(#76)
Pure Turbos's Avatar
Pure Turbos Pure Turbos is offline
Default 01-09-2017, 12:44 PM
Originally Posted by Stucks
I am using a jb4. are you referring to FUd bit7?
Yes
Stucks Stucks is offline
Default 01-09-2017, 12:52 PM
Originally Posted by Pure Turbos
Yes
ok, will try doing that and see what happens. Thanks!
Current: 2008 e92 335i coupe.
Default 01-09-2017, 01:02 PM
Try that and also set your DWP low.
Default 01-13-2017, 09:37 PM
Just to follow up, i tried what pure said with fud bit7....and lowered dwp. It no longer rattled with low dwp, but the rapid blow off is still there lol.
Newguy123's Avatar
Car: 12' 135i
Default 01-13-2017, 10:19 PM
Shooting the lasers 24/7 haha
18 Glacier white RS3
#PURETURBOS
#FUELIT
Default 01-13-2017, 10:42 PM
What do you have DWP set to? You may just need to go lower.
dawhiz's Avatar
dawhiz dawhiz is offline
Car: 09 335xi
Default 01-14-2017, 04:14 AM
After having installed inlets and noticing the unsmooth acceleration with it, I just paid for tuning and dropped the JB4. The custom tuning, having someone else do it, smoothed it out for me. No weird sounds. But I also run stock airbox.
Default 01-14-2017, 09:15 PM
I had it all the way down to 0 at one point during testing lol
Default 01-23-2017, 08:57 AM
Switched to a different bov (same orientation as oem style diverter valves...its a Tial qrj with 3 psi spring so its open at idle) and put a breather filter on the end so as to not suck in any debris. the car makes a normal crisp air release blow off noise when releasing the throttle after boost (no more weird howl) but still begins to rapidly blow off half the time while low throttle cruising. Starting to think maybe its not a valve issue like bradsm87 suggested, and more related to what pure has suggested.
TwistedTuning TwistedTuning is offline
Car: 2007 335xi 6MT Sedan
Default 01-23-2017, 09:35 AM
Boost I's exceeding boost request at part throttle. So what you are ď experiencing I's the results of the throttle fluctuating to control boost
"Increasing the Area Under The Curve"
Custom Performance ECU Calibration
www.twistedtuning.com
twistedtuned@gmail.com
Default 01-23-2017, 09:55 AM
Exactly.
It's in the tuning!
See post #59 where I explain the same thing, 2.5 months ago!
