HydroStream6 HydroStream6 is offline
Car: 2010 335i xDrive Sedan
Default N63TU JB4 Settings? - 03-18-2019, 09:39 AM
I just installed my S63TU (with BCM) JB4 on my 2014 50i X5. I've installed the N63TU firmware in the F-Series thread in this forum. However, in that thread, Terry mentions settings that need to be changed, and I don't know what those settings are. I do have a Bootmod3 Stage 1 flash on the vehicle as well (no other mods). I installed the JB4 TMAP, OBDII, and the boost solenoid connections, and I unplugged the MAF sensors. I have a few questions.
1. What are these special settings that need to be loaded? I've attached the current settings.
2. I'd like to run the JB4 with the BM3 flash. Do I need to set anything special on the JB4 to do this? I used to have to select BEF in the JB4 on my E90.
3. Will the JB4 target absolute boost or in addition to what the BM3 flash commands?
4. Can I run "flash only" by setting the JB4 to Map 0 or 4 and then plugging the MAFs back in and use the JB4 only for logging?
5. Will I need to add fuel pressure connectors, or is that not needed any longer? I do want to run ethanol mixes, part of why I want the JB4.
6. Anything else I should know?
Adam
Default 03-19-2019, 05:19 AM
Also, is this map guide still accurate? I assume I can still use map 6 and define it myself?
Map0: JB4 disabled
Map1: Additive map, up to 5psi requested over stock
Map2: Absolute map, 19psi peak
Map3: Absolute map, 18psi peak
Map4: Stock with CANbus active for logging and in dash gauges
Default 03-19-2019, 08:43 AM
Since the car is flashed first step is to record a log on map0 so we can check it out. I'd run TMAP and OBDII only to start, without BCM connections.
Default 03-19-2019, 08:47 AM
Thanks Terry. I really don't want to disconnect those BCM connections. I'll get a log and post it today.
Default 03-19-2019, 08:48 AM
I'm also not against flashing back to stock if that'd be better? I'm still within my BM3 return limit, so if the jb4 works nicely alone, I could get my $895 back.
Default 03-19-2019, 11:33 AM
OK no worries if they are on leave them. But I want to see some data before suggesting how we go about the tuning since it's flashed currently.
Default 03-19-2019, 03:53 PM
Two logs attached. Map 0, MAFs unplugged, Bootmod3 Stage 1 tune, 93 octane, all else completely stock. 2014 F15 50i.
I have access to E85 and I'm not afraid of going meth, *********, etc. Let me know what you think. Thanks!
Default 03-20-2019, 10:32 AM
Ah I see it's a V1 board. Did you buy the JB4 new? We may need to change that to a V2.
But so far so good. For the next piece of data grab a similar log on map1.
Default 03-20-2019, 06:12 PM
Thanks Terry. I did buy the JB4 used. I've bought my N54 and N55 ones from you though.
Two logs on Map 1 attached! Let me know what you think. I'm curious why the AFR goes way lean at the top end of the one log when the RPMs start coming back down, but still under boost. I felt this when I was driving.
Thanks again,
Adam
Default 03-20-2019, 06:48 PM
Looks like map1 is working as intended.
Fuel is cutoff during shifts so that is probably what you're seeing on AFR. Fuel trims look fine here.
For a setup like this should really have a V2 system I think. We're not doing any more V1 firmware updates, and the by bank boost control would be useful. We have upgrade kits for $200 if you need.
Default 03-20-2019, 06:54 PM
Thanks Terry. I'm not against upgrading. Do you think the flash is helping me, or should I get my $900 back and get the V2 and meth?
If I keep as is, can we try more boost as is or with some ethanol mixed in?
Default 03-20-2019, 06:55 PM
Or if the flash and V2 together are more powerful, I can do that too...
Default 03-21-2019, 01:25 PM
Mixed in 5 gallons E70 with a full tank of 93. Same settings as above, 0-100ish. Did 0-60 in 3.79 on Dragy.
Default 03-22-2019, 08:30 PM
Your bank to bank boost is pretty decent so the difference wouldn't be huge. But worth the update I think.
You're at 20psi here and there is room to go on fueling and timing, maybe need some 3.5bar TMAP sensors too? Stock sensors cap out around 21psi.
Default 03-23-2019, 03:17 AM
I'll get some map sensors on order �� I'm going to flash to stock this weekend and do a few logs and post them up as well. Thanks again!
Default 03-23-2019, 06:10 PM
I'd keep the flash, seems to be working fine! Good call on the sensors though.
Default 03-25-2019, 09:06 AM
Ordered the map sensors from you Terry. When they come, what's next? Map 2? Map 6?
Thanks,
Adam
Default 03-25-2019, 09:28 AM
I'm working on some firmware changes for the N63TU but they are only via the V2 board, which was why I wanted to get you kicked over to that.
But in terms of the V1 board next stop map2 and if clean then a custom map6.
Default 03-29-2019, 06:26 AM
Hi Terry!
My TMAPs get delivered today. I must say, I'm a little nervous reading about guys slinging rods out of their S63TUs (granted I'm N63TU). I understand anything can happen, but are you fairly confident Map 2 will be safe with my flash or should we shoot for a Map 6 and skip over Map 2 to keep the torque down a hair? Map 1 seems to be commanding 20-21 psi and I'm still running E30ish.
Let me know your thoughts!
Thanks,
Adam
And the truck is an animal BTW!
Default 03-31-2019, 12:08 PM
Terry?
Default 03-31-2019, 03:38 PM
You can log map0 with the 3.5bar TMAP sensors on if you want to start. Entirely up to you.
