(#8976)
erwan35's Avatar
erwan35 erwan35 is offline
Car: bmw 335i e92
Default 04-06-2015, 11:27 PM
Everyone i need help please.
i just install jb4 g5iso and wanting to stack with cobb ap v2. so i put on map0 then tried to install the cobb. it says cannot connect bla2. only happens when ignition is on. its like jb4 is stopping the cobb to program. been repeating it so many times and still failing,
please anyone help.
my car is bmw 335i e92 2007 6at rhd
Fully FBO w pump gas
_______________________________________\\\
BMW 335I E92 2007 RHD 6AT,FULL M3 BODYKIT,HYBRID TURBOS,BMS ADAPTER W/ 3.5BAR TMAP,VTT INLETS,JB4 G5ISO W/ MHD TREBILA FLASH,BMS ANTI-LAG,AEM METH KIT W/ FSB,BMS DCI,VRSF CHARGEPIPE & TIAL BOV,VRSF C@TLESS ***,FMIC,BMS OCC,BMS CABIN FILTER,MUFFLER CUSTOM BULLET,97RON PUMP GAS
erwan35's Avatar
Car: bmw 335i e92
Default 04-07-2015, 07:20 AM
anyone??????
Default 04-07-2015, 07:39 AM
Originally Posted by Cloud9Blue
lol, didn't realize the boost on map 2 was raised significantly for guys using 4/3 w/ backend flash... now that I have a persistent cylinder 5 misfire. free engine sound mod I suppose, the car now sounds like it has a LS1 engine swap...
If using a back end flash use mode 4/2. Otherwise, you'll get whatever boost the flash has programmed.
samstryker's Avatar
samstryker samstryker is offline
Car: 2008 535xiT e61
Default 04-07-2015, 09:20 AM
Anyone know if the latest interface available for mac yet? is version 1.5.2 the latest?
2008 e61 535xit: VTT GCs, Fuel-it PI, fuelab FPR w/ return line, stage 2 lpfp, fuelab "700" inline pump, RB external PCV, VRSF 7.5" race FMIC, Inlets, outlet, AR ***, 3" chargepiping, 3" exhaust, JB4, BMS PI controller
Car: 09 E92 335i
Default 04-07-2015, 11:30 AM
meant to type 4/2 actually, but it would be nice if you could update the first page of this thread to reflect the changes to the boost curves for maps in 4/2.
Shafer Shafer is offline
Car: 2008 e90 335i 6MT
Default 04-07-2015, 01:13 PM
See the thread for 3rd party JB4 interface.
He's not working on the OSX version for a few weeks, he's more involved in the Android and iOS versions right now.
Bullitt1841's Avatar
Default 04-07-2015, 06:34 PM
You can wait. It's not a big bug but no reason not to fix it. I also altered the fuel trims calculation to reflect 0-34% so JB4 logs match the rest of the world, and made LOAD a full time logging parameter (removed not obsolete CPS), so I'll be posting 28.8 shortly for you guys to test out.
I might have missed something, but are we now not able to log fuel trims as negative (-) percentage? Before, a value below 8 would indicate a negative (-) trim.
Default 04-07-2015, 07:00 PM
Correct can't see below 0 now. Sorry, something had to give there. Tired of the confusion as to how trims would exceed 33%.
Stucks Stucks is offline
Default 04-07-2015, 07:16 PM
updated to 28.81 firmware version, and i had my first gear boost limit set at 9.0psi and 2nd gear limit set at 14.0 psi. upon plugging in my laptop after driving around for a little bit, i noticed they had gone up and down .1. so i reset the 1st and 2nd gear boost limiting to 9.0 and 14.0, but each time i do that and save settings, they reset back to being down by .1 and up by .1. possible bug?
Current: 2008 e92 335i coupe.
Default 04-07-2015, 07:40 PM
What TMAP sensor are you using?
What interface/app are you using to upload firmware?
Default 04-07-2015, 08:08 PM
That is what happens when you squeeze a 0-360 word in to a 0-255 byte. Some decimal points will round up or down.
Default 04-07-2015, 08:09 PM
Now that we have separate maps for the back end flash I'm working on a stronger map 7 for you guys. If anyone is bored and feels like testing it just email me.
Default 04-07-2015, 08:33 PM
Dmac told me it was due to the 3.5 bar TMAP sensor conversion and a rounding issue.
Default 04-07-2015, 08:36 PM
Stronger in the flash or stronger in the JB4 firmware? I guess what I'm asking...is there more boost or more timing?
Default 04-07-2015, 08:37 PM
Same flash, more boost.
Car: 2013 Genesis Coupe
Default 04-07-2015, 10:58 PM
Idk if you still want logs, but here are some logs with the 28.81 firmware,everything seems to run smoothly on my end. I took the liberty to reread the 4/2,4/3 setting I have couple questions for you Terry. Just outta curiosity before this change took place, on the default setting 4/3, wasn't the JB4 safety enabled (Map 4) even with the flashed cars? My second questions is, so since the JB4 controls boost, does the flash control everything else such as, timing advance, afr, etc.. Also, if there was knock to be detected, would the flash or the JB4 reduce timing and how much timing can it actually reduce?
Default 04-08-2015, 07:40 AM
You should find answers to those questions in the open flash thread. This thead is re: JB4 firmware.
Default 04-08-2015, 11:28 AM
Just posted an interface update. The new interface date is 4/6/2015.
The changes are minor and have to do with time stamps in the logs. We found a little bug that could cause the timestamps to be inaccurate. e.g. it might put samples 80ms apart instead of 100ms apart, or the other way around, depending on how many data points the JB4 firmware version happened to be spitting out at the moment.
While not much of an issue it would throw off time to RPM calculations, etc, that I know some like to do within 3rd party software like virtual dyno.
So I fixed that and also setup the interface take the sampling rate from the JB4 firmware rather than being fixed at 10hz. So the interface can support up to 40hz now. Currently the JB4 firmware is still set at 10hz (even though some elements like boost, pedal, and fuel pressure are read at 200hz), but in the future we will be able to play with that sample rate output on the JB4 firmware side.
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 04-08-2015, 12:54 PM
So with this new firmware how are the maps different for us backend flash people?
09 335 - 6266
07 335i - 6870, E85 - SOLD
P1Jay's Avatar
P1Jay P1Jay is offline
Default 04-08-2015, 05:34 PM
Terry, once done with testing will this be available via JB4 firmware update?
Default 04-08-2015, 05:36 PM
So far it's been stable so I expect to post 28.82 soon. If you want it sooner just email me. The only real difference between it and whats posted is map 7 when using a back end flash map.
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 04-08-2015, 05:59 PM
It's more noticeable with the N20 sensor due to a smaller scaling value. You have to have a wider range of values for the N20 sensor and that causes a loss of resolution. Not a big deal though.
jwdominick's Avatar
jwdominick jwdominick is offline
Car: 08 535ix
Default 04-08-2015, 06:15 PM
I'd be interested in trying the new map 7 changes Terry. Email is Jwdominick@yahoo.com thanks!
'08 535xi 6m, ACT 6 Puck Race Clutch / AR Design DP's / AFE Twin Power DCI / VTT Inlets / VRSF CP / TIAL BOV / Big Tom style IC / Fuel-It Stg2 LPFP / NGK 5992's @.022 / N20 T-Map / MHD Flash....100% e85 @24psi on stock snails!
Default 04-08-2015, 07:18 PM
You do realize you don't have to publicly post your email address, right?
jwdominick's Avatar
Car: 08 535ix
Default 04-08-2015, 07:24 PM
Meh spam filters work. It's not a private thing...
