.
Since then I've kept an eye on fuel pressure and AFR's and nothing is underperforming.
Someone over at BMS had suggested to me that using the gates hose will clog up the fuel filter on the driver's side and make the pump work pretty hard, but it looks like you have a Fuel It setup.
Idk that might all be useless information but hopefully it helps someone in finding out why this code is being thrown.
02' E46 325ci 5MT- Totaled.
03' E46 330xi 5AT- Sold.
05' E46 M3 SMG- Sold.
08' E90 335xi 6AT- Totaled.
07' E92 335i 6MT- Current.
On3 67mm ST, JB4+MHD BEF, PI, E85 and supporting bolt-ons.
717rwhp on 27.5psi (Finish Line Performance Dynojet)
hoshi335i hoshi335i is offline
Default 03-21-2016, 07:21 AM
I got a walbro pump stage 2 bucket on saturday, installed on Sunday after 5-7 minutes idle or speeding i get the warning. no altitude no nothing.
I have Dinan tune on my car with bigger turbos and AFE intake.
Anyone able to figure it out ?
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 03-21-2016, 08:01 AM
I get pump warnings in idrive when going WOT but it never throws a code as it's set to 00 in the flash. It must be the increased current demand.
I somehow lost all my service info following the stage 2 pump install. Such a PITA!!! Now the car reads service required every time I start up. Plus the car on the lift.
I'm hoping my car is safe to drive. The oil measurement is always reading full 100% and hasn't dropped at all 2 months after an oil change. This has been after lots of WOT runs. I was expecting a tiny drop.
I tried parking on a 25 degree hill to see if I could get it to read anything less than 100% full.
I need to look at the car with DISv57 or ISTA. The BMW stealers couldn't sort my issue after paying them $160 for nothing. The car wont hold any service info right now.
JValenzSD's Avatar
JValenzSD JValenzSD is offline
Car: 2010 BMW 335i LCI-M FBO FF
Default 03-21-2016, 12:25 PM
I have that pop up in mine as well. I have an i-Drive and the codes are both disabled in my tune.
Months ago, I had my Fuel It Stage 2 bucket sent back to Steve for testing and the pump test came back with no problems.
Logs even show that the Stage 2 lpfp pressures are where they should be.
Everytime I get that orange triangle, I am now conditioned to know that my Stage 2 pump is kicking in.
MHD E75 Flash, E-Sensor, N20 Sensor, Fuel-It Stage 2, Injen DCI, Synapse Eng CP/BOV, CX-Racing FMIC, AR-Designs CL DP's, 2.5" SS Straight Pipe Exhaust w/resonators, MMP Si Inlets, VTT Outlets, BMS OCC, Ohlin's R&T DFV, M3 Bits, TMS Aluminum SF Mounts, MFactory Solid Diff Bushings, MFactory 3.46 LSD, Eibach M3 Sway Bars, ECS 2 Piece CD/S Rotors, Hawk HPS+, ECS SS Brake Lines, Motul Dot 5.1, NGK 5992, RB PCV, Si Hoses, Walnut blasted... '11 Ducati 848EVO, Pro-2A in Sunny SoCal.
Default 03-21-2016, 07:18 PM
I was sometimes getting that code intermittently while driving, then the iDrive fuel pump error symbol in iDrive after shutting engine off.
It got more and more frequent and eventually caused engine shutdown while driving. I listed all this in a Stage 2 LPFP thread some months ago.
Long story short I changed the EKP fuel module and recoded it. Seemed to solve the problem.
I updated to a newer version that was compatible, so went from an EKPM2 to EKPM3.
These modules contain heat sinks and I suspect that my bigger Walbro LPFP was generating more amps and more heat than the stock pump, hence causing disturbances. Just a theory.
I have had no codes or issues since changing the EKP. Used one off a 2009 e60.
I would not ignore fuel pump error codes. It's triggered by something, we just don't know for sure by what. In my case both pumps were fine and I blame that EKP.
No issues or codes since swapping it out.
houtan houtan is offline
Default 03-22-2016, 06:47 AM
So does everybody get the code who upgrades the fuel pump?
Has Fuel-it confirmed the fix is to upgrade the EKPM? How do we know what EKPM our car has?
I hear of instances where the fuel pump upgrade throws a code, but not very often. Is it that people are getting the code and not saying anything about it or is it rare to get the code?
Default 03-22-2016, 07:35 AM
No, everybody doesn't get the code but some do.
Ocean was having a lot of issues with the car shutting down after driving a short distance and when it did, it shut the fuel system down. The dealer replaced the HPFP and then said the LPFP was bad. We didn't believe this was the case but sent him out another LPFP. When we got his old LPFP back we tested it and found it to be good. They were then getting ready to replace the relay and we suggested that he replace the EKP module. This was what appears to have fixed the issue.
However, we would not recommend that people start replacing their EKP modules because they get a 2aaf, 2aae, or fuel pump warning. As mentioned the EKP does see that the upgraded pump pulls more current and may throw a code or warning on some cars. The code is a shadow code and does not throw an SES or CEL. If everything is running fine otherwise, we'd recommend that you disregard it.
Default 03-22-2016, 08:42 PM
Thanks Steve
J. Dub J. Dub is offline
Default 07-25-2016, 11:38 AM
I too have fuel-it stage 2. I too have 2aaf, and 2aae on my 2010 N54 335i.
Running MHD alone.
Running e40 mix of fuel.
Stock fuel lines.
Always a shadow code NEVER a limp car.
Occasionally on cold starts, the car will stumble a little. Possibly because I'm running some e85 in my tank.
snelson3003's Avatar
snelson3003 snelson3003 is offline
Car: 135I
Default 07-25-2016, 01:48 PM
+1 on the EKPM2/3 module. Mine had a similar issue until i swapped the module from one i got on ebay.
Also noticed my LPFP hits 76 now easily. Before it would stay at 67psi all the time.
498WHP / 516TQ : 10/29/16
VTT Stage 1 + Billet Wheel | VTT Inlets | VTT PCV Valve | JB4 G5 ISO | BMS E85 Flash | Fuel It Stage 2 | ECS TwinTake| Stett Vacuum Canisters | Hartge Stepped FMIC | VRSF DP | 91Oct w/E50 | BMS Cowl Filters | Located in Denver, Colorado - High Altitude!
Maintenance: EKPM3-DE @ 74K | Water pump & T-stat @ 70K | Valve Cover @ 50K | VTT Turbo @ 70K | HPFP @ 65K | Walnut Blasting @ 65K | 6 Injectors @ 55K | Vacuum lines @ 55K | Spark Plugs @ 75K | Boost Solenoid @ 65K
Default 07-26-2016, 10:19 AM
Interesting
Car: 2010 135i
Default 08-14-2016, 11:56 PM
I get the e code also.
Not real happy about it!
datalog --> http://www.***********/u/iminhell1/lo...0&data=4-15-23
This car is a return system as far as I understand. My Focus was returnless. When my pressure logs looked this ****ty I had to tune the PID controller for the pump (gain). All fell in line and I never threw another pump code.
How is the BMW pump controlled?
2010 135i auto,
