(#26)
Default 04-05-2017, 03:40 PM
That is incorrect... It goes on one of the JB4 red wires going to the TMAP sensor.
inevitab1e's Avatar
inevitab1e inevitab1e is offline
Car: 2013 N55 135is
Default 04-05-2017, 03:45 PM
Crap, I wonder if this has any effect on the performance of the vehicle. Do you have a picture of the wires/install? I'm wondering where you're connecting/inserting the splitter.
I have 2 red wires coming out of the JB4 to the sensors. Which one should I connect the BT kit to?
2013 E82 135is N55 JB4-BEF FBO
Default 04-05-2017, 11:27 PM
Either red wire in that bundle.
Xer0449 Xer0449 is offline
Default 04-06-2017, 09:51 AM
Can we get a sticky about this (or an update in documentation for the connect kit)?
'12 N55 e82 | MEVD1762 | DCT | CP | d0wnP1p3e sans meow | 7" IC | PPK1 | PE | JB4 ISO | BMS OCC | BMS Intake | PS2 | Stg2 LPFP | N20
Waiting to go in: BMS WMI kit
Default 04-06-2017, 09:38 PM
I took that picture from the first post of the 3rd party app thread that is stickied.
tho's Avatar
tho tho is offline
Car: 2011 335i Convertible
Default 04-07-2017, 10:26 AM
WARNING - DO NOT USE THE ATTACHED INSTRUCTIONS!!
I also had it installed to the 12v power from the JB4 and have been having connection issues where I can connect, but eventually the readings will freeze and I have to reboot it. Even then it doesn't always come back. It was something that I was going to look into this spring as the car is just coming back on the road.
I've been trying to figure out how I screwed up a 1 wire install especially with the pictures shown in this thread. Then I found the install instructions that I used when I installed my connect kit in July/Aug last year. I've attached it to this post. The instructions clearly direct you to wire it into the JB4 power wire. I'm going to send a message to the creator to see if I can do something to find out if I fried my connect kit.
Default 04-07-2017, 11:03 AM
Yup! This is what I followed as well, and ended up with the same problem. Good thing I didn't go changing parts around thinking something was wrong when it was just the instructions
Stoolz Stoolz is offline
Car: 11 135i
Default 06-18-2017, 04:52 PM
Damn back to report I still have those initial codes as per op AND my bt kit has been swapped back to 5 volt.
Any chance the bt module can be damaged? It went away for a few months and has now come back after pulling wiring apart for pi connection.
Default 06-18-2017, 06:25 PM
Where did you find those directions exactly?
Car: 11 135i
Default 06-18-2017, 10:45 PM
Ive bought a replacement rev3 see what happens eh
tho's Avatar
tho tho is offline
Default 06-19-2017, 09:07 AM
Unfortunately, I don't know exactly where I downloaded the directions from. I must have downloaded the instructions either at the time of purchase or when it got delivered. But from where I can't remember. Sorry.
