(#76)
Blackarrow335i's Avatar
Blackarrow335i Blackarrow335i is offline
Default 11-16-2016, 11:48 PM
Well I'm back with a couple new logs.
Steve could you please check em for me and let me know what you think!
Everything looks good? What about my map 6? Can I hold 22psi till redline or do I need to taper down? Think it doesn't looks as clean as my map 7 logs.
Thank you!
Add info: changed following values after the logs but couldn't do a log with the new values!
FF=80
FOL=82
Also attached 2 pictures, can I go with those boost/and other settings?
E92 09' 335i MHD BY V8BAIT
MMP STAGE 3 / MMP PI
XHP s3 / MR.5 AIRINTAKE
VRSF **'s VRSF 7" IC / RB PCV VALVE
VTT 2" INLETS / STETT CP TIAL BOV
M3 F/R CONTROL ARMS / M3 STEERING RACK
MEGAN TOE ARMS / KW V2 SUSPENSION
ST DRILLED/SLOTTED ROTORS
BODY/INTERIOR MODS
N20TMAP NGK 5992s Gapped To 0.018"
PR IGINITION UPGRADE
FUEL-IT STAGE 3 LPFP / MISHMOTO + BMS OCC
SETRAB AT COOLER / PERFORMANCE EXHAUST MOD
Default 11-17-2016, 11:24 AM
Not likely that you will be able to hold 22psi to redline. PWM is almost maxed out and you are shifting at 6200 or so with 18-19psi of boost. DB's look too aggressive up top and you overboosted shifting in to 5th and got kicked to map 4 on your map 6 log.
Default 01-23-2017, 11:05 AM
Hello Steve,
Could you please evaluate my logs to see if everything is how it should be
maybe a boost leak?considering how high my wgdc, Compared to the boost targets?
Thank you!
BODY/INTERIOR MODS
JayJ JayJ is offline
Car: 135i N54
Default 01-23-2017, 11:24 AM
HPFP is taking serious strain.
Default 01-23-2017, 11:50 AM
So lowering my E85 or get PI correct? But what about my wgdc? That ok?
BODY/INTERIOR MODS
Default 01-24-2017, 11:21 AM
Turbos are about maxed out, that's why PWM is high.
Yes, HPFP is struggling so you will have to lower ethanol content or go to PI. Right now you are right on the edge in regards to fueling..
Default 08-12-2017, 10:38 AM
Hey fellas,
I need help please mods are in my signature, having trouble with getting my car of the line it doesn't matter what I try or what gear I try to launch in it won't leave of the line until i shift to next gear...it's just fine on the streets roll racing feels great but horrible from a dead stop logs are attached custom tuned by Trebila but he isn't available til end of month tia
BODY/INTERIOR MODS
Default 08-14-2017, 08:49 PM
Bump still looking for some help please
BODY/INTERIOR MODS
Default 08-15-2017, 02:52 PM
So what's the issue here that I don't get any help ? Is it bc I'm custom tuned ???
Steve ??? You there??? Please
BODY/INTERIOR MODS
Default 08-16-2017, 11:07 AM
You're running a custom tune and MMP port injection.
I don't know anything about the tune you are running and MMP PI is problematic.
You'll want to follow up with them to resolve your issues.
