MasterWang MasterWang is offline
Car: 2007 335i e92
Default Half engine light but no codes - 12-03-2014, 09:18 PM
I've been getting half engine light at the end of my WOT pulls in 3rd gear.
It goes away after about 5 seconds and no codes are stored. I don't actually get reduced power, just the light that comes on and goes away after a few seconds. Does anyone have any idea why it is doing that? I've never had this issue before.
Mods are Jb4 and dci with 45-50% e85.
I know map 7 isn't recommended, but I was trying it out to see if I get the light on this map. Map 5 with less e85 gives me the half engine light as well.
Default 12-03-2014, 09:23 PM
Sure auto clear is off?
Car: 2007 335i e92
Default 12-03-2014, 09:25 PM
Yeah I made sure it was off.
Car: 2007 335i e92
Default 12-04-2014, 02:32 PM
Just ordered the Fuel-it Stage 1 kit.
Putting the e85 flash on this weekend so I will also check for codes using the BT cable and see if anything pops up.
Car: 2007 335i e92
Default 12-25-2014, 03:31 AM
Put the e85 backend flash on and installed Steveaz's stage 1 lpfp kit.
Still getting the half engine light at gear shift :/
Jb4 doesn't show any codes and neither does my BT cable software.
Car: 2007 335i e92
Default 12-26-2014, 04:02 AM
Anyone..?
I can't be the only person experiencing this right?
Russell @ BMS's Avatar
Car: 2009 335i AT
Default 12-26-2014, 10:36 AM
Log looks good. Without a code.... no idea what the DME does not like.
Levan-i's Avatar
Levan-i Levan-i is offline
Car: 2007 BMW 335i E92
Default 12-27-2014, 11:02 PM
look at shadow codes with inpa?
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
Car: 2007 335i e92
Default 12-28-2014, 11:54 AM
I've checked the shadow codes as well. Nothing was stored.
Since it happens right after a shift, maybe its transmission related?
I do have the transmission flash done, but I've had it for over a year and this issue recently started happening.
mattjustus317 mattjustus317 is offline
Car: 2008 bmw 135i
Default 03-25-2015, 02:34 PM
bump on this i know its been A while but I'm having the same thing only throws code when i shift from 3rd to 4th at like 5,500 rpm i have the juice box and a macbook so i haven't been able to log anything but it goes into limp mode, i plugged in obd2 and shows no code them when i turn the car on and off the engine light clears... help i can do it every single time without fail.
Car: 2007 335i e92
Default 03-26-2015, 11:07 AM
My issue only occurred when I was using the e85 backend flash.
As soon as I flashed to a custom flash it went away.
FYI, there is a 3rd party Jb4 program for macs.
Car: 2008 bmw 135i
Default 03-26-2015, 04:00 PM
i haven't been able to find the third party firmware could you help out?
and if i have a boost leak could that trigger it because it first happened when i blew off a front mount coupler but i thought i had it fixed but it just started happening again
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 03-27-2015, 09:51 AM
could try lowering the boost on gear changes...
Car: 2007 335i e92
Default 05-20-2015, 01:49 PM
I put on Terry's latest e85 Backend flash yesterday and this issue came back immediately :/
Here are my logs from yesterday.
Latest Backend flash and Jb4 firmware ISO_29.
Jb4 G5 ISO, DCI, 255 inline, e70-e75, e85 backend flash, map 7.
CHECKERED's Avatar
CHECKERED CHECKERED is offline
ex deus machina
Car: E92 N54 335i
Default 05-20-2015, 01:58 PM
set boost fail safe to 21, since there is some overboost post shift
Garage Queen: Audi S4 4.2L V8, Vortech Supercharger, Bilstein PSS9 Coilovers, Sway-bars, RS4 brakes and rear BBK, Fast Intentions - Full Exhaust, 505AWTQ 0-60: 3.8s
Daily Driver: E92 335i N54: complete part out - let me know of any parts you need:
https://www.n54tech.com/forums/showthread.php?t=55650
Car: 2007 335i e92
Default 05-20-2015, 04:48 PM
Tried boost fail safe @ 21 today, didn't work.
CHECKERED's Avatar
ex deus machina
Car: E92 N54 335i
Default 05-20-2015, 05:03 PM
I think the DV you have are sticking and not venting sufficient boost,
Default 05-20-2015, 06:16 PM
Turn off code clearing and see what the code is.
Car: 2007 335i e92
Default 05-20-2015, 09:32 PM
Code clearing is off.
Here is a video I took today. Can't really see the screen I guess, but the only code I had was the golf tee mod one.
bmartynowicz bmartynowicz is offline
Car: 335ix
Default 04-27-2017, 02:22 PM
I know this post is old, but I am having the same thing happen to me AND I have almost the same configuration. I have a COBB charge pipe, and JB4 w/ DCI. About to put some exhaust on but the car is behaving weird.
Default 04-27-2017, 09:14 PM
I'd suggest starting your own support thread and posting logs.
