(#1376)
philipf22 philipf22 is offline
Default Argh, just failed emissions in CA - 09-26-2013, 03:46 PM
Hi Terry,
Just moved from IL to CA. getting my car smogged. I put the OEM cats back on as well as my intake (since no carb sticker). I failed because three of my sensors showed "not ready". I had the JB4 running with code reset enabled. I think that is what did it. I'm now driving on map 0, code reset is still enabled.
1) Does map 0 also disable code reset? I believe it does but want to confirm
2) Any knowledge on how long it takes for those sensor codes to "learn" or become ready?
3) I still love my JB4 and it is worth this small pain to pay.
braunstein82 braunstein82 is offline
Car: 2007 335i sedan at
Default 10-08-2013, 11:58 PM
Just got 2.2 gal kit. Can't find any install video or reference photos on best location of solenoid, hoses and wires under hood. Sorry but pdf is very limited an mostly ww kit. Also picked up a 5 gal container of renagade 100% racing methanol. After reading some of previous post looks like I may have got wrong stuff not sure. If it is ok to use do I still mix it 50/50? If I use stock cp do I need to take it off to drill and tap it so particals won't get in engine. If so will i need new hose clamps, what size. Thanks for any help I get.
Terry just a recommendation add a upto date pic of what should be in each kit (ie. Brackets) and list of things that may be needed that aren't included (ie. Teflon tape, 1/8 tap, tools)
Also can someone explain menu 9/0-8 meth boost additive. Is that how much boost above 13 lbs while on map 3
