Stefan85 Stefan85 is offline
Car: M235i
Exclamation Stefan85`s M235i JB4 Datalog - 07-15-2015, 02:10 PM
Hey Guys,
could you please have a look at my log running at map5?
Can you please tell me whether all values are fine?
My modifications:
- JB4 N55 EWG
- N55 JB4 EWG Harness Adapter
- F Series OBDII CANbus Interface
- 200 Cell ********
My User Adjustable Settings:
Thanks a lot.
Regards
Stefan
CHECKERED's Avatar
CHECKERED CHECKERED is offline
ex deus machina
Car: E92 N54 335i
Default 07-15-2015, 02:34 PM
looks good, but a bit short because of the 8 speed gear ratios
try getting a longer log of 4th into 5th
Garage Queen: Audi S4 4.2L V8, Vortech Supercharger, Bilstein PSS9 Coilovers, Sway-bars, RS4 brakes and rear BBK, Fast Intentions - Full Exhaust, 505AWTQ 0-60: 3.8s
Daily Driver: E92 335i N54: complete part out - let me know of any parts you need:
https://www.n54tech.com/forums/showthread.php?t=55650
Car: M235i
Default 07-15-2015, 10:20 PM
Thanks.
Do you think I should change any values like Open Loop?
I will do a better run of 4th in 5th later.
Default 07-15-2015, 11:57 PM
Ol looks great and log looks good.
As suggested do a 4th gear log.
Car: M235i
Default 07-16-2015, 08:36 AM
Do I have any chance to get AFR into 12th?
Default 07-16-2015, 04:39 PM
You did, for about 1/2 a second.
it looks fine, timing is good and stable. I wouldn't worry about it.
Car: M235i
Default 07-17-2015, 01:08 PM
Hey Guys,
as wished here is a 4th gear Log in Map5.
I hope everything is fine .
User Adjustable Settings are identical as above, except of FF/Wastegate Adaption, it raised to 91.
Can you also tell me why boost is sometimes higher than target?
Thanks for your support .
Default 07-17-2015, 05:08 PM
Boost exceeds target because your FF is a little too high. Lower it to 80.
Car: M235i
Default 07-18-2015, 02:26 PM
Thanks Steve, I will change it to 80 and will do a log tomorrow.
Is the FF/Wastegate Adaption value only self adjusting in map5 or also in map2?
Default 07-18-2015, 03:17 PM
It's self adjusting on all maps.
Car: M235i
Default 07-19-2015, 10:32 AM
Steve,
here`s a run in map5 from 4th to 5th gear with FF 81 (I`ve set FF to 80 but it self adjusted to 81).
Sometimes boost is still higher than target...
Default 07-19-2015, 12:34 PM
Yes, but look at the variation in your RPMs...that's either spinning, rough road, or trans issues. That probably contributed to the throttle closures and thus the overboost. I wouldn't make any assumptions based on that log.
FF will adjust itself. Try to do another log with a better RPM slope.
Car: M235i
Default 07-26-2015, 09:51 AM
Hey Steve,
here`s another Log from 4th into 5th, now with better RPMs .
Please have a look at it .
Thanks a lot .
Car: M235i
Default 07-27-2015, 10:44 AM
Up
Car: M235i
Default 07-30-2015, 12:43 AM
Hey Steve,
can you please check my log? In some reason I have still some overboosting. It that`s the reason that throttle is opening and closing all the time?
What can I do?
Default 07-30-2015, 09:17 AM
Sorry I missed this.
The N55 typically has more throttle closures but none of which are very severe and don't look to be impacting performance.
Your overboost is pretty minimal, it should learn down but you can always lower your FF a couple points. However I don't know that I would worry about it in your case.
IAT's were getting up there...that may have affected your post shift timing a bit. Otherwise it looks pretty good.
Car: M235i
Default 08-11-2015, 12:31 PM
Sorry for disturbing you again.
But I just got some error codes while driving with highspeed on german autobahn.
Here are the codes:
102001 Air mass, plausibility -- Tuner code, ignore
128901 Lambda probe before catalytic converter, dynamic: slow reaction
101F01 Throttle valve opening angle pressure -- Ignore, tuner code
119404 Rail pressure sensor, signal stuck
Could you please tell me what`s going wrong?
My actual settings:
Thank you for your support
Default 08-11-2015, 12:48 PM
Would need to see a log.
Car: M235i
Default 08-11-2015, 12:55 PM
Steve,
here`s a log before I have got these problems.
If you want to see a actual one I need to do this tomorrow.
Greetz
Stefan
Default 08-11-2015, 02:02 PM
That log looks fine, would need to see a log when the actual codes appear.
Car: M235i
Default 08-12-2015, 12:17 PM
Hey Steve,
here`s a log (Log with error code) when the actual codes appear.
This always happen when I drive into 250km/h speedlimiter on autobahn.
But at this time i was logging the only error code was
The user adjustments are identical as above.
After that I deleted this codes and started a new "normal" log from 3rd to 5th gear. I also attached it above.
Thank you very much.
Default 08-12-2015, 03:19 PM
Is this always at the same speed and you're hitting the speed limiter? I can see that the rail pressures are pretty high, but once you hit the limiter the throttle closes but the rail pressures don't drop. Looks like they stay pretty high due to the drop in boost and rise in AFR's.
In your 3-5 log, the rail pressures are just as high and it's not an issue, so I think it may be due to you hitting the speed limiter, throttle closing, but your rail pressures remaining high.
Car: M235i
Default 08-12-2015, 10:52 PM
The Problem always appears when I am hitting the Speed limiter, in other cases I don`t have any problems like this.
Can you please tell me what I can do to avoid this Problem?
Driving slower? It`s not an option .
Default 08-13-2015, 08:12 AM
I don't believe there is anything we can do about the speed limiter.
Car: M235i
Default 10-12-2015, 01:12 PM
Hey Guys,
I have another question left.
Is it safe to run Map7 with my setup and german super plus 98 ROZ fuel?
