rdef rdef is offline
Car: e92
Default 11-28-2017, 07:41 AM
Originally Posted by Rushan
replaced both front O2 sensors, still randomly I get 2C31 or 2C32 , no cell display but I can feel it when it happen and read it form JB4 and delete it.
i'm suspecting this related to JB4 firmware or BMS MHD flash,
my friend also getting same O2 errors he is on JB4 and BMS pump flash and im same but with race flash and meth
Replacing front sensors did not help. Replacing rears too did. I'm not sure if the rear sensors were the actual problem. When I replaced the rears I also replaced the gaskets at the back of the down *****. It was clear by looking at them they were leak pretty badly.
My sense is the gaskets were a contributing problem at a minimum. The gaskets that ship with down ***** are thin and cheap. After a period of time they start leaking and along come these codes. OEM ones are very thick and are $30 each.
Maybe try gaskets first.
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 11-28-2017, 09:32 AM
You'd probably be able to hear an exhaust leak that would affect 02 error codes.
The codes for 02 in front of catalytic converter only apply to the sensors near turbo.
Do you have any *****, or other *****-type settings on via MHD, etc?
2017 AMG C63 -JB4
2009 535i - 548whp - sold
Car: e92
Default 11-28-2017, 09:55 AM
I as far as I can tell the comment about those codes being related only to the front sensors is incorrect. I know it makes sense, but I’ve seen a number of posts out there indicating that if the rear sensors are not working the front ones cannot calibrate, despite a tune that “ignores” the rears. I can tell you for certain that I replaced my front o2s and the codes did not go away. As soon as I changed both back o2s all codes went away.
The codes were being thrown on all stages of the MHD tune.
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 11-28-2017, 02:58 PM
I will double check the gasket but I'm sure i tight it and no visible leak or noise. But can double check and re-tight again
Rushan's Avatar
Car: 335i E92 2009
Default 11-28-2017, 03:03 PM
I have the last BMS race flash perior to the Dppps error change so I should be fine with it, the issue that it not showing cell error but I can feel when the error happens as it little jerk and when I read from JB4 the error is there and can be deleted, I notice it happened on cruising on high gears mostly when I give it little throttle that why I'm suspecting it JB4 or flash related more than actuall O2 fault even I replaced them both just to make sure, also my friend having same fault on BMS pump flash so I guess it's not O2 sensor
cebrailbakan's Avatar
cebrailbakan cebrailbakan is online now
Car: BMW E90 335XI
Default 11-28-2017, 04:11 PM
Try removing Jb4 board and check if touches anywhere and causes a short circuit , hope this makes sense.
Do more with less !
Rushan's Avatar
Car: 335i E92 2009
Default 12-02-2017, 05:56 PM
I was thinking to recheck and clean all the JB4 subcontractors if it doesn't work I'm planning to roll back on firmware or flash and see to eliminate those 2 also
Default 12-02-2017, 06:21 PM
JB4 log?
Rushan's Avatar
Car: 335i E92 2009
Default 12-03-2017, 03:15 AM
JB4 log?
Hi Terry, I just reset the lambda adaption to override the error, ibwill take 100 mile to start again so I will log and post both with adaption reset and after when it start the errors
Rushan's Avatar
Car: 335i E92 2009
Default 12-11-2017, 02:51 PM
I was checking something with my bms race flash and noticed on the flash xdf there is 4 tables for the something O2 and use single rear O2 which for some reason they were enabled I guess value 56 which to disable should be 00
I thought I was running the previous flash prior to the latest flash that been set to enabled of the o2 for emission compliance.
So do i need to set them to disable 00 and could that be the reason that I was getting random 2c31 and 2c32 on jb4 read error but not CEL? Or that irrelevant?
accler8 accler8 is offline
Car: 08 335i
Default 2c31 error message - 02-06-2018, 08:11 AM
Hi Rushan,
Were you able to fix this code? I am getting this error code. Changed all the sensors too. Please let me know.
i am due for emissions and need this fixed to pass emissions. Any help is appreciated.
Thanks,
Sunil
Default 02-06-2018, 08:56 AM
Log? Reset adaptions?
LessIsMore's Avatar
Inner Circle Member
Default 02-06-2018, 08:04 PM
I suggested that 02 settings in the tune might be responsible earlier. So did Steve. Seems that was the issue.
I am assuming OP got it resolved with what his last post mentioned, since he hasn't posted back here.
2017 AMG C63 -JB4
seanm135's Avatar
seanm135 seanm135 is offline
Car: 2010 e90 335xi
Default 02-22-2018, 06:04 AM
Rushan - Sent you a PM but never heard back... Were you able to fix this? Was it the flash settings and, if so, did your buddy running the PUMP BEF also fix his?
I have the same issue.
2010 e90 335i xDrive - M-Sport - Premium - Cold Weather
JB4 - AFE DCI - VRSF 3" ** - VRSF 7" FMIC - Cobb CP - Bilstein B6/Eibach Pro-Kit - Staggered Klutch KM-20 19"
Rushan's Avatar
Car: 335i E92 2009
Default 02-23-2018, 01:50 PM
Ok here how I solved my issue, front new O2 didn't help and didn't remove the front O2 errors hence the error refere to front O2.
Rear working OEM didn't sort it and I tried to give those bosch universal with quick connector a try from Amazon as they 41.7 USD each so I bought 2 ( Bosch 15733 Oxygen Sensor, Universal Type Fitment) and it worked perfectly, didn't even reset adaption and error went away and car running smooth for almost 2k miles,
My friend had same front O2 error we also did the same to him and it also worked perfectly no more error.
For some reason the front o2 error is related to the rear O2 and those Bosch O2 worked perfectly and they are way cheaper than OEM and identical. You transfer the heat shield from your original rear sensor and connect to the same old c9nnector.
Cheap fix that works 100% and cost 83.4$ for both
