Nicky92's Avatar
Nicky92 Nicky92 is offline
Car: 2008 335i
Default Water pump constantly running..just replaced it too - 04-19-2016, 09:51 PM
Had this problem where the water pump was running when the car was cold. Had 60k on the pump so I replaced it and the t-stat.
Did the job. Plugged the battery back in......... anddddd
ITS DOING THE SAME THING.
The pump is just running non stop. I can hear the coolant circulating. This is ridiculous.
and no one around has had this problem so I'm not getting anywhere with it lol. Looks like im off to bmw?
WONDERFUL
335- stock
veee8's Avatar
veee8 veee8 is offline
Car: BMW
Default 04-20-2016, 08:34 AM
Did you check to see if any codes were stored that need to be cleared?
Nicky92's Avatar
Car: 2008 335i
Default 04-20-2016, 12:21 PM
Yes. No codes. Cleared shadow codes on BT as well. No water pump codes before or after replacement
335- stock
speedhunter93 speedhunter93 is offline
Car: 335i Coupe
Default 08-03-2016, 01:32 PM
Did you ever solve the problem?
Nicky92's Avatar
Car: 2008 335i
Default 08-03-2016, 01:42 PM
Nope, it's crazy.
335- stock
Nitrousbird Nitrousbird is offline
Car: '07 335i 6MT
Default 08-03-2016, 04:29 PM
My water pump failed by running all the time, regardless of if the car was on or off. Has to disconnect the battery to stop it.
I have heard of a new one out of the box doing the same thing.
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 08-03-2016, 07:01 PM
I think it's a DME issue when this happens. Search the other forum there is some info on it
09 335 - 6266
07 335i - 6870, E85 - SOLD
Jsr1256 Jsr1256 is offline
Car: 08 335i Sport Package
Default 08-05-2016, 02:16 PM
Do u have the max cool mode on in the jb4? Or does it run 24/7
08 E92 335i AT 20k Miles | Wedge E60 Flash| E85 | VRSF FMIC | VRSF Lower Charge Pipe | ER Charge Pipe|Tial Bov| Vrsf *** | DCI | IC Sprayer | Scoops | NGK 1 Range Colder Plugs | Fuel It LPFP | E60 | [12.2 @ 118with e85 flash] [ My E60 flash 1/4 = 11.8 @ 120
InsipidMonkey InsipidMonkey is offline
Car: 08 E61
Default 08-05-2016, 02:42 PM
Did you purge the cooling system properly after replacing the T-stat? There is a special procedure for bleeding the cooling system with the electric water pump. Something about holding the pedal down with the system set to full heat in ACC mode (engine off)? I can dig it up if you can't find it with a search.
N54luvr N54luvr is offline
Car: 2010 335i xdrive
Default 08-06-2016, 03:40 PM
Your max cool is set on your JB4, turn it off and back to normal voila.
Nicky92's Avatar
Car: 2008 335i
Default 08-13-2016, 07:47 PM
It's not mad cool. And yes I bled the system.
It's something with the DME
335- stock
Default 08-15-2016, 08:43 AM
If your DME sees an issue with your AFR's, fueling is stuck in open loop, or something similar, your fan and pump will run 100%.
