(#26)
rleroy4298 rleroy4298 is offline
Default 09-08-2016, 11:57 PM
Update...still plagued with the fault codes below, however, I thought no harm in removing the PUMP BEF and uploading my original bin file so I went ahead and did that today.
2C6B code (Lambda probe behind catalytic converter, system check)
2C31 code (lambda probe in front of catalytic converter, trimming control)
I also short tested all modules with the BT Cable which came back with the results in the images below...most of these codes I was unaware of...anyone else have some experience with these? I went ahead and cleared these and reset adaptations within the BT Program as well...will see if anything pops up tomorrow.
Also, Steve, you had mentioned additional testing of the wiring/hardware and I was curious if there was any way this could just be done through one of the many lambda associated parameters logged within the BT software (i.e. image below)? Thanks again for the support!
Default 09-09-2016, 10:32 AM
Sorry, I don't play with the BT much.
Default 09-12-2016, 04:44 PM
Update: Removed the BB Pump Flash (02/23/16) and changed the appropriate JB4 Steering Wheel Control Setting back to 4/3 from 4/2. I have now driven 50 miles like this (fyi...*** still installed) and no lambda codes (2C31 & 2C6B) have been thrown. Seems like there was an issue with the PUMP Flash? ...strange as I've been going back and forth between BB Flashes (PUMP, RACE, & E85) & stock for years now never have experiencing any lambda related codes...
