Tallicia Tallicia is offline
Car: E88
Question 87F2 C902 7753 codes 2EF2 2EF3 - 08-13-2018, 09:44 AM
I am getting the following codes
87F2 C902 7753
How can I find out what the first 3 codes are. there seems to be no definition for these anywhere.
I suspect the valvetronic motor is not fully up to spec. I'm in the process of getting INPA-D to try to relearn the stops or confirm the motor needs be replacing.
Occasional 2EF2 2EF3 - I have replaced the plugs and coils for 4,5,6 and verified the gap. I suspect the injector may not be 100%. or the above issue with valvetronic motor is causing this.
2011 135i E88 N55
