Default JB4 for 2018+ AUDI RS3 & TTRS - 12-01-2018, 11:38 AM
Order here: http://www.burgertuning.com/vw_volks...Jb4_tuner.html
We'll use this thread for our upcoming Audi RS3 & TTRS JB4 SENT BETA updates, map guides, firmware, and discussion!
Install Guide here: http://www.n54tech.com/flash_files/audi_s4_install.pdf
Optional map changing, datalogging and updates are done using the BMS data cable or JB4 Mobile REV3 bluetooth kit.
BMS data cable hard wired directions and software Click here
Map guide as of v4 firmware:
Map0: Stock tuning, disable JB4
Map1: (default map) 2psi peak over stock
Map2: 3psi peak over stock
Map3: 4psi peak over stock
Map4: 5psi peak over stock
map5: 6psi peak over stock
Map7: Integrated WMI (water/meth) map, progressive control with boost increased as a function of fluid flow up to the user defined WMI additive.
Map8: Valet/Low Boost/Safety map. Runs 25% less boost than stock.
Dragy results:
10.8s all stock on JB4+E30: N54Tech.com - International Turbo Racing Discussion - View Single Post - JB4 for 2018+ AUDI RS3 TTRS
Firmware:
JB4_AUDI_TTRS_5:
1) Adjusted map5 to target up to 7.5psi over stock, for those running E30 or unleaded race gas who want to push things a bit. Results in around 22psi in most situations.
2) Adjusted shift boost reduction logic to further reduce boost spikes during shifts. Default setting is shift reduction = 50. A higher value will reduce boost more during shifts and a lower value less.
3) Minor adjustments to boost ramp in to improve operation under boost limiting/loss of traction situations.
4) Added support for low fuel pressure hardwire connection to monitor and rescale, allowing some fuel trim reduction in heavy E85 mixtures. Requires harness addition so is just under testing for specific cars for now.
JB4_AUDI_TTRS_4_T3:
1) Various minor map and tuning revisions.
JB4_AUDI_TTRS_3:
1) Revised boost targets per map
2) Added direct boost control logic allowing dramatically more boost than is possible previously. Enabling this unique feature requires purchasing the optional BCM module.
3) Revised logging channels to include high fuel pressure on a scale of 0-50 = 0-3000psi.
4) Revised logging channels to add road speed
5) Added in over boost and lean-run JB4 safety systems. If boost exceeds user adjustable "boost safety" setting for more than 1 second the JB4 will switch to map0 (disabled). If AFR goes leaner than 15:1 at full throttle for more than 1 second the JB4 will switch to map0 (disabled). More advanced user adjustable safety systems including the ability to failsafe to less boost than stock (for flashed cars) is under development.
JB4_SENT_AUDI_RS3_1:
1) Adjusted warm up temperature safety to avoid bug with it kicking in when car is heated up.
2) Adjusted cyl 2-5 logging parameters so they show much higher values, to make boost/octane evaluations easier.
3) Created a firmware split so "S4" firmware will be used for all six cylinder models, and "RS3" firmware for all five cylinder models.
FutureUseD Bit Settings as of v3 firmware:
Bit0:
Bit1:
Bit2:
Bit3:
Bit4: Turn on to disable JB4 passive safety systems (over boost safety, lean run safety)
Bit5: Turn on to disable extended Audi logging channels (knock 2-5, dme bt, ecu_psi, fp_h, gear). Disabling these channels doubles the sampling speed of the primary channels.
Bit6:
Bit7:
Default BCM settings:
How to update firmware via JB4 Mobile:
Default 12-08-2018, 09:54 PM
Here is a log off a flashed one, who will be using the JB4 for fine tuning, logging, and running WMI. All of the JB4 maps are currently additive based. So he's adding a couple PSI over "stock" here.
Bullitt1841's Avatar
Default 12-09-2018, 09:40 AM
AFR seems pretty good on this engine platform. What's the highest E85 mixture we can run with JB4 only?
Default 12-09-2018, 10:31 AM
Still a work in progress on the RS3, need to get fuel control working. We have it active on the S4.
Default 12-09-2018, 11:02 AM
What about 1-2 gallons per tank, for now? Our 91 is so bad here.
Default 12-09-2018, 11:18 AM
Should be fine, knowing you, we'll get logs both ways.
On the RS3 the big things we need to get done to really be competitive with the flash tuners:
1) Fuel control active
2) Wastegate control active
Of course, the flash tuners can never compete with the JB4's ability to remove the tuner without a trace.
Default 12-09-2018, 11:25 AM
Awesome. Launch control is so bad ass with this car. I could never launch this hard with my B58, even with launch control and sticky tires. Even with our 91, this thing just pulls all the way through 3rd gear.
Default 12-09-2018, 12:08 PM
Dragy it, let's see what you're doing stock.
Default 12-09-2018, 12:16 PM
I'm "supposed to be" breaking the engine and clutch in, ha ha. Did one launch control before I made the purchase just to be sure I wanted the car. Only had 100 miles at that point. Boy was it worth it.
Default 12-09-2018, 06:46 PM
The S4 launches really well, it's a standard style automatic transmission which I prefer. Easy 1.80 60' times. Would be faster with more power. It just needs a bigger turbo to compete with the RS3/TTRS crowd.
Default 12-10-2018, 12:36 PM
I'm not really understanding the transmission and shift behavior on the car yet. When driving normally on city streets it upshifts very quickly from 1st to 2nd, but then hold 2nd very long, as well as the next couple gears. I'm using Dynamic mode only for now to vary the RPM's and break in the car. Also, the damn shifter is backwards for up and down shifts. Hopefully there is some flashing that can correct these annoyances.
What tune is the other customer running? Integrated Engineering looks legit. Obviously APR is well known. But they are owned by the same company as Dinan!
Default 12-10-2018, 05:33 PM
Its running a custom tune from a small tuner in Europe.
RSthree RSthree is offline
Car: Audi RS3
Default Jb4 ?? - 12-15-2018, 02:56 AM
I have some newbie questions about the jb4 scene, just want to make sure Iím not misunderstanding anything.
I was looking at the other rs3 thread which said there were still issues being sorted for the Rs3 before it becomes available. Can I assume that this thread here implies the issues have been sorted and it is now on sale?
Also from what I read the jb4 unit is the same hardware for s4 and RS3, hence why all the documentation refers to S4?
I am confused about the order link as it makes no mention of Rs3. If you order on the supplied link how do you specify the RS3 code.?
Lastly are there any instal pics which show where the sensor connectors are located under the bonnet.
Look forward to your advice.
cityazndan cityazndan is offline
Default 03-10-2019, 12:55 PM
On stock ********, intercooler, intake etc.?
SOLD 2007 BMW 335i | 6AT | ZSP | ZPP | ZCW {Smurfin' before it was cool}
|JB4 G5 ISO|Cobb|S&B Filters|RB|Evolution Racewerks|Synapse|ar design|JetHot|Active Autowerke|Bastuck|
||Amuse Ericcson|M-Sport|M5 SMG Knob|V1 Yellow Stripe Steering Wheel||
SOLD 2009 BMW 335i | 6AT | ZSP |ZPP
|FBO, PS2, Meth and #spacegraybrigade|
OTW 2018 Audi RS3 |7DCT |Dynamic | Black Optics | Tech | RS Design
Default 03-10-2019, 01:49 PM
Correct.
Default 03-25-2019, 11:04 PM
Correct.
What numbers are you seeing or people achieving on map4/5?
tegxsi tegxsi is offline
Car: RS3
Default 12-15-2018, 08:31 PM
RS3 uses the same JB4 as B9 S4 and that is what you can purchase at the moment.
You need to update the JB4 with RS3 hex that is 1st post. You will only be using the TMAP and MAP connections on the harness for now.
More features will be added soon and a proper harness will be released in the near future.
I just got my JB4. I'm anxious and want to play.
2018 Audi RS3
2013 Mazdaspeed3
2007 Acura TSX
Donnie darko Donnie darko is offline
Car: M135i
Default 12-19-2018, 11:39 PM
@Terry
Maybe I have missed it somewhere in here but what happened to prefacelift 2016 Audi RS3 JB4? I have used JB4 on all my previous cars and like the way they work. Are you guys bringing one out? In the market for a chip now for my vehicle.
Default 12-20-2018, 08:03 AM
Originally Posted by Donnie darko
@Terry
It doesnt look like we going to do a RS3 for the 370hp version.
Default 01-13-2019, 05:51 PM
Our development TTRS finally arrived! Wasted no time throwing on the JB4 BETA to data log some stock runs (JB4 map), install was super easy. Photos below.
Default 01-13-2019, 05:58 PM
Did a baseline run today too on the way home. On the orignal tank of 93 octane the car came with. Damn it moves!
Default 01-13-2019, 10:00 PM
Is that with stock tuning or with the JB4 adding boost? Either way, you have some catch up work to do with me
Currently 100% stock with APR's Stage 1 E85 flash.
Default 01-14-2019, 09:35 AM
All stock baseline! See attached JB4 log from run.
We have a couple objectives with the platform. First to provide a robust tuning system for those who don't want to void the warranty by flashing. Second, to provide those who have taken the plunge to flash tons of extra features and options to make their tuning easier to use, safer, and more intuitive.
Default 01-14-2019, 05:34 PM
Yeah, these cars rip in stock form. E85 allows well over 20 degrees of timing at 22 PSI. Looking forward to stacking with the JB4 on lower ethanol mixes and less timing.
Car: RS3
Default 01-13-2019, 07:08 PM
I've been running the beta since December on my RS3. I've been communicating with George and sending him logs. I get an occasional random throttle close when WOT. Not sure what is causing it but seems like I only get it in the early morning when it's cold.
2018 Audi RS3
2013 Mazdaspeed3
2007 Acura TSX
