(#51)
Default 12-11-2015, 04:53 PM
I suspect a boost leak or hardware issue. Time to get dirty.
Blackarrow335i's Avatar
Blackarrow335i Blackarrow335i is offline
Default 12-16-2015, 12:21 PM
Hi Steve,
Does it still look like a boost leak? never had any 30ff codes, I adjusted menu 12 from 2400 to 2800 now!
also attached 2 pictures of user adjustment
Thank you!
https://www.dropbox.com/s/jz2ksgwx1n..._3079.PNG?dl=0
https://www.dropbox.com/s/dk5t8cgvzu..._3081.PNG?dl=0
E92 09' 335i MHD BY V8BAIT
MMP STAGE 3 / MMP PI
XHP s3 / MR.5 AIRINTAKE
VRSF **'s VRSF 7" IC / RB PCV VALVE
VTT 2" INLETS / STETT CP TIAL BOV
M3 F/R CONTROL ARMS / M3 STEERING RACK
MEGAN TOE ARMS / KW V2 SUSPENSION
ST DRILLED/SLOTTED ROTORS
BODY/INTERIOR MODS
N20TMAP NGK 5992s Gapped To 0.018"
PR IGINITION UPGRADE
FUEL-IT STAGE 3 LPFP / MISHMOTO + BMS OCC
SETRAB AT COOLER / PERFORMANCE EXHAUST MOD
Default 12-18-2015, 06:02 AM
help please...
BODY/INTERIOR MODS
Default 12-18-2015, 09:13 AM
Looks like you need more DB tuning but may have a bit of a boost leak as stated before.
Your FF should not be maxed out.
Default 12-18-2015, 09:27 AM
Thanks Steve for looking into it! By more DB tuning you mean try to increase by 5 all over the board (log) and go from there?
BODY/INTERIOR MODS
Default 12-18-2015, 03:45 PM
Dial in your FF curve via the DB values so the shape is similar to that of the PWM curve. Then use the FF value to move the curve up or down.
Default 12-18-2015, 04:40 PM
Alright Steve will do so appreciate the information and instructions!
Btw found a little leak today on the lower hose on the vacuum canister but going to replace that hose now
Will post some logs in the next days thanks again Steve! Love your support here!
BODY/INTERIOR MODS
Default 12-19-2015, 11:06 AM
I'd suggest replacing all of those with silicone lines while you're at it.
Good luck.
Default 12-19-2015, 03:32 PM
Good luck.
Hi Steve,
I fixed the Vacuum leak actually the vacuum reservoir itself was leaking but got that fixed and went out for a spin and took some logs!
so far so good but now i get a 2F0C code at WOT sometimes not always and half engine light but goes away on its own after a couple sec. guess that related to the TMAP sensor? but the Sensors is new replaced the old one to N20 couple weeks ago jb4 is set to 1 for N20! what I'm missing or what could cause it!
Also played a little bit with the DB settings how does it look now?
Thanks in advance!
BODY/INTERIOR MODS
Default 12-21-2015, 09:31 AM
BODY/INTERIOR MODS
Default 12-21-2015, 09:32 AM
I'm not sure about the 2FOC error, only thing I can suggest is running the original TMAP for a little while and see if the error still occurs.
Otherwise the logs look pretty good.
Default 12-21-2015, 10:34 AM
Thanks Steve,
Actually i swapped from the oem sensor to the N20 because of this issue (2FOC)! Problem was gone until now! Guess however it started after playing with the DB settings! Will try to revert the settings just to see if it fixes the issue! I'll keep u posted! But this will probably not happen before next year, going on vacation!
Thanks again Steven and merry Christmas
BODY/INTERIOR MODS
Default 03-25-2016, 07:41 PM
Hello Steve / Hello guys,
I made a bad experience today, was sitting at a red light about to get on the interstate, got green and about to take off car went into limp mode, cleared code (29DC) and tried to keep driving but unsuccessful because as soon I hitted the throttle car went back into limp mode, tried to kept deleting codes but also with out any success car was shaking also tried to restart the car, idle was really bad and car died. After a second try I was able to get it home with out much throttle! I got to logs but there are pretty bad bc I could not give any throttle! I'm right if I say that is my hpfp? Any help is appreciated!
BODY/INTERIOR MODS
Default 03-27-2016, 05:34 PM
Yeah...HPFP does not look good at all.
Default 03-28-2016, 05:42 AM
Thank you Steve she sitting at the dealership already and waiting to get a new hpfp
BODY/INTERIOR MODS
Default 08-02-2016, 06:14 PM
Hello Steve / guys
Could someone review my logs please? It's bin awhile since I posted my last logs on here, I did a couple things to her in between (see signature).
I'm planning on going to the Drags strip on Thursday and would like to know if she is healthy and good to go?
Thanks in advance
BODY/INTERIOR MODS
Default 08-03-2016, 09:01 AM
Looks pretty normal but your LPFP is tanking and taking your HPFP with it. You'll need to upgrade the LPFP.
Default 08-03-2016, 10:15 AM
Thank you Steve!!! Yeah I know about the lpfp it's on top of my list! But I want a stage 3 since I'm planing on running PI in the future as well, and is hard to get a used stage3 guess I'll end up with buying a new one from you guys!
I'm right that I'll need a stage 3 if planning on running PI right?
Again thank you Steve for your help!
BODY/INTERIOR MODS
Default 08-04-2016, 11:03 AM
No problem, if you plan on running PI and over 500whp on E85, I'd suggest a Stage 3.
Default 09-27-2016, 07:52 PM
Hello Steve / hello guys
Here we go again, I was playing around little bit with map 6 and just wanted to double check if everything looks still okay? I know I can work a little more on my FF and Duty Bias settings to get a better shape right? But how does it look over all? Am i still good with 20.4 PSI in the mid range and 19 at redline? Any help and advice is highly appreciated!
BODY/INTERIOR MODS
Default 09-28-2016, 06:44 AM
Looks pretty good but fuel system is struggling and HPFP is crashing up top. I would not recommend continuing to run that way. Other than that, I don't see any issues.
Default 09-28-2016, 12:42 PM
Thank you Steve for always responding so quick! I know I need to have my fuel pump upgraded real bad! But it's coming... just saving some money to do it all at once end of this year (turbos,stage 3, & PI)so I can roll out with 700 ponies under the hood next season!
Anyway thanks again Steve for being always so Buick and helpful!!!
BODY/INTERIOR MODS
Default 11-11-2016, 09:50 PM
Hey Steve,
Here we go again, after I finally purchased and installed my stage 3 pump! (Thanks for for fast shipping)
Please could you review my logs? Can I slowly bump it up to 23psi in map 6?
Running a E70 mix currently!
Thank you!
BODY/INTERIOR MODS
Default 11-14-2016, 11:05 AM
Looks pretty clean but trims are high. Switch to the E85 flash if you haven't already.
Default 11-14-2016, 12:16 PM
Thanks Steve will do so tonight! And report back with new logs!
BODY/INTERIOR MODS
