(#3551)
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 02-02-2018, 01:12 PM
Originally Posted by Ragin Cajun
Terry:
I finally found the culprit of the vacuum leak, however I am uncertain if it is related to boost not hitting target. The Fuel Tank Ventilation line that is attached tot he back housing of the throttle body has a tiny crack in it. https://www.ecstuning.com/b-genuine-...SABEgLaufD_BwE
Would that cause the boost issue? Thanks for your help!
Part # 13907636153
If that hose that attach to throttle body and cracked it's on the boost side and will leak before your intake so I guess it will be low on boost
OldBooster's Avatar
Car: 2008 135i AT
Default 02-02-2018, 01:23 PM
Thank you, Rushan, that does make sense. I will give the buyer of my car the money so he/she can buy the licenses.
Held #1 on www.DragTimes.com:
First to run 11.012 @129.30
neroneuman's Avatar
neroneuman neroneuman is offline
Car: n54 335i
Default 02-03-2018, 09:09 PM
Thanks Rushan
Ragin Cajun Ragin Cajun is offline
Car: 2007 335i
Default MHD JB4 BEF OPTIONS - 02-17-2018, 04:23 PM
Hi Terry:
I bought the jb4 mhd bef download and have a question regarding the 3 E85 options. Can you tell me the difference and advantages of choosing 1 over the other?
1. JB4_BB2_I8OS_E85_PI.bin
2. JB4_BB2_I8OS_E85_TS.bin
3. JB4_BB2_I8OS_E85_TS_THR.bin
Thanks so much!!
Default 02-17-2018, 04:29 PM
Do you have port injection?
Do you have a twin scroll turbo manifold?
Do you have both and want a more aggressive throttle mapping?
Car: 2007 335i
Default 02-17-2018, 04:36 PM
Terry:
Please disregard! I found the info on the 1st page under the MHD descriptions. Please accept mt apologies.
Back End Flash Map Templates
All the maps are included in to a single download file named by release date. Maps are organized by the file name using the specifications below. These templates are unlocked allowing you or your tuner to make whatever adjustments to base timing, AFR, and other factors you need.
JB4_BB2_[software version]_[fuel type]_[ST if for single turbo]_[PI if intended for port injection or TBI systems]_[TS for twin scroll single turbo kits]_[KR if knock sensors have been desensitized].bin
Software Version: IJE0S for MSD81 (most 2008 and newer cars), I8A0S for MSD80 (most 2007 and early 2008), INA0S for 335is models, and IKM0S for 1M models.
Fuel Type: PUMP is suitable for pump gas fuels and up to 30% E85, RACE has more aggressive timing curves best used with higher octane fuels, while E85 has timing and air/fuel ratios best suited to E40 and higher mixtures.
ST: This designates maps that are intended for single turbo applications. They run load, timing, air/fuel, and VANOS curves optimized for single turbos.
KR: This designates maps that have altered knock sensor sensitivity tables. We've found the platform highly susceptible to false knock, timing drops on higher octane fuels, particularly post shift, and desensitizing the knock sensors will reduce this tendency and improve performance. Alternatively the [KR] changes also increase the risk of engine damage if running the map outside of its octane/boost requirements and/or if actual knock occurs.
6/15/17 Map Release
1) Various minor tuning changes.
2) Added some THR maps for single turbo use with a more aggressive pedal to boost profile preferred by some drivers.
3) Added a BB2 version of INA0S PUMP which can be flashed with BB or MHD. The rest of the INA0S maps are MHD only. Will add the rest of the INA0S BB2 maps in the next update.
2008_335i_coupe's Avatar
2008_335i_coupe 2008_335i_coupe is offline
Car: 2008 BMW 335i coupe
Default 02-20-2018, 08:34 PM
I have an issue.
When trying to flash back to the stock bin, with a battery charger on the car (connected to the Terminals under the hood). The fuel pump runs the whole time and when the flash is complete. The car only cranks and won’t start at all. I tired many times and no luck. I can flash to a bef and the car will start. Please help
2008 Alpine White 335i E92, 6AT, Saddle Brown Leather, NAV, CF roundels, M3 steering wheel with M3 paddle shifters, Aero lip, painted kidneys (white / black), painted lower grilles (black), debadged, M3 spoiler, ST V1 coilovers, 19" CSL wheels.
, JB4 ISO 5, BMS DCI, AA Intercooler, Coolingmist methanol kit, Forge Diverter Valves, BMS 3", CPE Charge-pipe, BMS Oil T-state bypass, RB PCV
RhynoBoiler's Avatar
RhynoBoiler RhynoBoiler is offline
Chi-Town Cruiser
Car: 2011 BMW 335is
Default Stock DME Backup - 02-21-2018, 10:19 PM
This is the first time I've tried doing the BEF thing so I want to be sure I haven't made any mistakes so far. Is there any way to confirm that the stock DME backup file I saved is good?
I have a 2011 335is with HW: 7639995.
The backup took over an hour but I accidentally started the backup with the JB4 on map 2. I stopped it 4 minutes in, changed to map 0, & then restarted the backup (at least I think I did, since the MHD option says: "Start/ Resume Backup").
I tried to attach a copy of the backup file incase anyone here can help but the 2mb file size is too big.
I'm planning on flashing the INA0S PUMP BEF via MHD tomorrow night, but I want to be sure I have all the correct files.
All aboard the Lakeshore Drive Express!
Rushan's Avatar
Car: 335i E92 2009
Default 02-22-2018, 04:21 PM
2mb look like it's correct, that's the bin file size, make sure u have latest JB4 firmware as it automatically set you to map 0 when you connect your cable
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 02-24-2018, 06:31 AM
Originally Posted by 2008_335i_coupe
I have an issue.
Fuel pump is disabled with MHD so I guess you use the BB programm.
Sounds like your backup is not valid (probably a tune not a backup). You can use MHD to flash back to stock without a backup file.
Don't oversweatit - MHD backup is completely optional (and may be removed later altogether) as the app has all oem maps to flash you back to stock without a backup.
cslpower cslpower is offline
Car: 08' 335i E92
Default 02-27-2018, 07:32 AM
I have a older Rom on my MSD80 (I860S). Can i just flash the I8AOS BEF over it?
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 03-19-2018, 02:52 AM
yes.
Originally Posted by BMWSwede
Hi guys.
Is lean spool active in the I8A0S pump, race and E85 BEF?
I have some trouble with missfires in several cyl 1,4,5,6 during spool. Sometimes even in map 4.
Doesn't occur every time but AFR is almost always lean. Sometimes stuck at 20, next pull at 17-18. And sometimes at a more normal 15.
Attached a log of map4 with afr at 20 during spool.
post in the support section
Car: 2007 335i
Default MHD JB4 BEF Colder Plug Gap Question - 03-19-2018, 04:03 PM
Hi Guys: Found the Vacuum leak: Intake O Ring in charge pipe got sucked in the motor!! Next issue at hand below:
Installed inlets to compliment my mods and understand running 1 step colder plugs prevents misfires. I gapped the colder NGK plugs 0.018" based on what I read and the power I am putting down. JB4 found several misfire codes two days later. Should I open the gap to 0.022"? Thanks for the advise.
mods are as follows:
BMS DCI intake
VRSF Inlets/Outlets
BMS Meth
Charge pipe, BOV
RB PVC
Running JB4 Map 7 E57
FMIC, Kittens, Full Exhaust, JB4 MHD BEF E85
fredcase fredcase is offline
Car: 07 335xi
Default 03-30-2018, 02:30 PM
I just bought another n54. It came with a cobb v2. Can I use the Cobb to load a bef? I'd rather use the Cobb to load the bef than buy another licence from mhd.
2007 335i MT, JB4 G5, Hybrid Race BEF, DCI, Inlets, Tomioka 16t turbos, outlets, 6" AMS FMIC,Chargepipe with Raceport BOV, d_p's, stage 2 lpfp, Mfactory LSD, X-Clutch twin disk.
MasB00st MasB00st is offline
Car: 335is
Default 335is ST Port injection - 03-30-2018, 03:12 PM
I don't see a single turbo port injection tune on here for INAOS. I do see a hybrid turbo port injection. I assume this is for twins, correct?
Default 03-30-2018, 03:24 PM
We have one, may not have posted it yet. Email me!
Car: 335is
Default 03-30-2018, 03:44 PM
where can I email you?
terry@burgertuning.com
Car: 07 335xi
Default 03-30-2018, 04:21 PM
Default 03-30-2018, 05:22 PM
Uninstall and sell Cobb to some sucker, and use MHD for $80 or BB for free to load the BEF. We haven't supported the Cobb platform for years for various reasons. Mainly their development didn't keep up to pace with even the free BB firmware.
Car: 07 335xi
Default 03-30-2018, 06:47 PM
Thanks Terry. Maybe I will hang on to it, maybe one day it can be used to load bef or if I come across other custom maps.
codesx's Avatar
codesx codesx is offline
Default Uploaded PUMP BEF (I8AOS) - Runs, but stumbly - 04-14-2018, 01:54 PM
Hello,
I've looked around and don't recall seeing an answer to this - which suggests to me it's not required. Still, with my symptoms, I think it's best to ask...
I just uploaded the PUMP BEF via MHD.
The process went swimmingly.
Upon starting the car (after setting dash-accessible to 4/2 (enabling BEF I believe), the car runs pretty rough.
However, when I flip it over to 4/3, it smooths out.
I haven't gotten a chance to road test it as the weather here is brutal this weekend.
Does it need some time to 'adapt' to this BEF and then it will smooth out?
Do I need to reset adaptations to speed this process up?
New NGK @ 0.020 (was 0.022, but just closed a bit i the hopes it helps avoid the odd hit).
New Ignition Coils, Bosch.
Thanks!!
Default 04-14-2018, 04:44 PM
With the BEF loaded 4/2 is required. Setting has no effect on idle so you may have something else going on. When re flashing the car some adaption is required.
codesx's Avatar
Default 04-14-2018, 05:05 PM
Thanks for that reassurance Terry.
I only got to idle, but I wanted to think it was improving after 5 mins.
Maybe tomorrow I can get it out if weather allows.
imad777 imad777 is offline
Car: BMW 335i
Default 04-15-2018, 12:22 AM
Hello guys. May be this was already answered before, but I can't find Single Turbo BEF for I8A0S to use with MHD flasher. I can only see IKM0S and INA0S.
Any assistance is appreciated.
2007 335i MT N54
MHD+JB4 Garret GTW3684 ST
FMIC, DP, 3" *****, Fuel-It Stage 1, MF LSD.
