(#2701)
K.Jameel K.Jameel is offline
Car: BMW E92 N54
Default 07-05-2016, 10:00 AM
Originally Posted by suspenceful
I noticed the same thing.
+1 count me in, the burble it's amazing but the oscillating and jerking has been increased.
Hope MHD solve that problem at the earliest.
BMW 335i '08 E92 N54, JB4 G5 IOS, BMS DCI, VRSF ***, BMS-Tial BOV Kit with Chargepipe, VRSF FMIC, BMS Meth Kit, JB4 MHD BEF, BMS PCV valve, BMS OCC. TCU Alpina_B3 Flash, .
ninjacoupe ninjacoupe is offline
Car: 135i..First of the 1
Default 07-05-2016, 05:20 PM
OK MHD has burble but what about the ghost cam haha...more fun!
mkster08 mkster08 is offline
Car: 2008 335 AT
Default 07-05-2016, 09:20 PM
Check out your menu 11 settings on the jb4, if it's set probably anywhere above 1.5 or 2k you will feel that surging because the car is calling for boost and is much more touchy at 5% throttle.. And the burble is trying to come on around that same throttle % so it's trying to do both things at the same time, a linear throttle mapping will not do that. Having a less linear more aggressive throttle will do this slight surging regardless of burble too. At least this is how my own experience has gone, now with menu 11 back at 0 I can rest my foot on the gas at highway speeds no oscillating or surging.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 07-06-2016, 05:10 AM
A beta 1.40 build was pushed, that features a fix for the low load jerkiness, as well a second duration slider for sport mode so user that have a sport button (1M, IS cars and DCT cars) or AT (in DS-M mode) can tweak the effect differently based on the mode (normal, sport).
Waiting for feedback on the jerkiness fix.
Opting in for the beta channel is here
https://play.google.com/apps/testing...hd.flasher.n54
cmg5461 cmg5461 is offline
Car: 2008 E90 335xi 6MT
Default 07-07-2016, 06:35 AM
Jerkiness at steady pedal is fixed.
Getting off the gas quickly is still rough.
I'll see if I can get a log of it after work today
E90 335xi 6MT - Deep Green
Poppowisch's Avatar
Poppowisch Poppowisch is offline
Car: BMW e93 335i
Default 07-07-2016, 11:56 AM
tested the new update today, love that you can change so burble is only on the DS-M. felt no problem with the jerkiness, but I did not felr any problems before either
BMW 335i e93 M-sport 2007 AT Alpina B3 TCU, JB4 G5 whit MHD BMS backend flash pump
Default 07-07-2016, 01:49 PM
Martial, does this apply for BEF users as well? Been having an issue with low rpm jerkiness coming off throttle. Particularly noticeable in lower gears. 6MT. Also throttle jerkiness with cruise control downhill. Really annoying.
N54 | Build Thread
krazi3azn krazi3azn is offline
Default 07-07-2016, 05:48 PM
When the burble option first came out, I was on aggressive 2 seconds and it popped and burbled like crazy loud
Now on the newest update (v1.40) I'm on 2 second base hard and it's a lot quieter and only burbles (when I tried 2 sec base and sport, nothing happened).
Manual transmission
gixercho's Avatar
gixercho gixercho is offline
Default 07-08-2016, 12:29 PM
I cannot upgrade to 1.40. When i open the link and click to install it shows that i am in the program, but there is no upgrade.
PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 07-08-2016, 10:51 PM
I loaded up the new MHD burble option with settings at 1.5 second duration and soft aggressiveness. My mods are in my signature and my exhaust setup is fully ********* with the BMW performance exhaust. I'm loving the new burble option Thanks Martial.
SOLD - FBO N54, Pure Turbos stage 2, TFT inlets, JB4/MHD, EOS intake manifold w/PI, Fuel-it stage 3
Default 07-09-2016, 11:21 AM
Added some code to the JB4 firmware to switch to map 0 (and flash the blinkers once) if you connect the MHD and try to flash the car. To avoid support problems when people forget to put the JB4 on map0 before flashing and get confused. Tested it on our development cars and its working well. If anyone has time to test it out firmware is attached.
gixercho's Avatar
Default 07-09-2016, 12:15 PM
It will be very cool feature if the burble could be reproduced during upshift, like CLA 45amg for example. Better only in sport mode.
tofu tofu is offline
Car: 335i e92
Default 07-09-2016, 12:23 PM
That farting sound?
TactileTurn TactileTurn is offline
Car: 2009 135i MT
Default 07-09-2016, 12:47 PM
Anyone happen to had a DCAN cable in DFW? Trying to get a single turbo car running ASAP. Message me here. I'll buy it, I'll borrow it, I'll even pay a crazy rental fee.
Poppowisch's Avatar
Car: BMW e93 335i
Default 07-09-2016, 01:26 PM
Added some code to the JB4 firmware to switch to map 0 (and flash the blinkers once) if you connect the MHD and try to flash the car. To avoid support problem when people forget to put the JB4 on map0 before flashing and get confused. Tested it on our development cars and its working well. If anyone has time to test it out firmware is attached.
Nice work Terry! it happened to me last week, I managed to solve it
Keep up the good work!
Default 07-09-2016, 03:18 PM
My car will do this sometimes on the upshift if I'm shifting like a granny. Could be cool if it was more reliable, but not sure if it would be annoying.
N54 | Build Thread
Default 07-09-2016, 09:11 PM
I figure it will be more of an issue when people want to turn on and off the exhaust burble which can only be done via a flash time option.
pepper135i pepper135i is offline
Car: 135
Default 07-10-2016, 12:00 AM
Hey terry!
I never had this issue but I figured I would give your update a try .. I was a bit scared to test it, but I left jb4 on map 5 and attempting to a new MHD backed .. Worked like a charm ! Jb4 auto switched me to map 0 and continued the flash ! I did not see the blinkers flash, but I may have missed it when they did.. Also would like to add after the flash was completed my jb4 auto switched back to the original map I was on! Pretty sweet !!! Thanks again for your continued support !
Car: BMW E92 N54
Default 07-10-2016, 06:32 AM
Ok Now, I missed out the second duration slider, the burble same as befor nice work, but the jerkiness still, and i'm having it before the Burble option.
joeinsd joeinsd is offline
Car: 2010 e92 335i msport
Default 07-12-2016, 01:46 AM
Yes! Thank you Terry! I've managed to screw it up once before, too. Lol. Will load this up soon!
AngryDick's Avatar
AngryDick AngryDick is offline
Car: 2007 BMW 335i Coupe
Default 07-12-2016, 07:22 PM
This might be a bit of a noob question so I apologize in advance; I currently have the JB4 blue tooth setup so it runs through my iPhone. With the backend flash coming from my android device (Samsung Galaxy Tab4) do I need to install the JB4 app on the Galaxy? Or can I continue to run it on my iPhone for data logging, etc.? Does the cable that connects into the Galaxy provide power? If so I may just find a good place to mount it and use that for data logging and monitoring.
07 335i BMS DCI, BMS Cowl Filters, BMS JB4, BMS Meth Kit, 3" C*tless Down *****, Full Exhaust, BMS Wheel Spacers, BMS CP and Tial BOV, OZ Bronze Ultraleggera Staggered 18s on Potenza RE71R,
Need4Speed
Default 07-12-2016, 07:30 PM
Just use your Galaxy for flashing. Use your iPhone Bluetooth for JB4 stuff.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 07-13-2016, 01:34 AM
Yep, just make sure you have MHD 1.40, check the flash options and rewrite.
Manual transmission
The latest version is more progressive and thus the interpolated timing is a bit less reduced. I'll need to add a new "harder" setting.
To anyone willing to help testing the map 0 switch, you can first test the map 0 auto switch feature by plugging in MHD and do "read codes". It will send the same message to the DME that the JB4 notice and use to switch to map 0. Or MHD store, or anything that requires a connection to the DME in MHD like reset adaptations.
I am glad you're testing this automatic map 0 switch I suggested 2 weeks ago per email. You're right, adapting some settings to be modified on the fly is definitely on our list of things to develop.
N54_liam N54_liam is offline
Car: 135i e82 n54
Default 07-16-2016, 10:23 AM
When i connect to jb4 mobile app and go to settings, read only, it doesnt give me any ecu related info. How do I find if I am msd80/81 ijaos i8aos or whichever version it may be.
Current: M140i
Previous: N54 - Forge BOV - Forge Chargepipe - Airtec Intercooler - DCI - VRSF - JB4 - LCA
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 07-16-2016, 11:40 AM
If your car pre 03/2008 it's MSD80 of newer it's MSD81
Currently Active Users Viewing This Thread: 19 (0 members and 19 guests)
