(#51)
e46eric's Avatar
e46eric e46eric is offline
Car: e93 335i N54
Default 04-14-2017, 11:18 AM
Will start with the pump flash with E30 and I'll post logs.
- reset any adaptations after the flash?
- best Map to drive on? I'm normally on Map2
- If one day I'm forced to fill with only 93-oct with an ethanol BEF, and don't have my OBD2 cable with me to flash back, what harm will driving on it cause?
- Eric
Default 04-15-2017, 03:34 PM
- you can...it won't hurt.
-map 2 is fine to start then.
-don't drive aggressively until you can change the flash or add more ethanol.
e46eric's Avatar
Car: e93 335i N54
Default 04-16-2017, 09:13 PM
I loaded the pump flash tonight and the car drives well. It's on Map 1 for now and feels strong, peaking about 17psi. I haven't put in ethanol yet I want to verify everything is working properly first.
- Should I still need to lower my FOL? I haven't red-lined WOT 3rd gear yet. before the BEF it threw fuel pressure codes.
- Should I raise menu 12 back up now or leave it? It's at 2200. Pre-BEF I never resolved the boost oscillation even after dropping it that low. My boost surpass the target boost, and it looks like it still over-shot in 2nd gear.
- Any other suggestions about the log ex: timing? Thanks, happy easter
Eric
- Eric
Default 04-17-2017, 12:16 PM
Looks okay so far...try a longer log.
e46eric's Avatar
Car: e93 335i N54
Default 04-17-2017, 08:55 PM
Since the BEF, the boost oscillation is non-existent. I'm thrilled and the smile is finally back on my face. Thanks for all of your help about that I very much appreciate it.
Okay, first logs on ethanol, E30 on the pump flash. I'm on Map 1 and I'll go to Map 2 if you think it's solid. My trims are slightly lower but still approach 40my. I also noticed my hpfp runs shy of 15 compared to 17-17.5 before the flash. Should I be worried about that
How do they look to you?
Thank you,
- Eric
e46eric's Avatar
Car: e93 335i N54
Default 04-17-2017, 08:57 PM
oops. guess I didn't click upload
- Eric
Default 04-18-2017, 10:47 AM
Fueling looks fine so far. If you add more ethanol, switch to the E85 flash.
e46eric's Avatar
Car: e93 335i N54
Default 04-19-2017, 09:19 PM
Will do. Still on my first tank of E30. Driving very strong however 3 times in 3 days the car threw the "engine malfunction" CEL because of:
- 30FE boost over target
- 3100 low boost mode engaged
I can tell you that all three times it happened at partial throttle cruising around, not full throttle. I wasn't logging at the time. I attached some logs from earlier today in case they are helpful. Menu 11 and 12 are both at 2500. Do you have any suggestion?
Thanks Steve
- Eric
e46eric's Avatar
Car: e93 335i N54
Default 04-25-2017, 04:32 PM
- bump.
... and we're so far from the original reason I posted that perhaps it's time to begin a new thread
- Eric
Default 04-25-2017, 08:46 PM
Set menu 11 and 12 back to default and see if that resolves your issue.
e46eric's Avatar
Car: e93 335i N54
Default kicked me to Map4 - 04-30-2017, 08:31 PM
Hey Steve - I tried E30 mix with map2 for the first time. I got the double blinker flash and kicked me to Map4 but no codes. Overboost it looks like
menu 10 - 3
menu 11 - 2500
menu 12 - 2200 (boost oscillation when set higher. put back at 2800 and clicked downward until oscillation stopped)
What can I adjust to help this, and is map5 a better option? I could switch to the E85 BEF (currently pump flash). Thank you!
- Eric
Default 05-01-2017, 08:59 PM
That's correct, you were overboosting and you need to raise your boost safety limit.
Lower FF to 60 and try a couple more pulls.
e46eric's Avatar
Car: e93 335i N54
Default 05-07-2017, 10:38 AM
I went to lower FF but found that it was already at 55. Did you mean FOL?
- Eric
Default 05-08-2017, 11:33 AM
No....it may have already learned down as it was at 80.
e46eric's Avatar
Car: e93 335i N54
Default 05-16-2017, 01:01 PM
Hey Steve - I took more logs in Map2, two are below. I'm concerned about HPFP and LPFP numbers in the short log but in the longer log they look okay.
I'm at 30% E85 with PUMP flash.
- I'd like to increase if the logs check out okay
- I'll flash the E85 back end too as long as running E30 on it won't damage anything.
- Am I better on Map2 or Map5?
- Any other notable observations?
(Also, I do not have a FMIC. I've always watched IAT and doesn't rise much since I never drive hard for long periods. I think the log below only rose ~27deg above ambient. I don't want to cook anything internally so how much rise in IAT is safe?)
thank you
- Eric
Default 05-18-2017, 11:01 AM
LPFP is crashing...that needs addressed first.
e46eric's Avatar
Car: e93 335i N54
Default 05-21-2017, 03:55 PM
In your opinion is an in-line pump enough? my plans for the car won't exceed e40, e50 tops. and stock turbos unless they **** the bed. Still would love to know if better drive in map 2 or 5. thank you
- Eric
Default 05-22-2017, 12:08 AM
Stage 1 is not recommend for use with ethanol.
If you want input on logs for map 2 and map 5 then post 2 proper 3rd gear logs.
e46eric's Avatar
Car: e93 335i N54
Default 05-29-2017, 09:00 PM
I was taking the logs you suggested (map 1) and the jb4 kicked to map 0 and the hazards stayed stuck on. I read the various reasons it could kick to map4, but why did it go to map 0? the log is blank and I couldn't dig up the answer in my searches.
and where is the setting to raise the boost safety found?
[I've been putting money aside for the stage 2 lp pump so that's coming soon. In the logs since, the lp numbers haven't trailed off like that luckily]. I hope you had a great holiday weekend. Thanks,
- Eric
Default 05-30-2017, 11:56 PM
Map 0 sounds like a JB4 reset. Maybe a bad power connection or the JB4 connect kit connected to the wrong power source. If so, it may have zero'd out all your user adjustment settings.
