Nicky92's Avatar
Nicky92 Nicky92 is offline
Car: 2008 335i
Default One more post for this on going issue with water pump - 01-06-2017, 10:22 AM
I've been having this problem for about a year now. With no progress.
Here's the issue.
When my car is COMPLETELY cold, the second I unlock the car and the water pump starts going, and it stays on for about 10-15 mins.
It's just going on and on.
I replaced the water pump and thermostat thinking it was that, like an electrical issue. Nope. Same thing is happening
No MAX cool is not on, No codes. I have checked the wiring.
I don't know what else it could be?
Any ideas?
335- stock
Nicky92's Avatar
Car: 2008 335i
Default 01-06-2017, 12:49 PM
E90post says it's my fuel pump. Lol so done with that forum
335- stock
blown07's Avatar
blown07 blown07 is offline
Car: 335xi, 335i
Default 01-06-2017, 01:50 PM
I had a problem with my water pump running after the car was shut off if I used the RST (residual heat button). Probably not related but something that could not be explained by anyone.
335i FBO,Meth,MHD,XHP3,LSD,GCLites 11.83@124.88
335xi FBO,Meth,MHD,XHP3,VTT stage1 11.38 1/4 - 7.30 1/8th - 3.35 0 to 60 @ 0C
Nicky92's Avatar
Car: 2008 335i
Default 01-06-2017, 02:01 PM
isn't that what it's supposed to do for the function
335- stock
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 01-06-2017, 03:41 PM
DME mosfets? What year is your car?
09 335 - 6266
07 335i - 6870, E85 - SOLD
Nicky92's Avatar
Car: 2008 335i
Default 01-06-2017, 03:51 PM
I was thinking about that. It's a 2008
335- stock
Milan's Avatar
Car: 08 335xi
Default 01-06-2017, 04:14 PM
That would by my guess because you said the issue happens when it's cold.
09 335 - 6266
Nicky92's Avatar
Car: 2008 335i
Default 01-06-2017, 04:29 PM
You think I fried it?
Would there be any other symptoms?
335- stock
Nexic Nexic is offline
Car: '10 335i
Default 01-07-2017, 03:54 PM
This happened to me, it was my water temp sensor on the oil filter housing. Seemed to be on the fritz but did not throw any particular codes. Once I swapped it out, the water pump stopped circulating constantly. My guess is that it sees something wrong with the sensor or temperature gradient and runs the pump at 100% to prevent a cooling failure. The gradient may still be within the tolerance of the DME and not throw a code, but thats just my guess.
Nicky92's Avatar
Car: 2008 335i
Default 01-07-2017, 05:35 PM
That's great I thought about that actually!
Def going to replace that
335- stock
Nicky92's Avatar
Car: 2008 335i
Default 01-12-2017, 03:35 PM
The sensor on the OFH is the oil pressure sensor btw.
The one under it on the cylinder head is the temp sensor
335- stock
Nicky92's Avatar
Car: 2008 335i
Default 01-12-2017, 05:14 PM
Welpp I changed it and it didn't work.
I am going to remove the Jb4 tomorrow and see if that helps, if not, I really don't know what else to do, looks like the only one with this on-going issue
335- stock
ibsr335 ibsr335 is offline
Car: E90 335i 6spd sold. Now 03 z06
Default 01-13-2017, 04:10 AM
It might be the IBS (negative battery cable) unplug the wire with the blue connector off the neg battery cable and see if it stops.
Nicky92's Avatar
Car: 2008 335i
Default 01-13-2017, 07:07 AM
I heard something like this. I will give that a shot later. Thank you
335- stock
Nicky92's Avatar
Car: 2008 335i
Default 01-13-2017, 01:28 PM
I unplugged it, still running.
Might have to reset adaptations. But I am going to remove the jb4 tonight, i have a strong feeling it's something with that.
335- stock
Car: '10 335i
Default 01-17-2017, 03:29 PM
Did you check the plug going into the thermostat? Make sure it is plugged in correctly and all the way in.
User Name User Name is offline
Car: E92 6MT N54
Default 01-17-2017, 04:18 PM
I typically hate the type of post I'm making here, but throwing it out there in case someone is going through what I did.
I had an issue where a bad alternator voltage regulator was causing waterpump, IBS and oil level sensor issues. Codes, low voltage mode, all sorts of issues. The moment I disconnected the data cable going to the alternator the problems cleared.
Pure Stage 2's | MHD + JB4 | 625/613
