Tallicia Tallicia is offline
Car: E88
Default N55 Alternator Pulley Removal - 10-27-2018, 05:36 PM
Has anyone removed the Pulley from the alternator on the N55?
I have been chasing some noises from the belt area and have replaced all pulleys, the tensioner, the power steering pump, and the A/C compressor pulley with bearing and clutchless damper.
The only thing I have not swapped yet is the alternator pulley.
The second pic is the one I have ready to swap, I am just unsure of which way to turn the inside bolt/shaft(?) and the outside pulley. From the first pic, to I turn the big outer hex counter clockwise (left) and the inner small hex clockwise (right) ?
The new one I have with splines instead of the hex has me a little concerned, but hopefully it's fine just a little different.
